Making Fire With Ice!
100,709
96
86
About: http://www.webfun.org http://www.dometents.com http://www.gripclips.com http://www.relieftents.com http://www.primitiveways.com http://www.woodenbikes.com http://www.bobgillis.com
Use clear lake, pond ice or try boiling water for 3 minutes let the water cool; then boil for 3 minutes again and let cool to remove gas. Create a foil container 2" deep and freeze slowly. Or buy a clear block of ice. To make fire, the ice must be clear.
Look at the bottom of http://primitiveways.com/fire_from_ice.html to see a Big ice lens.
Step 1: Shape the Ice Lens for Fire Making.
Shape the ice lens for fire making. First shave with a knife to get the rough shape of a lens. You can also grind your ice fire lens on cement or a stone.
Step 2: Finish Shaping Your Ice Fire Lens.
Finish shaping your ice fire lens by using the heat of your hand to melt the ice lens smooth.
Step 3: The Edge of Your Lens Should Look Something Like This.
The larger the lens the better: it will collect more sun. You will want the lens to be about 2" thick and more that 6" in diameter. The lens should be smothly curved on both sides
Step 4: Focus the Brightest Spot of the Suns Light Onto Your Tinder.
Locate tinder that is completely dry and finely divided. With the sun at its highest in the sky hold your lens perpendicular to the sun and move it up and down to focus the brightest spot of light onto your tinder. Be careful to avoid dripping water onto your tinder. The tinder will first smoke and then ignite. Carefully add more tinder and very small sticks until a good fire is established.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    86 Discussions
    KquotesC
    3 years ago on Introduction
    find some clear ice, shape it and start a fire.<a title="best friend
    quotes"
    href="http://kquotes.com/category/best-friend-quotes/"> best
    friend quotes</a>
    Reiff
    5 years ago on Introduction
    Now that is a very good survival skill. That's amazing, how did you come up with this?
    mrmerino
    6 years ago on Introduction
    Excellent. Now, someone needs to figure out how to create ice from fire.
    stevet47
    6 years ago on Step 4
    Very cool and simple skill to keep in the back of your brain incase you ever need it! Thanks!
    BarrettkgJakwiebus
    Reply 6 years ago on Introduction
    And they might have gotten the idea from the movie, The Edge. They never actually did it but Anthony Hopkins' character mentioned it
    If you already have "Pond water" or a clear block of ice, you don't have to boil.
    Boiling Tap water removes the stuff that makes our drink Ice look white and cloudy.
    Matinpooboy
    Reply 11 years ago on Introduction
    It is me in both places; that is if you are talking about Primitive Ways. If you have any doubt ask (emial) any of the other "clan" on the PW site.
