Making Liquid Fertilizer From Weeds
44,012
433
91
About: I am a Marine Engineer in the RNZN (41 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
Weeds, we've all got them!
Let's turn them into something useful.
Now I don't like putting weeds into my compost heap as you can end up with them spreading, the alternative is usually to burn them but they are full of nutrients so this is a bit of a waste.
Why not try to recover the nutrients and at the same time render the seeds from the weeds inert.
All you need for this is:-
A Container (in my case I have used a plastic 45 gallon barrel)
Weeds (no shortage of those!)
Water
I have actually looked iat some past I'bles since publishing and refer you to tim_n nettle fertiliser from 2010 i hadn't realised however it does give me the opportunity to enter the REMIX contest :-)
www.instructables.com/id/Nettle-Fertiliser/
Supplies:
Step 1: Gather Your Materials
As I said I used a 45 gallon plastic barrel, found in a skip, originally container for mortar plasticiser.
I have a large garden so wanted a big container, if you want to make less then use a smaller one
I washed the barrel out just to make sure there were no nasties in it
The Weeds, try to find deep rooted stuff, thistles are excellent, but also dock, dandelions etc - dig the whole thing out including the tap root
You can also use other deep rooted "non weed" plants like Comfrey
Step 2: Fill the Barrel and Add Water
Top up the barrel with weeds and fill with water
Cover and leave for 2 weeks minimum
Step 3: Mmmmmmmmmm Stinky
After 2 weeks you end up with this slightly smelly tea (or soup), the smell isn't too bad - you wouldn't want it in your house but it is fine a few yards away!
Water this soup down 15 to 1 and then water on your plants about once a week
Top the barrel back up when you have finished for the day and it will be back to full strength in a few days
I change out the weeds about every 4-6 months, the old ones are almost completely decomposed and can now go into the compost.
This process releases all the good nutrients into the water so you get the following (amongst others)
Nitrogen
Phosphorous
Potassium
Calcium
Sulphur
Mangenese
Magnesium
etc
I watered my Kumara with this and won the local veg competition with a 1.6kg specimen (See Photo!), it also did wonders for my citrus trees, which were spindly and lacking and now are big and bushy.
Edit
A few people have commented about decomposition of seed heads, I generally get my weeds before they have gone to seed, but if you think that the seed heads may still be viable then I advise you to burn the weeds after you remove them from the soup
Edit 2
I watered my paddocks with this mix at a ratio of 10 to 1 I used approx 7 lires (70 of mixed) for an acre, it promotes grass growth and because the soil is richer the weeds don't seem to like it (I believe they prefer poorer conditions) Once you have sprayed your grass keep livestock off of it for 10 days to allow the grass to grow and any nasties to dissipate. Ideally spray before a rainstorm if possible (or during like I did!! :-( )
I will endeavour to answer all questions, and appreciate the comments and advice received so far
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
91 Discussions
0992948892
Question 6 weeks ago on Step 3
1.It is believed that this plant (Comfrey) contains poisonous chemicals called pyrrolizidine alkaloids (PAs), and the leaf, root, and root-like stem (rhizome) are used to make medicine. Cant these poisons not affect our crops?
2.What other weeds can make a good liquid manure using this method?
buck22170992948892
Answer 13 days ago
Also for info we have our soil tested and have recently been awarded an organic produce certificate, our veges were tested and had less than one percent of the contamination levels of shop bought
Also just about any weeds(or plants ) will do, I just topped up with the end of season tomato plants and potato tops as part of the nightshade family I couldn't give them to the goats
buck22170992948892
Answer 13 days ago
Sorry didn't see your question until today, the natural poisons in most plants will break down very quickly to their constituents in the water
weedguy
Question 15 days ago
Can I put poisonous/noxious plants into weed bucket to use on vegetables?
