Make Your Own Longboard
16,004
332
12
About: mechanical engeneering student
In this instructable I will show you how I made my longboard, I hope you like it as much as I do!
warning: always be safe around tools, and ride safe afterwards.
Step 1: Materials
To make your longboard you will need a couple materials. they are very easy to find, so this won't be a problem!
you're going to need:
- +/-9 layers of 1/2 mm maple veneer, it doesn't have to be maple, but this is a strong and still flexible wood so i prefer this for my longboards.
- woodglue
-scrap wood to make te press.
-a dozen bricks, or other heavy objects.
-spraypaint and clearcoat spray
Step 2: Making the Press
The press is used to give the board its concave while it is glued. this press consists of 2 pieces, 1 board with ledges glued on top and one strip of wood to press veneer into the mold.
make sure to round off all the edges so that de veneer doesn't break.
the strips of wood on the board are around 3cm +/-1 inch thick.
the 2 strips on the side of the mold make sure that de board gets concave, and the strip on the end of the board makes a kicktail.
Step 3: Preparing the Wood
before you can glue the wood you have to cut it to the right size, mine is 85 cm by 20 cm but you can make it every size you want, just make sure it fits in your mold!
cutting this thin veneer can be done with only a stanley knife, or a boxcutter.
when everything is cur to the right size, you can fit it in your mold and deside how big your kicktail is going to be. when you've prepared everything you can go to the next step which is glueing the veneers.
Step 4: Glue-ing
the next step is to glue the veneers together in the mold/press, before you start make sure you have something heavy in reach to put on your press so the wood takes the shape of the mold, i used bricks for this.
the next thing you have to do is cover 1 side of the first layer of veneer in glue, do this in a zigzag patern and spread the glue with a piece of cardboard, put ALOT of glue on the boards, otherwise it will not hold the shape.
the inner layers have to be coverd with glue on both sides.
when you've glued everything and set the weight on the press leave it over night to dry. wait at least 2 days before you start shaping the board.
Step 5: Taking It Out
After 24 hours you can take the wood out off the mold and make sure it went ok, don't start cutting yet, wait at least another 24 hours so the glue can fully harden.
Use this time to make a stencil for the shape of your board (see picture 3) and trace this onto the wood.
Step 6: Cuttting the Shape
After 2 days you can cut the board into the shape you want, I used a electric saw for this, if you don't know how to use these, ask someone who does, of your parent to help you.
After cutting you can round off the edges of the board (picture 3) I did this using a file and sandpaper, but you van use anything you want.
- To get a consistant round edge you can cut a pvc pipe in 2 and lay the sandpaper inside, this way it will follow the rounding of the pipe and give you and even roud edge!
The next step is to drill the holes fot the trucks, unfortunatly I don't have photos of this, but it is really simple to do.
First draw a line in the midde of the board, grab the trucks you're going to mount on you board an place them somwhere on this line(where you think is the right place but the rear truck has to be somewhat behind the kicktail).
Step 7: Graphic
In this step you're going to paint your board.
Before you start painting make sure you sanded your board really well!!
You can paint everything you want on your board or just leave it blank, I chose to paint a abstract skull on it.
First I made the skull on my computer, I used some pictures I found on the internet as inspiration.
I printed the design on normal paper and using a sharp knife I cut the black sections out.
Step 8: Painting Time
Before I painted the skull on the board I painted the board white using spraypaint.
To get the skull on the board I sticked the pre cut paper on the board using a prittstick, I used this because it will easily let go when I'm done with painting.
After I stuck it on o painted the board with light and even coats so the glue wouldn't let go, unfortunatly I forgot to take much photos during this step.
When the paint dried you can remove the paper and you will have your design on there!
Don't forget to apply a blank layer of laque when your finished painting, it will ensure your board is waterproof, and will give it a longer lifetime!
Step 9: The End
I'm very pleased with the result, I hope I made the steps clear enough for you to follow along.
If you have any questions, leave them in the comments.
I put much time in making this instructable, if you liked it I would apreciate it very much if you vote for me in the contest!!!
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    12 Discussions
    BadZombie
    4 years ago
    How long do they last compared to store bought boards.
    martijno_0BadZombie
    Reply 4 years ago
    This one is holding up fine now, but they do last a long time, I have this one which I made 2,5 years ago and rode everyday since and still looks and rides well!
    dscholten
    4 years ago
    welke platen van de praxis?
    martijno_0D-I-O-N
    Reply 4 years ago
    In the past I used to go to a lumberyard for veneer, I did this for several boards. this particular one was a recycle project, the veneer was packaging from some furniture.
    D-I-O-Nmartijno_0
    Reply 4 years ago
    what lumberyard did you go to? I'm guessing you live either in Belgium or the Netherlands. I live in the Netherlands and I can't find veneer.
    martijno_0D-I-O-N
    Reply 4 years ago
    The easiest way is to google "berk/esdoorn fineer" than you will find a shop near to you, the easier way (since you're also dutch) is to go to a store where they sell "composiet platen" most of the time these are packed with 1mm thick veneer (not maple but good enough and free!). (this wood came from "praxis")
    eman.rojas.5
    4 years ago on Introduction
    how did you align the wheels so that the board goes straight and can you share your sketch or plans for the outline of the board
    martijno_0eman.rojas.5
    Reply 4 years ago
    I drew half of the shape on several pieces of paper and than I cut this out. using a tapemeasure i found the middle line of the board (length wise) en taped my paper on this, i traced this on one side, than fliped it iver and did the same on the other side.
    unfortunatly i cannot share my design since i don't have it anymore
    sorry.
    Flash67
    4 years ago
    Wow! Nice finished product.
