Making a Cyclone Chip Separator for a Dust Collector
352,312
451
29
A dust collector should be one of the first major purchases for any woodworking shop.  Not only do they help keep things clean and tidy, they also protect your lungs from harmful airborne dust.  A dust collector is only as good as it's filter, and as filters fill up with dust it reduces airflow and efficiency.  One way to reduce this is to create a chip separating baffle, which collects most of the debris in a trash can before it reaches the filter.  This instructable will show how I created a chip separator for my dust collector.
Step 1: The Dust Collector
Being on a tight budget, I chose the 2hp model from Harbor Freight.  I waited until it was on sale, and then used a 20% off coupon making the total price around $165 with tax.  I think the 2hp rating is a little overly generous, but it still can't be beat for the money.  The filter that comes with it only filters down to 5 microns, which means it won't collect the dust that is most harmful to your lungs.  Rather than spend a bunch of money on an aftermarket filter, I decided to vent my system outside, eliminating the filter completely.  I highly reccomend this approach if you're able to.
Step 2: The Recepticle
I buy used plastic drums for use as trash cans and storage containers in my shop.  They are easily found for little or no money, lightweight, durable, and come in a variety of sizes.  I chose a large 60 gal size so that I wouldn't need to empty it as often.  I also used a white one, as they are semi-transparent, and I can see how full it is without having to remove the baffle and look inside.  Most of these drums have a solid top with two 2" bungs, so you'll have to cut the top off with a jigsaw or reciprocating saw.  You might get lucky and find one of the removeable top varieties.  It's generally a good idea to make sure the drum didn't contain anything toxic before you start cutting into it.  The ones I buy are were all previously used for transporting and storing food goods, but I still give them a good rinse before doing anything with them.
Step 3: Taking Apart the Dust Collector
When I first bought the dust collector, I assembled it in the standard configuration so that I could test it, and compare the results to my finished product.  I then of course had to take it all apart.  The only pieces we'll need are the motor and fan assembly, the center ring, the hose, and the fittings.  You can skip this step if you're buying a new un-assembled unit.  Most of the excess parts went into the scrap pile, but the casters were actually pretty nice quality, so I think they will go under a new rolling tool cart I plan to make in the near future.  The center ring has 6 holes in it where the supports bolt on.  I simply used the bolts to plug these holes.
Step 4: The Baffle Concept
The baffle is modeled after the design Phil Thien came up with to increase the efficiency of his shop vac.  This design has been used and modified by many people with great results, so I figured it would be a good place to start.  He has a great website showing his final design, along with other great information-  www.cgallery.com/jpthien/cy.htm
 His design puts the baffle under the lid, and it fits down into the recepticle.  This would be a little tricky for my plastic barrel trash can, as the sides are convex.  I thought that the center ring of the dust collector would make a great housing for the baffle, especially since it already has a lateral inlet.  It also has a cone inside that is intended to keep chips down in the bag with the stock set-up, which should only help with keeping the cyclonic action going.  The other advantage this has is that it allows me to use the full capacity of my trash barrel.
My idea was to create a disc that would fit on top of the trash barrel, and that the center ring would then fit on top of.  There would be a channel cut out of the disc near the perimeter of the barrel 2/3 of the way around, emmulating the Phil Thien design.  A second disc would then be fitted on top of the center ring, and the blower could then be mounted on top.
Step 5: Making the Bottom Disc
After looking around my shop for a suitable material, I found some scraps of 1/2" MDF.  I thought it might be a little thin and flimsy, but I had enough to make two pieces that I could later laminate together to form a 1" thick piece.  I used my router circle cutting jig to cut two pieces a little larger than than the trash barrel.  I then used a round nose router bit to route a groove in the bottom piece that would accept the top of the barrel.  The barrels aren't perfectly round, so I sorted through the 5 I had, and chose the one that was roundest.  I then routed another groove in the top piece to accept the bottom of the center ring.  With both pieces milled to shape and size, I then glued and nailed them together, making sure not to nail near the area where the channel will be cut.
With the grooves cut, and everything test fit sastisfactorily, I then marked out the channel.  The Thien design uses a 1 1/8" wide slot that runs 2/3 of the way around, but it is designed for use with a shop vac, and a smaller diameter trash can.  I wasn't sure how the lower static lift and higher airflow of a dust collector would effect the design.  I had a suspicion that mine would need to be larger, but I decided to use 1 1/8" to start with, so that I could enlarge it slightly later if I felt it needed it.  I drilled 1 1/8" holes at each end of the channel, and then used a jigsaw to cut the rest out.  I could have use my circle cutting jig again to make a perfect arc, but I would have had to make several passes to cut the full 1" depth, and the jigsaw just seemed quicker and easier at the time.  Since I want the chips and dust to fall into the barrel, but not come back out, I used some sandpaper by hand to slightly round over the top edges of the channel.
