Make an LED Light Box
46,960
664
42
About: This is all about inspiring you to build stuff with your own hands! http://youtube.com/gethandsdirty
You should know that a light box that can be used for a bunch of creative stuff, so let's get started!
The video helps to understand the whole process. :)
Step 1: Make the Box // Cutting All Pieces to Size
We start by cutting the wood to the desired size you want the box to be. This box has 60 x 40 x 8 cm (aprox 15" by 23" by 3" tall) and you can make it any size you want but I recommend not making it too shallow so you can get a better light refraction inside the box.
For the material I am using 10mm plywood that is going to be joined with 45º miters with internal splines for reinforcement but you can use solid wood or 1/2" or 3/4" plywood that you might have laying around.
To make the 45º angle cuts, I used a table saw sled made specially for this type of cuts and you can see how I made it right here.
After cutting all the 4 sides to their final size, you will want to create two rabbets all around. One is for the backer board to seat properly later and the other one is for the white opaline acrylic sheet (translucent) slide in and out if someday you need to replace it. I used 3 mm (1/8") opaline acrylic sheet.
One of the sides is a bit narrower than the other three. That will allow the acrylic sheet to slide in and out in the future. I mistaken this part when making this light box and I fixed it all up in the video so you might want to check it out first!
Step 2: Reinforce the Miters and Glue Up
Since we are using tall miters, it's quite important to reinforce them and there are several ways to do so. The one I chose and found out to be very efficient and easy to make is with hidden long splines.
It's so quick and easy once you put a stop block on the 45º table saw sled that makes the process a real pleasure.
After all the slots are cut, we need to make some solid wood splines from a strip and tune them up just so they become just a little bit lose in the slots to allow some space for the glue.
We can now glue the 4 sides with the hidden splines and a picture frame clamp really helps. Make sure everything is square and that the acrylic sheet seats nicely in its rabbet.
Step 3: Make a Top Frame to Close the Slot
Now you need to create a barrier so that the acrylic sheet stays trapped inside the groove.
You can easily do that by making a border frame with solid wood strips after cutting some miters so they look nice since this is going to be pretty visible.
Don't forget that one piece of the border needs to be thicker to match the final height of the light box (remember on Step 1 when I talked about my mistake on the video?). That is the piece that won't be glued and be able to come out if you need to remove or replace the acrylic sheet.
Before gluing up, it's a good idea to cover the edges of the acrylic with some plastic wrap so that the glue squeeze out doesn't fill the groove and also don't stick to the sheet. Be patient when removing the sheet with the plastic wrap. It will come out nicely if you take some time.
Step 4: Apply Finish and Reflective Material
It's time to give it a light sanding to prepare the box for finish. I used wood sealant and spray lacquer but you can apply your favorite protective finish.
Once the outside is done, we need to concentrate on the inside and make it as reflective as we can. A really good choice is to stick aluminium tape to the interior of the sides and also (very important) to the backer board (I'm just using a piece of thin MDF).
Step 5: LED's and Closing the Box
We are getting closer and closer to the end!
Now we just need to stick some LED strip to the sides the farest possible to the front acrylic sheet so that the light can spread more evenly and close the box. The closer the LED strip is to the acrylic, the more evident the bright line will be. And if you stick it to the backer board, you will also get bright light stripes, which, in this case, I don't find particularly good for the purpose. Unless you apply lots and lots of strip covering the entire backer board, you will always get those visual bright lines when you look front to the light box. That's why I found that applying them on the sides ends up getting a better result. But if your box is very very big, you will eventually need lots of strip so minimize the middle darker area or perhaps using an ultra bright and powerfull LED strip might work.
After closing the box and attaching some wooden holders on the bottom, you will need to drill a few holes to insert screws from the front on the movable border piece.
Now you just need to plug it on and make cool stuff with it!
Step 6: More Projects!
If you enjoyed this project, you should check out more videos on my channel and don't forget to subscribe!
    • Epilog X Contest
      Epilog X Contest
    • Organization Contest
    • Tape Contest
      Tape Contest
    42 Discussions
    onlylivemusic
    3 years ago
    Awesome work, your video production is as good as your woodworking!
    Dwargh
    3 years ago
    Good work on this one! I like your video tutorial a lot! Now I want to have my own light box! :)
    dougstrickland
    3 years ago
    You are a very talented young man. Very inspiring!
    N3TQV
    3 years ago
    IMHO you are an excellent woodworker and craftsman, fortunate to have all the tools to do the job right. You have also done an excellent video presentation, professional quality. Kudos to you for your hard work.
    nightshift911
    3 years ago
    Do you find that 1/8" for the acrylic is strong enough to resist bowing inward while tracing?
    I'm currently using a converted laptop with a piece of glass over the "screen," but it is not big enough and I am collecting ideas for building a box that has a better size and portability.
    Get Hands Dirtynightshift911
    Reply 3 years ago
    Depends on the size of the box. For this one (60 x 40 cm) it flexes a bit but no big issue. If your light box is bigger I recommend using a thicker sheet, though I may want to keep in mind the thicker the acrylic the less light will come through.
    Seeed Studio
    3 years ago
    Nice job. The video is really cool.
    Syrus7808
    3 years ago
    Just one word ! " Awesome " for - work - video - workroom ( so jealous!!) detail to explain everything- keep it up mate & u will go far!! Looking forward to more instuctables...
    littsz
    3 years ago
    I actually made a lightbox myself using a broken photocopier, which had a detachable top part that came as a box with a clear screen and everything. But, I placed the LEDs down in strips on the backer board, and I was wondering how to get rid of the bright lines and make the light even, so thanks for the tip! It didn't help that the interior was black either.
    Though, would LED boards be a viable option to even out the light? I have seen them being used in advertisement boards quite effectively (though I haven't seen any for sale).
    gbeltrao
    3 years ago
    An idea that can save us lots of time would be to reuse a portrait frame box without the screen and just work out with the acrylic and LEDs after.
    vincent burgio
    3 years ago
    would aluminum foil work as the liner
    kcbaltz
    3 years ago
    I chose to put my LED strips on the bottom and I just painted the inside white. It does have a striping pattern to the light, but once you put your tracing source material on top, it's very noticeable. I do think the "wrap-around" method here would be easier to wire as I had to cut mine into strips and join them with clips that were supposed to be no soldering required but I ended up having to solder every one.
    kcbaltzJonathanrjpereira
    Reply 3 years ago
    I built mine using a clear acrylic sheet and to make it diffuse the light, I sanded it with 220 sand paper on a random orbit sander. I choose to leave the "up" side smooth but you can get more diffusion if you sand both sides.
    JustinPhilpott
    3 years ago
    love this video!! And your workshop!
    snootyblaine
    3 years ago
    Wow, that was some awesome precision woodworking! The ingenuity and simplicity of your work is astounding.
    Your process and attention to detail is so inspiring; I would love to see your creations using other media!
    Thanks
    rring883
    3 years ago
    Great job on the video, too!
