Make a Super-heroine Shield
18,602
397
44
Hi everyone !
This is my first insctructable and first big tutorial in english so please be fair with me ^^
The shield you see is just an exemple , you can make every shield you want. you can customize them as you want !
For this build you will need some stuff : A cutter - whipsaw - loctite brand glue - Eva foam sheet ( 1 cm thickness 5 mm and 3 mm )
Step 1: First Step : Drawing Your Pattern
I'm using illustrator, you can change the size of your drawing without loosing resolution or details.
Here are some exemple.
Once you think your pattern is good you have to print it at echel 1.
scotch tape your sheet together to get your pattern complete.
Step 2: Make the Shape of the Shield
Take a sheet of EVA foam ( actually foam use to protect the floor ) and cut a circle at the chosen size.
to bend the foam, cut of a litle part from the midle of circle to the edge and glue it.
Then you can start cutting the differents part following your pattern. and glue them on the shield.
You can use pin to fixe the foam details on the shield this will make the glue step very easy ( don't have taken pic for that ) sorry
For my shield, i used little stars to add more details.
Step 3: The Paint Job
First you have to apply 3 layer of wood glue the glue will work as light resin, the glue will correct the little imperfection and will add a smooth effect on the shield.
Then add 2 layers of primer
1 layer of black paint and then you can start the real paint job
I let you made your own
Step 4: Want to Fix It on the Wall
Just make a litle hook glue it on the back and it's done ^^
I used SINTRA pvc, cut it with the whipsaw
Step 5: You Can Also Make Real Shield Sangle System
using leather / screw and glue
Step 6: And the Final Product
i hope you will find the essentials informations to make these shield.
enjoy it and forgive me for my english
Superheroes and Supervillains Contest
Fourth Prize in the
Halloween Props Contest
Third Prize in the
3 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Classroom Science Contest
44 Discussions
CorruptedReality
2 years ago
I totally am going to do this for halloween this year! Just a quick question: in step 3 after applying wood glue and primer do you have to do the layer of black paint?Could you do a different color instead or will that mess something up? Sorry if this is a stupid question, I don't do a ton of projects involving spray paint..
briciiusCorruptedReality
Reply 2 years ago
i use black paint for ease of use. i explain : when you do the paint job it's possible that you miss some parts. if your layer is white or i don't know maybe green xD. the part that you missed will be very showy. if it's black it will be mingled with the rest of the paint job.
you can also hide some black parts with tape and create some contrast.
I've tried a white layer one time and that was a real disaster ! sometimes the parts i've have to paint are so little i just make a black layer and a quick dry brush and it's done. much easier than to paint all the little part with a pencil and tape .
PatKarrow
2 years ago
Dang this is amazing. I'm going to use this instructable to make a Captain America Shield. I'll show you when I'm finished :)
briciiusPatKarrow
Reply 2 years ago
Yeah !! The first one with 3 stars ? Or the new one with circles red and blue ? Because i ve made the first one one week ago and i can send you pics if you want it.
PatKarrowbriciius
Reply 2 years ago
the one with circles red and blue. I am hoping to also make the original one from WWII. That would be greatly appreciated, reference pictures will help a lot!
briciiusPatKarrow
Reply 2 years ago
i've just updated the instructable with new pics on the last step. as you can see i've customize the shield ( as always ) with some relief. you can also use a woodburning tool to trace the circles on the foam, something like what nemo13 did in the coms.
PatKarrowbriciius
Reply 2 years ago
Okay awesome thanks. That will help a lot!
whiteXshadow
3 years ago
how did you join the shields from the center after applying glue to it ?
briciiuswhiteXshadow
Reply 2 years ago
Sorry to be late ( euphemism ;) ) once you have applied the glue put the shield flat on your work surface and then using your both hand join the shield starting from the center to the edge.
Jedi_zombie85
3 years ago
Very cool, Ive not attempted a shild yet just a few ironman projects, how stirdy did you find the shield once completed?
Ive found with the ironman suits ive made from the same materials Ive had to add layers of the wood glue on both outside and inside of the armor to stop the other side that has not been coated from getting out of shape. is the shield the same or did it not need the extra support?
briciiusJedi_zombie85
Reply 3 years ago
it depend. the shield is "decorative" you don't have to make 100 layers of pva glue to harden it.
i can throw it, the paint will not take damage as the shield ;)
Jedi_zombie85briciius
Reply 3 years ago
thats good to know, even tho i spent ages on the ironman helmet and costume for cosplay purposes I found that the arms mostly needed extra support think from all the movement, i suppose the shield is different but still epic and goinf to give it a go, thanks
steve.verhil
4 years ago on Introduction
What kind of foam did you use for the raised details on the shield? The outer ring and center logo? What kind of paint do you recommend or use? These look awesome! Great job!
briciiussteve.verhil
Reply 4 years ago on Introduction
All the shield is made with EVA foam. You can find 4 or 5 differents thicknesses : 10 mm ( for the base of the shield ) 5 3 and 2 mm ( use for the details ). I also use 5 mm and 3 mm PVC round profiles to add more details.
For the last shield ( with the eagle ) i used SINTRA PVC for the "frieze" i can add pics if you want ;)
One more tips : you can use Screw head if you don"t have stars to personnalise your shield.
For the paint i use metal spray paint ( first i pulverize paint on a painting palette and then i use a brush to apply the paint on the shield i don't use directly the spray on the shield ).
And to protect the paint you have to use an elastic varnish like transparent plastidip
KathrynR11briciius
Reply 3 years ago
Hi! I'm looking through your tutorial on these shields and I'm definitely wanting to make one! My classroom next year is going to be "superhero themed," so these are kind of perfect for the walls! I've tried to make my shopping list of the materials and want to get the supplies tomorrow. I just wanted to ask a couple of quick questions regarding your help from this response. Did you buy your SINTRA PVC from a craft store or online? Was the thickness 5mm, 3mm, or 2mm? Where did you find the little 3D stars (or did you make them)? And finally, when painting, you mention pulverizing the paint on a palette. Do you mean you sprayed directly on the palette and used that to paint with a brush? I've just never heard that term before, so I wanted to make sure my understanding was correct. Thank you so much for your help!
briciiusKathrynR11
Reply 3 years ago
Hi :)
In france the sintra is PVC is hard to find in store so i've buyed it online.
i've used 3mm thickness, if you take 5mm it will be more difficult to cut it with a cutter. the 3D stars comes from a christmas garland ^^, you can make simples stars using eva foam ( the 3D effect is good but not indispensable )
And finally for the paint, when i say a palette i talked about this :
http://www.hainautnorddefrance.com/fichs/11458.jpg. in the tutorial i use spray paint but you can easily use acrylics paint ( really better for classroom if you your students make one ). i used a brush both.
i give you the link of my facebook album :
https://www.facebook.com/media/set/?set=a.26347910...
there are more photos, i think that can help you too
KathrynR11briciius
Reply 3 years ago
Awesome! Thank you so much! My students won't be making them; I actually plan on just having it as decoration in the walls somewhere to go with the "hero" theme of my classroom. But I have either paint, so I'll figure out what works best! I appreciate your help; thank you!!
gabigirl80
3 years ago on Introduction
This is beautifully done! Do you happen to know what the dimensions are for the shield? I am making a Captain America shield for my 5 year old and want to make sure that it will fit him.
Thank you so much for taking the time to make this.
CheerySquish
3 years ago
That's so big!! I assumed it would be a child size shield but you made those things like you were gearing up to fight? you might be..but you should totally try cosplay sometime ⭐