Step 6: Making the Top Disc
For the top disc, I found some scraps of 5/8" OSB.  Once again I decided to laminate two pieces together for added thickness and strength.  Just like the bottom disc, I used a roundnose router bit to form a groove that would fit on top of the center ring.  The scraps I had were just barely large enough to cover the ring, and as you can see in the pic, it barely had room for the groove.  I then measured the inlet of the fan housing, and cut a hole in the center that would fit snugly.  I noticed that the square outlet on the fan housing was preventing it from seating fully, so I notched the top of the disc.  I tested it to make sure it was a nice flush fit, and then used some construction glue to attatch the upper disc to the fan housing, creating an airtight seal.
Step 7: Creating the Gaskets
Being that the barrel and center ring aren't perfectly round, and it needs to be close to an airtight seal, I wanted to form some sort of gasket where everything fit together.  I decided to lay a bead of silicone caulk in each of the three grooves I had routed, and then used my finger to smooth them into a convex shape that would help contour to the mating parts.  This creates a flexible and airtight seal.  The silicone takes 24 hours to fully cure.
Step 8: Assembly
After letting the silicone cure, I put everything together.  One of the reasons I didn't attatch the center ring to the base disc is that I want to get the alignment right first.  I placed the bottom disc on the barrel, and then placed the center ring on top of the disc.  I put the inlet of the ring in place above the solid portion, emmulating the Thien design.  I just guessed at proper placement, and then made temporary reference marks on the outside of the center ring and disc.  This way I have a starting point, and can adjust the alignment in either direction to get maximum perfomance.  Once I get it tuned up, I can make permanent reference marks or even attatch it permanently so that it's perfectly aligned every time.
Then I mounted the top disc with the fan and motor assembly.  I used the short length of flexible hose that came with the dust collector as a vent.  I wasn't comfortable installing it permanently just yet, so I just ran the vent hose out the nearby window for now.  I plan on using a dryer vent for the final permanent installation.
Step 9: Flipping the Switch
Because the motor is now on it's side, the on/off switch is now upside down and on the back side of the unit.  I simply removed the switch box, and rotated it 180 degrees, so that it's now right side up and facing the right direction.  The only modification required was to drill a new hole in the mounting plate for the wires that run from the switch into the motor.
Step 10: Testing It Out
I hooked up a length of hose and ran a few tests with some of the machines in my shop.  I ran a few boards through the planer, the jointer, and the tablesaw.  The airflow and collection seem to be as good if not better than the stock set-up.  I then had a helper stick the hose straight into a large pile to sawdust while I watched the exhaust outside.  There was a visible amount of fine dust coming out, but it was surprisingly small.  All of the chips, and the vast majority of dust were collected in the barrel.
After a minor adjustment to the inlet alignment, and enlarging the slot to 1 1/4", I was able to improve the performance even more.  During most normal operations there is so little dust being exhausted that it can't be seen with the naked eye.  Sucking up a large pile of dust, or taking heavy passes with the jointer or router table will create enough fines that the exhaust is visible, but just barely.  So far I've filled the barrel just over 3/4 full, and there doesn't seem to be any scrubbing or loss of airflow so far.
I currently have most of my equipment on wheels, and they are all set up at the same height in order to use the same outfeed table behind my tablesaw for everything. This makes it practical to install the dust collector near the outfeed table, and just use one 10' flex hose for everything.  I may install permanent ducts sometime in the future if I ever expand my shop, but this set-up seems to work well for now.  The only machine the hose doesn't reach is my bandsaw, but it doesn't create much dust, and I think the higher static lift of my shop vac works better for my bandsaws dust hood set-up.
I made a few modifications to my contractor style tablesaw in order to get more efficient dust collection with the new set-up.  I used a piece of hardboard with magnets to form an enclosure for the back of the saw.  I also used some magnetic sheet material (old car magnets) to reduce the gaps between the frame and the table top, as well as the slot on the front of the saw.  These can all be easily moved for making bevel cuts.  The last modification was to drill a hole in the ZCI just behind the blade to help reduce above the table dust.  This has reduced above table dust by about half.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    29 Discussions
    natedgreat
    3 years ago
    Everyone who is venting outside, where are you getting your make up air? I want to vent outside via laundry vent but am stuck on the make up air part. Just curious what others have done.
    Project Lemming
    3 years ago
    I like your project and want to build one. Does it matter which way the cyclone spins?
    arvevans
    3 years ago
    Interesting that this project is being shown now as if it were a new instructable, but some of the comments are 6 years old. Must be a rerun of something that is old.
