Making a Wooden Lathe Faceplate the Easy Way
1,826
16
4
About: Retired Boat builder,CNC programmer,Process Engineer
Making a wooden face plate the easy way,
I started by drilling a 17mm hole through a block of beach and cutting a tread in it with a steel tap ,
I started the tapping on the drill press to make sure it was all at 90 degrees
Supplies:
Step 1: Tapping a Screw Thread
I re-enforced the threads with liquid superglue and re tapped the thread.
Step 2: Turning the Face Plate
I took the corners off the threaded blank then I screwed the blank onto the headstock I shaped the faceplate on the lathe.
I needed a disc to glue on the front and I turned disc on my router table by spinning it. Then i glued the disc onto the turned part by pressing it on with my tailstock.
Check out my Instructable and a youtube video on making discs on the router table
Step 3: The Finished Faceplate
I cut a nut in half for clearance for the headstock and then screwed the finished faceplate on the lathe.
Check out my youtube video for a more comprehensive view of the build.
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    4 Discussions
    MrHermito
    3 years ago
    This*?
    I understand how to make it I just don't really know what it's used for.
    marcello bianchiMrHermito
    Reply 3 years ago
    I made a 12inch disc sander for my lathe as an attachment and i used my stock metal faceplate so that left me without a face plate to use so I made a wooden one to replace it ,also it can be used to turn bowl by screwing the black to it.
    please check out the disc sander in another of my instructables
    MrHermitomarcello bianchi
    Reply 3 years ago
    Lol ok, I see now, I was just confused but now I know, thanks for the answer
    MrHermito
    3 years ago
    Sorry for being so ignorant, but what do you do with thi?
