Make Your Own SIMPLE 5x5x5 RGB LED Cube
75,149
466
69
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to build a simpler version of a 5x5x5 RGB LED Cube. The driver circuit only consists of an Arduino Nano and the programming is rather simple due to the FastLED library. Let's get started !
Supplies:
Step 1: Watch the Videos!
The videos give you the mandatory information you need to build this project. In the next steps though I will give you some additional helpful advice.
Step 2: Order Your Parts!
Here you can find a list of all the necessary electrical parts to build the cube:
Amazon.com:
1x Arduino Nano: http://amzn.to/1XrlQJy
150x PL9823 8mm LED: -
1x Veroboard: http://amzn.to/1XrlQJy
3x PCB terminal: http://amzn.to/1XrlQJy
2x Female header: http://amzn.to/1XrlQJy
1x Toggle Switch: http://amzn.to/1XrlQJy
1x 10k Potentiometer: http://amzn.to/1XrlQJy
1x DC Jack: http://amzn.to/1XrlQJy
Silvered Copper wire: http://amzn.to/1XrlQJy
1x 5V Power Supply: http://amzn.to/1XrlQJy
Amazon.de:
1x Arduino Nano: http://amzn.to/1k2lfiB
150x PL9823 8mm LED: http://amzn.to/1k2lfiB
1x Veroboard: http://amzn.to/1k2lfiB
3x PCB terminal: http://amzn.to/1k2lfiB
2x Female header: http://amzn.to/1k2lfiB
1x Toggle Switch: http://amzn.to/1k2lfiB
1x 10k Potentiometer: http://amzn.to/1k2lfiB
1x DC Jack: http://amzn.to/1k2lfiB
Silvered Copper wire: http://amzn.to/1k2lfiB
1x 5V Power Supply: http://amzn.to/1k2lfiB
Ebay:
1x Arduino Nano: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
150x PL9823 8mm LED: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x Veroboard: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
3x PCB terminal: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
2x Female header: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x Toggle Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 10k Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x DC Jack: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
Silvered Copper wire: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 5V Power Supply: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
Aliexpress:
1x Arduino Nano: http://s.click.aliexpress.com/e/QBqzZvFEQ
1x Veroboard: http://s.click.aliexpress.com/e/QBqzZvFEQ
3x PCB terminal: http://s.click.aliexpress.com/e/QBqzZvFEQ
2x Female header: http://s.click.aliexpress.com/e/QBqzZvFEQ
1x Toggle Switch: http://s.click.aliexpress.com/e/QBqzZvFEQ
1x 10k Potentiometer: http://s.click.aliexpress.com/e/QBqzZvFEQ
1x DC Jack: http://s.click.aliexpress.com/e/QBqzZvFEQ
Silvered Copper wire: http://s.click.aliexpress.com/e/QBqzZvFEQ
1x 5V Power Supply: http://s.click.aliexpress.com/e/QBqzZvFEQ
Step 3: Create the Cube and the Wiring!
Here you can find a couple of pictures on how the wiring should look like and the .svg files for the cube.
Step 4: Upload the Code!
Don't forget to include the FastLED library in your Arduino folder before trying to upload the code!
FastLED library: https://github.com/FastLED/FastLED
And here you can also find two example codes with a couple of animations.
Step 5: Success!
You did it. You successfully built your own simple 5x5x5 RGB LED Cube.
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
7 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Arduino Contest 2019
69 Discussions
Vashiru
Question 11 months ago
I've asked this on the Youtube video as well but hopefully this will help speed things up. I really like the simple design of this, less wire obscuring the LEDs, but I want to go bigger. I want to do an 8x8x8 cube, would this be possible by simple using this design? I assume I'd need a different resistor and a stronger power supply but are there any other issues that might occur? Or do I really need to look into another tutorial and dive into how shift registers etc. work?
edo23syahputra
12 months ago
can anyone explain why is it doesnt work with 5mm LED?
edo23syahputraGuransh Singh
Reply 12 months ago
hey, do you have any recommendation for the LEDs? its hard to fint those type in where i live.
masterofcodeGuransh Singh
Reply 2 years ago
you could use these ws2811, p9823 or apa106 LEDs, they all function about the same. Here's the eBay listing:
http://www.ebay.com/itm/WS2811-APA106-P9823-F5-5mm-F8-8mm-Round-RGB-LED-chipset-Full-color-LED-Chip-5V-/262557174771?var=&hash=item3d21a08bf3:m:m8T47ldvZXsC047otS-x2Jw
andreas.grainHùngT14
Reply 3 years ago
you could not controll it just by conecting it to the arduino. it would be to much for one arduino. he acually did a version where you can use rgb leds, but you would need couple more parts.
wilson3682
1 year ago
Great Job Scott! I made one and it works really nice. Waiting for a code with more effects. Thanks! Here is a short video of my working cube:
AndrewH345
1 year ago
Can i use an arduino uno?
LokiG1
1 year ago
Where can I find the programing tutorial ?
Great project.
im_yoganandhan
1 year ago
I need a program to glow LEDs like alphabet letters
RhysH14
1 year ago
would this scale up to a 8x8x8 cube or do i need to add something to the circuit?
MartinR190AestumB
Reply 2 years ago
I also have the same problem. Did you find a solution?
AestumBMartinR190
Reply 2 years ago
Yes, problem was that some of led was soldered badly. So check each led to be soldered well.
masterofcodeAestumB
Reply 2 years ago
all I can say is make sure all LEDs work, the voltage is about 5.5 volts and that the data wire isn't corrupted anywhere. Any of these can cause the LEDs to freak out like that.
FlorianB30AestumB
Reply 2 years ago
Hi
I have the same problem did you find a solution?
BernardN13
2 years ago
Hi i was wondering if you had a wiring diagram that could help
TorstenD2
2 years ago
Hi everyone,
can someone give me links/sites with animation/programms for this cube ?