    Dark Solararvevans
    Reply 3 years ago
    Yeah, the newletter's servings of DIY are kind of like reaching into an extemporaneous grab-bag full of magic 8-balls.
    Still a good mod though. :D
    tructable
    3 years ago
    Yes, yes and more yes! Nice job. A couple of thoughts for those considering building one for themselves. First: Stop wasting your time with jigsaws and such. Take an hour or two and make a router circle cutting jig. Just do it. You'll live happily ever after. Second: I have the Grizzly equivalent of the 2hp collector mentioned here. It is surprisingly quiet and powerful. Other smaller units are screamers and who needs that?
    DDW_OR
    Reply 3 years ago
    nice concept, if you add a flash back preventer. you want to heat, not explode.
    DDW_OR
    3 years ago
    maybe add a LED night light to shine into the barrow to help monitor dust level.
    I cut the lid off, then flipped the lid. the lid has two holes, one with plastic thread that i do not use, the other has pipe thread that i use for dust-in.
    I then screw in an adapter in both sides of the dust-in.
    http://www.homedepot.com/p/Carlon-2-in-Non-Metalli...
    then i use a PVC 2 inch end cap and a short piece of 2 inch pipe.
    then using a hole saw i cut a 2.25 inch hole in the end cap to make an adapter to the shop vac hose.
    i probably should make an instructable on how to make this.
    for now the sequence of parts is this:
    saw, shop vac hose, 2 inch end cap, short pipe, adapter, lid, adapter, street 90. angle the street 09 to throw the sawdust to the barrow wall.
    the the suction hose is attached to the center of the lid by drilling a 2.25 inch hole with the hole saw.
    will be making a LARGER version of this. something i can use my tractor to move and dump. the 55 gallon barrow i am using fills up in 2 hours.
    Kreat0r
    3 years ago
    very good and useful project. i ll be making one soon for my workshop.Thanks!
    DejayRezme
    3 years ago
    "Being on a tight budget, I chose the 2hp model from Harbor Freight."
    Sorry but what is it that you bought there in the first/second step? Cheers
    KentDejayRezme
    Reply 3 years ago
    He means this one:
    http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html
    KellyCraig
    3 years ago
    Keep in mind that adding a means of dumping out most the dust and debris means those things aren't going through your impeller.
    I use a Super Dust Deputy on a thirty gallon barrel and it allows me to vacuum leaves and cones from my yard without beating on the impeller of the little one horse I bought for that purpose (it's dedicated to my miter when it's not doing yard duty).
    KellyCraig
    3 years ago
    Adding a cyclone or other means of removing most the dust and debris before it gets to your filter is an excellent investment. However, adding a Thein baffle, a cyclone or other means of spinning out debris and such will not change your collector from a dust pump to a hazard free collection system.
    If your stock bag or cartridge filter isn't capable of trapping one micron or, preferably, smaller particles, consider upgrading, as soon as possible. There are many after market suppliers who can sell you quality bags.
    If your lower collection bag, or bags are material, you can cut costs by replacing them with [a] clear plastic one(s). Then you only have to put the money out for a better quality upper bag.
    still_alive
    5 years ago on Introduction
    very good idea first off! am building one now. ?. did u finally use 4" or five inch hoses for inlet an venting? also, how long was vent to outside?
    thanks, mike l.
    vtxmanmike
    Are you still running this setup? I have an old Grizzly single stage DC that looks just like yours. I think mine is a 1.5hp, 240 volt unit rated at 1150cfm. Mine blows a lot of dust out of the top filter bag. If I convert, I'll still be exhausting into the room, so I'll have to adapt some filter bag anyway. I built a simple cyclone in front of the DC. It does a nice job of catching the bigger stuff but the bag on the DC still fills with shavings.
    Please comment as I'm ready to make a change to my DC now!
    Thanks, Michael
    mcheung
    7 years ago on Step 7
    Did you find a need to add any pipe extension to the blower inlet so it sticks down closer to the baffle top?
    mcheung
    7 years ago on Introduction
    Really glad to find this write up. I've just bought the HF DC, and was planning a much more complex build with a large cone. My workshop is on the 4th floor of an industrial loft building right up against the freeway, so I'll be venting outside as well. Good to know the simpler Thien baffle will separate enough that chips are not making it through to the other side.
    tlott
    I just built a version of this, but decided to do the chip separator without the ring on it ( I needed the ring to put a bag on because I don't have the option of venting outside.) Anyhow, I spent a couple of days on this and found, to my frustration that the airflow was EXTREMELY reduced by the addition of a barrel, so much so that the bag on the collector would not even inflate, and I'm using the same model Harbor Freight Collector. A couple of days and about 30 bucks in materials later, I would caution persons against this project.... unless you are prepared to lose about 1/3 to 1/2 of your collectors power.
