Make a Wind Chime
68,109
262
11
Super easy to make wind chime, made with leftover materials from other projects, total cost $0
Materials needed:
nylon string
scrap wood (solid wood, not pressed such as mdf or plywood. if/when it gets wet it will eventually fall apart)
aluminium tube
Tools needed:
pencil
jig saw
hack saw
tape measure
scissors
sand paper
drill
drill bit (a little bit bigger than the size of the thread)
first step... figure out what you want it to look like.
I made mine to have 6 chime thingies with a hexagon mount.
Step 1:
On the piece of wood you're going to want to draw out the shape of the top mount, the middle piece that chimes the aluminium and the bottom wind catcher thing.
Once drawn out on wood cut them out. i used a jig saw for this.
Using the drill, drill a hole in the center of the piece that chimes and holes in the top mounting piece. See the picture for an explanation of the holes
Once you have all your holes driller grab your sand paper and sand everything down, round all the edges/corners.The smoother and nicer the finish you have the better it will look in the long run, so take your time.
Step 2:
Next wipe down all the wood with a lint free rag to take care of any saw dust. i like to vacuum the pieces too.
Grab a stain that tickles your fancy and stain the pieces. brush on, wait, wipe off.
I gave each piece two coats and let them dry overnight.
Once the stain is dry give the pieces a few coats (I did 3) of clear coat and again let it sit overnight to dry.
Step 3:
While your pieces are drying take the time to cut the aluminium tubing.
Not sure where i got mine from bu its basically an aluminium shower curtain rod. It is about and inch in diameter, thin walled so it has a nice chime.
Cut it into 6 pieces at different lengths. My longest one is 20" long and each piece is 1" shorter than the previous.
Once you have all the pieces cut, mark them all at equal distances from the end of each pipe. I did 4" from the end.
Step 4:
Now come putting it all together.
I started with the strings that will hang the wind chime. I cut 3 pieces of string each about 10" long.
Tie a knot on one end and thread the string through the top piece of wood and also through opposite corner and tie a knot to secure it. (see picture) Repeat for the other two strings.
Step 5:
Now on a new piece of string tie a know on one end and thread it through the wood catcher piece.
Then about 18' up from that tie a knot in the string and slide on the piece that chimes.
About 12' from the piece that chimes tie another knot and slide the top mount on.
Once on tie another know to keep it all in place.
Sorry its kinda hard to explain, i hope the pictures help.
Let me know if you have questions!!
Step 6:
attaching the aluminum "chimers"
Cut 6 equal lengths of sting. I cut mine 13.5" long so the chimers will hang 6" below the top piece. (1" for the diameter of the pipe and 1/2" for the knots)
On each piece of string tie a knot on one end and feed it through one of the holes in the corner, through the hole you drilled in the aluminum pipe, back up and through the top piece again and tie another knot to secure it all.
Again see pictures to help clear it up and let me know if you need something explained better.
Hang it up and enjoy the sounds!
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    11 Discussions
    maximzodal
    4 months ago
    Tube length and hang points are crucial to good sound. This site has all the information you would need to build nice sounding chimes: http://leehite.org/Chimes.htm
    sharpstick
    5 years ago on Step 3
    Thicker tubing material will make a richer sound. And drilling your suspension holes at 22.4% of the length at the vibration node will lessen dampening of the vibration. (This is the point where the pipe doesn't move while vibrating.)
    flammaefatasharpstick
    Reply 4 years ago on Introduction
    So does this mean the longer tubes will have a longer string, and the shorter tubes a shorter string? Does it make a big difference?
    sharpstickflammaefata
    The string length doesn't matter except to determine the location/height of the tube.
    Usually chimes are made so the tops are at the same level, but that is up to you.
    I am not aware of any striker height importance.
    I was just wondering about your 22,4% length comment for the suspension holes. So on a 10 cm chime the hole for the string should be drilled 2,24 cm from the top, but on a 20 cm chime the hole should be 4,48 cm from the top, to result in the least dampening of the sound? Sorry my previous comment was a bit less clear (the different lengths for the holes mean different lengths for the strings to get them hanging on the same level).
    EugenioR8flammaefata
    Reply 1 year ago
    That's correct. I like to make my wind chimes line up at the bottom, that way, the striker hits the edge, which is a recommended spot. The BEST part to drill the suspension would be the center, but gravity will make that impossible and/or impractical, so the next best percentage is 22.4%. It will dampen the overtones, giving it a caressing sound.
    sharpstick
    4 years ago on Step 3
    You're not clear about how to determine lengths. What note system is this supposed top be? There are online calculators to determine lengths by which note you want each tube to be. Then you cut a bit long, test it, then file shorter until it matches. There are android apps for guitar tuning that will help.
    waterbaby
    5 years ago on Introduction
    Years ago I bought gorgeously-toned large wind chime which weathered the weather year round for a couple of decades before the strings started to fail. Just the other day I was thinking how nice it would be to hear it again and that I really ought to figure out how to fix it -- and now thanks to you I can!
    cyber5
    Looks good! I made some chimes years ago and found a cool website that explains where to drill holes to hang them and how long to cut them if you want to tune them for the best sound, or to specific musical notes. https://sites.google.com/site/chuckchimes/
    darman12
    5 years ago
    Sweet chimes! We made similar chimes in 8th grade pre-algebra. We even used a guitar tuner to calibrate each tube. Can't resist commenting on your wind catcher; it looks like a coffin :) Great job!
