Making an Off Road Trailer.
35,482
197
19
About: Nothing to see here, move along, move along.
The wife and I wanted to have an off road capable trailer. Since we have the capabilities we decided it would be a cheaper and more robust option for us to build it our self. Many people decide to take a cargo trailer and modify it for off road use but we decided to build one from the ground up.
I am going to have most of this instructable from the point of us working on the project, its a custom job for our needs your needs may differ, what I am showing is one of many ways to go about making this project.
I did make a build log of the trailer as it was under construction you can find it |here|, note it is not a how-to but how I did most of the work.
Supplies:
Step 1: Deciding to Buy or Build Your Own Trailer.
Do you even need a trailer?
This was the first question we asked our self and the answer was no, but we would like a trailer as it would allow us to pack all of our camping gear and spare parts in the trailer allowing us to keep the vehicle near empty this would be safer for us as there are less things in the cab that can come free and hit you and it would make setting up camp much faster as it is already set for us.
Do you buy or build?
We looked around at several companies from pop up campers to specialty utility trailers. Often the cost got us to around half the cost of the FJ and there were compromises as it wasn't our plan but someone else's. We also couldn't justify a dedicated camper trailer as we have a 2 car garage and we couldn't see us using half of it for something that can't hold cargo if we need to use it like a truck bed. This all pushed us to build our own trailer.
What do you want it to do?
Sounds simple, drag behind and camp in. Well, it gets more complex, we never used a trailer to camp in and you can see in the pictures we originally came up with a hatch style system to access everything in the bed. We decided to make the trailer in 2 phases.
Phase 1 was to make the trailer as a 4'x6' truck bed.
Phase 2 to put a lid on it.
We decided this as we really don't know what we would need if our cargo happens to be 30" square and the hatches we made were 28" so we decided to make the trailer and see how we use it before moving to phase 2.
How big of a trailer?
You can find examples of trailers that are less than 4'x4' with small tires up to 30' dual axle monsters. We wanted a trailer that would hold about a truckload of gear, use the same wheels and tires as the tow rig and have a rack on the top to hold a tent. This got us to a trailer about 12' long with a 4'x6' box and sat about the same height as the truck. We also didn't want to have the trailer stick up above the vehicle so we picked out a tent we wanted and made sure the top was about the same height as the vehicle.
Step 2: Going to Build... Start With a Plan.
You need to have a plan.
I have a degree in engineering and access to Autodesk Inventor so I went to town on the plan. I have seen people build a trailer off not much more than pencil sketch on some scrap paper and do just fine. I was able to design it to know the approx weight and weight loading of the trailer. Once you figure out what your going to build your trailer out of there are many many websites that tell you how much metal shapes weight per linear foot, so you can do this by hand. Its not impossible.
Plan for safety.
Trailers are simple tools provided you do 2 things.
1. Have proper frame strength.
If the frame is too weak you will have the tongue bend and fail. The center spar of my frame is 2 1/2" square by 1/4" thick, the rest of the trailer is 2" square by 1/8" thk. You also have to make sure the trailer doesn't weight too much.
2. Have proper tongue loading.
A vehicle can only take so much load on the ball of the hitch and if a trailer doesn't have enough weight forward of the axle it looses stability. Trailers can be designed correctly and still packed wrong so this rule is something you need to keep in your head the whole time.
I used a PDF from Dexter Axle on how to place an axle you can find it |here|
License the trailer.
Take a look at your state/local government's laws for trailers. In TX I was able to licences this trailer as a equipment trailer as it was under the weight and not technically designed as an RV. For this I just went up to the county office and filled out a piece of paperwork and got some plates that day, the trailer wasn't even done yet, no inspection.
Still need to keep it legal.
Once again take a look at your local laws, in TX for the weight I didn't need trailer brakes but I still needed rear lights, license plate light and reflectors.
Step 3: Start From the Ground Up.
The hitch
There is more than just a ball hitch out there. The ball is the cheapest and should get you most places just fine but we chose to go with an AT max coupler, it is designed to have no binding that a ball does. The coupler is also designed to go into a 2" receiver on both sides, this is one of the reasons we chose to have the center spar be 2 1/2" x 1/4" square tube.
Build a solid base.
Everything is built off the frame of the trailer this means the simplest looking part is really the most critical. It needs to be square and strong. If this is wrong everything else will be wrong. I took my time on this part and even cut it apart and restarted on it because it wasn't good enough.
Don't trust your concrete floor to be level, unless your building on a specialized table or planed floor your going to have an un level floor. I thought on for this project I would be ok but it was over 1/4" twisted. I had to cut my tack welds and re check with a level. It was worth it.
Step 4: Build the Tongue.
Critical point!
This doesn't look to be a critical point, its just a piece of metal that sticks out of a box. Well it takes the weight load of the trailer and connects it to your vehicle. If all your connections are in line they will be in a high risk of cracking and if it is made too short you can run it to issues of turning.
Strong strong strong.
This part is the last section of the trailer that needs to be strong as you can be. The area from the cargo box to the ball can be the weakest area. Even when not being towed the tongue takes the weight as the ball jack is on the front of the trailer. The tongue never takes a break.
If you noticed on the last step I made the frame stick out past the farthest up cross members. I did this so I can can trim them down and weld along it so the weld is diagonal to the load it will see. It is a simple thing to do but something you need to plan for.
Step 5: Capping the Tongue
A bit more beef since we plan on throwing around the trailer.
