Makedo Giant Windball
33,272
209
19
About: Makedo is a simple to use, open-ended system of tools for creative cardboard construction. Build imaginative and useful creations from upcycled (repurposed) everyday cardboard. Makedo comes to life in collab...
If there’s any single Makedo project you have to make, it’s this one. We’re releasing the secrets to the infamous Tanaka Satoshi Giant Windball, from Makedo's Master Maker in Japan.
One of our most revered Makedo creations for it’s stunning visual design, creativity, simplicity and adaptability - but most of all hours of play. No need for further explanation, these pictures and video of one Giant Windball’s adventures in Japan speak larger than words.
All you need are some reclaimed cardboard sheets and Makedo re-pins and re-clips available at mymakedo.com.
See the windball in action from Flickr:
Step 1: Find
Source cardboard and cut out 30 30x30cm squares. Use the point end of the Makedo safe-saw and punch holes on all four corners of the cardboard square, however not too close to the edge. Use the Makedo hinge as a spacing guide.
Step 2: Punch
Punch holes on all four corners of the remaining 29 pieces of cardboard.
Step 3: Connect
To begin the ball, connect 5 pieces of cardboard from corner to corner using Makedo pins and clips.
Step 4: Connect
Continue to connect the pieces together using Makedo pins and clips, moving from layer to layer. As you work up, the form of the ball begins to mould itself into a rounded shape. To assist you in visualising your windball, the negative space between the cardboard should be forming triangles and pentagons.
Step 5: Complete
Your Makedo Giant Windball is complete! Have a ‘ball’ of your own and take it outside for a spin! Make one of any size or colour to decorate your home using cardboard scraps and a Freeplay KIT for THREE. Download easy instructions from the Makedo blog...
Don’t forget to post your Windball adventures on Makedo's Facebook page.
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
19 Discussions
mrsmerwinJack A Lopez
Reply 2 years ago
rhombicosidodecahedron is probably not even in the vocabulary of most math teachers--which bothers me a lot since I am a math teacher.
mrsmerwin
2 years ago
The one I am planning will be more in the Christmas ornament size. I am going to use cardstock and hold it together with glue stick.
l8nite
6 years ago on Introduction
hhmmmm coraplast from old signs instead of cardboard would make this more weather resistant... very interesting idea
linny
6 years ago on Step 2
This really appeals to me. So inspiring! You could have a party with 30 guests and have them all decorate a piece of cardboard.
OR You could take 30 LP album covers (!) and use the fronts of them. Or 15 and cut them up! Maybe someone has already done this??
armored bore
7 years ago on Introduction
http://www.youtube.com/watch?v=kgrnIBlxZCk
That's all there really is to say on the matter.
CynthiaR
7 years ago on Step 2
That is a great idea! I really like to see such creative things! :)
cammersmakedo-able
Here it is. I had to invent my own cleats to hold it together. They didn't work very well so duct tape to the rescue again. I think the makedo gear would be much much much easier and neater.
makedo-ablemistyp
This project would take around 60 makedo pins and clips. :) Makes building it a lot easier and simpler.
