Making Laminated Wood Spoons
9,253
86
16
About: I have an unhealthy relationship with pallet wood. I make fast paced and entertaining build videos on my YouTube channel that are made for everyone, but with the ultimate goal to get the younger generations ...
This pair of wooden spoons made in collaboration with Pat Laperrière over at Le PicBois in Quebec (Fabrication de cuillères en bois avec la collaboration de Pat Laperrière). The spoons are the size of a large kitchen spoon and are made from a lamination of walnut and cherry. Pat laminated them and cut them down to rough size and then I carved them down to final sized and dished them out. And then sent one of the spoons back to him and kept the other, we like to use it as proof of us "spooning" together.
Step 1: Materials & Tools Used on This Build
Materials
- Cherry wood
- Walnut wood
- Wood glue http://amzn.to/2kID2jI
- Mineral oil/beeswax finish http://amzn.to/2Bk950Z
Tools
- Table saw http://amzn.to/2j4bvVU
- Radial arm saw (or miter saw) http://amzn.to/2j614UM
- Belt sander http://amzn.to/2oS8zyE
- Pipe clamps http://amzn.to/2jkLLbO
- Jointer http://amzn.to/2sr7SlQ
- Bandsaw http://amzn.to/2j4auNu
- Hot glue gun http://amzn.to/2jfKopP
- Random orbital sander http://amzn.to/2jrwsJC
- Die grinder http://amzn.to/2H6xebC
- Screw clamps http://amzn.to/2k4EvjT
Step 2: Preparing the Materials
Pat starts by cutting the pieces all down to the right width on the table saw. First some bigger strips for the walnut and then some thinner strips of cherry to contrast the walnut.
He then uses the radial arm saw to cut all of the strips down to the same length which will ultimately be the length of the spoons.
To prepare for the glue-up, he uses the belt sander to flatten the face of all of the pieces. The back plate of the belt sander is perfectly flat so this completely flattens and takes out any saw marks from the pieces.
Step 3: Glue-up
Wood glue is applied and spread on the surface off all of the pieces and then they are assembled together to make some walnut racing stripes.
Pat clamps them up using some pipe clamps to hold everything together while the glue dries. He made sure to leave out glue between the blanks for the 2 different spoons though so he can just pop them apart later.
With the glue dry, Pat pops them out of the clamps and runs one face across the jointer to flatten it and then runs the blanks through the planer as well to bring them down to thickness.
Step 4: Cutting the Blank
He ended up free-hand sketching the shape of the spoon on one half of the blank and then cut along that line on the band saw.
The cutoff from the first cut can then be used by flipping it over onto the opposite side as a pattern so each side is a mirror image. He then cuts that on the bandsaw as well to establish the shape in 2 dimensions.
For cutting it to shape in the 3rd dimension, he no longer has a flat surface to reference off of, so Pat uses a few dabs of hot glue to temporarily stick the cutoffs in place.
He then draws out the lines for the bottom and top of the spoon and cuts those lines on the bandsaw. He can now separate all of the pieces from each other and we now have our roughed out spoon shape.
Step 5: Getting the Blanks to the US
Delivery from Canada to the US is easier said than done...
The first attempt was to just shoot over the boarder real quick...
That didn't seem to work out too well, so he mailed them to me instead. Nothing wrong with a back up plan.
Step 6: Rouge Carving the Spoon Shape
After approximately 829 years, the package arrived at my shop. I start to refine the shape of the spoons on my bandsaw. It's just a matter of taking a bunch of little cuts off of the corners of the shape to round everything over. Safety note: only take small bites or it will want to bind up.
After nibbling the corners down, I can further refine the shape by running it backwards along the teach of the blade of the bandsaw to essentially just grind the shape down a little smoother. With this motion you just want to be very aware of what you're doing and keep your hands away from the teeth of the blade since you're kind of working backwards from normal.
Step 7: Fine Tuning the Shape
The last bit of shaping of the spoon is done with my random orbital sander. Sanding down the shape brings the surface down completely smooth and creates some really nice looking curves.
You can see the before on the left and after on the right. Lots of sawdust, but now it's starting to look like a spoon and the handle feels good in the hand. I just repeat the process to shape down the 2nd one.
Step 8: Dishing Out the Spoon
To establish the dished out portion of the spoon, I trace out a line along the edge of the scoop to follow along with when I carve it out.
I start by shaping things down with a die grinder attached to my compressor. The bit has a round nose to it so it carves away material fairly quick to concave the spoon.
Step 9: Scraping Out the Scoop
Once I get it dished out to rough shape, I take an old utility knife blade and round over one side of it. This profile will act light a tiny card scraper to scrape out the rest of the inside of the spoon.
Lots and lots of scraping to get it to a satisfactory finish, but the scraper actually leaves behind a great looking surface finish.
Step 10: Finish
For the last step, the finish can be applied for the spoons. I use a mineral oil & beeswax mix like what I use for cutting boards. Even though we'll probably never actually use these, this ensures that they are entirely food safe just in case. The oil brings out the color and the beeswax gives it a bit of a shine!
Step 11: Glamour Shots
Thanks for checking out the build, but definitely don't miss the build video too. Pat is a fantastic video editor and did this one with me, you won't want to miss. He's even sub-par with special effects ;)
Thirsty for more? You can also find me in other places on the interwebs!
My Website: Essentially my entire life
https://www.jackmanworks.com
YouTube: Me, in moving picture form
https://www.youtube.com/jackmanworks
Instagram: Preview my projects as they progress #nofilter
https://www.instagram.com/jackman_works
Twitter: Riveting thoughts, in very small doses
https://www.twitter.com/jackmanworks
Note: This post contains affiliate links. Thank you for supporting what I do!
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    16 Discussions
    HorusCok
    2 months ago on Step 11
    Running the stock backwards against the bandsaw blade - Brilliant! This is the kind of hidden nugget that encourages me to read every word. I should have thought of that - but, did not. Thanks.
    meddler
    10 months ago
    I would like to repeat Alfon1917's question. Are these food safe using the wood glue? I would very much like to try it.
    JackmanWorksmeddler
    Reply 10 months ago
    Yes, we used titebond glue, which is labeled as food safe
    denbecr
    1 year ago
    Great instructables. Small correction needed. "Sub-par may seem to mean above average if thinking of a low (good) score in golf, but it actually means the opposite: https://www.merriam-webster.com/thesaurus/subpar
    I'm sure you meant to say the special effects are excellent.
    alfon1917
    1 year ago
    Great instructable.
    I do keep wondering, however: will it still be food-safe with the glue? And will the lamination hold up if used for cooking?
    christine828
    1 year ago
    Beautiful spoons. Great video. I only wish both you guys wore protective eye wear when using your power tools. Stay safe, dudes. We want to see more instructables from you!
    deluges
    1 year ago
    Very cool! An exercice in trust between two craftsmen :)
    JackmanWorksdeluges
    Reply 1 year ago
    I'm still not certain if I trust that guy haha
    KurtPH
    1 year ago
    I loved it. I always wondered how to make the bowl. I have loved the thought of making these myself. I wondered if roughing it out with a router would be helpful, especially a plunge router set to various depths. Speaking of roughing, please look at Step 6: change spelling to rough. Not Rouge.
    JackmanWorksKurtPH
    Reply 1 year ago
    For big spoons I think some sort of router jig would be super useful to take out a bunch of material!
    timdekker1825cpalac
    Reply 1 year ago
    I agree, would have them on display instead of using them for food!
    doing2much
    1 year ago
    Simply beautiful!
    mrwonton
    1 year ago
    very nice!