Joseph
1 answer
buck2217weedguy
Answer 13 days ago
Absolutely, the natural toxins in so called poisonous plants like nightshade, comfort, nettles etc Wil break down in the "tea " to their constituents
LadyMoon
2 years ago
I used a tall trash can with a tight fitting lid, installed a faucet 3 inches from the bottom, put a round paver in the botton, set a plastic milk crate on the paver and put in a mesh bag for the weeds. I can get the tea without opening the lid and I can add weeds as I get them
davidj31
3 years ago on Introduction
I made it but no image yet.
Cut top off a plastic 15 gallon drum. Threw in weeds I had pulled just 2 days before reading this instruct. Filled with enough water to cover weeds, placed brick on top to keep 'em submerged. Smell is something else, can't keep it in the garage so it sits outside. I'm hoping the seeds compost and will find out in a few months.
buck2217davidj31
Reply 3 years ago on Introduction
Cool, put some plastic or tin (or even cardboard) over the top and the smell will be contained
Berkana
3 years ago on Step 3
I have some suggestions based on my knowledge of the biology of compost and some of the processes involved.
The stinky odor comes from rot and anaerobic fermentation, and is not a good thing, and our recognition of the stench warns us of this. Methane is also released by this kind of fermentation, and the methane is a pollutant.
The benefits from the weed material can be gained without the stench by using other bacteria to break down the material in the form of pickling. If you damp down the weeds, put down a stone or something to weigh down the weeds, and start it with bokashi starter (I'm sure there are instructables on bokashi pre-compost fermentation), you will still break down the weeds and will still have a nutrient rich liquid byproduct, but it will not stink; it will smell like pickles. Essentially speaking, this kind of fermentation forms a sort of sauerkraut out of the weeds, pickling them. When buried in the ground, worms go nuts over pickled plant matter, and will eat it up preferentially, because it is easier for them to digest.
The side benefit of bokashi and lactic acid fermentation (somewhat of a misnomer; lactic acid is not the the only nor even the primary acid that is produced) is that the weak organic acids produced in the process boost the cation exchange capacity of the soil, making it more fertile independently of the nutrient content of the liquid.
Try it out. It's not that different from what you're currently doing, but it will definitely stink less.
ShindouBerkana
Reply 3 years ago on Step 3
Great idea, but I think you have changed the process enough to warrant making your own 'ible. I for one would LOVE to see how to do that entire process end to end.
buck2217Berkana
TBH it is only a mild smell sort of like earthy compost, if it was too "ripe" then I would question it
Spike63
Another point, who wants to waste beer on a garden project? It should be used for keeping the man happy and I don't know anything about that Cola rubbish...
I'm always in awe of people who can find odd things to do with beer, maybe someone can come up with a 'structable to make my day! Apart from making our own, natch!
buck2217Spike63
Beer is for drinking not gardening, a bad beer is better than a good coke!
Spike63
I just pour a little olive oil on the surface, that kills the li'l beggars! Organic if you like...!
buck2217Spike63
If you want to be cheap use any old cooking oil (rather than more expensive olive oil)
rlove4
I do this with Comfrey and Nettle every September and let sit till Spring. Lay out a net, pile up the leaves then roll up or gather the corners and tie with string. Put the bundle in the container of water with one end of the string hanging out the top with a bit wood on, so once a month you can (hold your breath, it stinks) lift the lid and pull the bundle up to the top to keep it all circulating. In Spring it can be lifted out and composted / burnt / binned and leaves the liquor free of solids.
ooohlaa
Hi ... thanx for this. I make compost tea all the time but never thought to use weeds. I use compost from my pile. I carefully cart off weeds to the local recycle station but now I will do it your way. I do get LOTS of mosquitoes, they love compost moisture, even with a lid on. Do you have any skeeter problems? I added some kitchen soap to the water to kill the larvae but not crazy about doing that. Here in Fl all insects are legion!
namoraooohlaa
Instructables has offered several effective mosquito traps that may prove useful for you.
