Making a Lightning Necklace by Using Recycle Materials
1,260
8
6
About: Make something. #maker #diy #coder #crafter #WearableTech #Lilypad ❤
Hi all,
About one month ago, I bought some affordable LED strip lights from Bangood.com. You can see that the LED strip lights are used in interior/exterior designs of the house/garden etc.
I’ve decided to make a light up necklace for when the new year is coming. It’s easy to make. It doesn’t require advanced electronics knowledge. It really looks nice when you wear it. I also used the plastic package which is wrapped around the products to prevent them from damage when i make the necklace. You can leave a comment if you use them in a different way.
Supplies:
Step 1: Required Materials
Let’s start ! We will use a little lenght of the strip leds. You can make different projects with the rest of the strip.:)
Step 2:
  • Cut the LED strip lights with enough lenght.(You can wrap it around your necklace and then measure the lenght of the strip.) It has already a sign on the strip leds saying where to cut it.
Step 3: Designing the Necklace
  • Cut the length of the protective plastic cover with the same lenght as the LED strip lights
  • Then stick the LED strip lights on the protective plastic cover.
  • Cover the LED strip lights with the protective plastic cover and sew or silicone it.
Step 4: Soldering Operations
It's time to power the LED strip lights.
  • Solder the 9V battery head to the LED strip lights. The red cable represents "+" and the black one represents "-".
Step 5: Final Step
Finally, we stickt the hook&loop tape on both ends of the necklace. Our lightning necklace is ready ! We can wear it !
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    6 Discussions
    Tinkerer1351
    6 months ago
    To gm280 Highly unlikely and even then little harm will be done, maybe the foam may smell a little ;-o !
    I like the effect but would have used the silicone covered type of LED strip, less likely to heat up the foam and stick to things and spreads the light more evenly but all in all Nice!!!
    PKamu
    6 months ago
    Nice idea!
    gm280
    6 months ago
    Interesting look. Just hope the batteries don't short out.
    hilalgungorgm280
    Reply 6 months ago
    Thanks for comment. Just wondering why do you think the batteries short out? (i covered up the connections with the electrical tape)
    gm280hilalgungor
    Reply 6 months ago
    Batteries can just short internally, not that your design is unsafe. Lithium Ion batteries do it a lot. And even though your are not using those types, any battery can internally short.
    hilalgungorgm280
    Reply 6 months ago
    Okay, thank you for feedback ! :)