We decided to take a 2"x1/4" flat bar and plate the ends. We opted to wrap the corner to act as a bit more protection in case we run the trailer into rocks and trees. This also helps beef up that welded location as is spreads out the connection point.
Got to make a bent part with a welder "minimal" tools.
I don't have a proper way to bend metal, I don't have a torch or press but I do have an angle grinder, table vise, welder and a hammer. I scored the plate where I want to bend, clamped it to the vice and hit it with the hammer until I got the shape I wanted. Lined it up with the frame and trimmed the frame to fit the plate just right and welded it in. I also then went back and welded the score line, this puts metal back that I cut out and the heat helps relieve some stresses from cold forming the metal.
Step 6: Installing the Axle
This step is relatively easy. If you follow the PDF I linked at the earlier, once again its |here|. They do a good job on telling you where to place your axle, if you are doing this in a very manual fashion you might want to hold off until later so you can balance the trailer to find out the best location of the axle.
The devil is in the details. I wanted to use the same wheels and tires as the tow rig. In this case its a 2013 FJ Cruiser. I didn't think about the studs being metric or SAE. I figured I could just get some SAE nuts that fit the wheels. That wasn't true, the nuts for the wheels only come in metric so I had to buy a metric spacer to act as an adapter to fit my wheels.
Step 7: Finish Up Any Work You Want Done on the Bottom of the Trailer While You Can.
This isn't 100% true, you can still do work on the bottom of the trailer but its easiest to do right now. I decided to gusset the cross member that lines up with the spring hangers.
Step 8: Install the Uprights
Time to start building the functional trailer parts!
Instead of building panels and trying to get them to match perfectly I opted to build a skeleton then later come back and skin it. Since the skeleton isn't taking a huge amount of load I made it out of 1 1/4" square by 1/8" thk. I tacked most of the frame together then came back and seal welded it.
The top of the trailer has a ladder type rack to hold the roof top tent we will be installing.
Step 9: Getting Use Out of Empty Space
Use the space you have don't let it go to waste.
Many people install a tongue box, we opted to put space for, four (4) gas cans, this helped move weight forward and it is out of the cargo area so it is not likely to get damaged by anything moving around in the cargo bed.
Step 10: Skinning the Trailer
I used, I believe, 10 guage (.120" thk) steel for the base and 14 or so for the walls. I had the parts cut and bent by a metal supplier before they arrived to me. I made sure to make them a bit long so I would weld the rounded edge of the square to the plate then grind them down flush. I also fully seal welded the bottom plate and it took forever, and it was done below the trailer, like I said earlier, its possible just not easy. The sides were only welded on the tops and sides. This allows any moisture that gets trapped to fall out.
Welding this much sheet metal took a while and required a lot of tacks to keep the metal from wanting to curl flex. Many people opt to screw sheets on and its a sound method. We opted to weld so there is no chance of screws working loose.
Step 11: More Detail Work
Fenders, spare tire and light pods were installed.
Fenders
Fenders I had subbed out but and cut the exact same then I came back and timed them to fit where they were needed. They also got 1 1/4" square framing along the leading and trailing edge to give them strength to take a hit. The fenders are also 12+ inches deep and flat to act as a table.
Spare tire
A spare tire was added to front of the trailer, this keeps the spare out of the cargo, protects the gas tanks and helps keep that weight forward.
Lights!
We purchased lights that were both brake, turn signal and running lights. Kept the wiring down and fewer holes to drill. The "pod" they are in is designed to once again take a hit and deflect it, that is why the leading edge has a taper to them. When I welded them on to the trailer I welded the top, sides and only the first few inches of the bottom so if water does get in it can fall out.
Wiring
I had to get wire from the front of the trailer to the back. We decided to keep it exposed but inside the bed of the trailer. We used some 1" angle and drilled matching holes on it to loop wire ties to it. This kept it exposed so if for some reason we needed to we can get to it but protected since its inside the trailer and high.
Rear drop legs
If the trailer is not on attached to a vehicle there is a real risk of the trailer tipping backwards if unloaded. Something you do not want if your in a tent on top of it. We installed 2 drop legs behind the fenders. These 2 legs with the front jack make the trailer into a stable tripod when camping.
Rounded edges
At this time we went around the trailer and cut off any sharp edges and round them.
Step 12: Rear Door
Plan your door.
This can be as complex or easy as you want. Some people even opt to have no rear door if its an exposed bed like ours. We wanted the door to slope to give us some more room with out killing departure angles. The latch is a bought out item and there is one on either side behind the light pods protecting them. The hinge is a 36" stainless steel piano hinge, supper beefy and simple at the same time.
Getting the most out of our door.
This gives us a few cool things we can do with the door:
- A small area to put chairs and commonly accessed items.
- Folded down the door acts as a step or seat.
- If placed half way down we now have a full 4'x8' working bed.
Step 13: Paint and Fabric
Paint
If you haven't noticed the trailer already had rust on it before I even stated building it. Lots of people rattle can their trailers I choose to powder coat the whole trailer. Very rugged but not cheap.
The inside of the trailer got a roll on bed liner along with some logistics track to hold all my stuff down.
Fabric bits
After it came back from the powdercoat I installed the tent and awing. The awning has a clip that was welded before hand onto the trailer.
Step 14: Camping Time
Metalworking Contest
Grand Prize in the
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    19 Discussions
    BenJ38
    4 months ago
    Very nice build, but it seems awfully overbuilt (1/4 inch material) and subsequently heavier than it needs to be for such a small trailer with such a small load potential. What was your max load goal, and how much weight did you think the tongue would have to support given that the tongue should support 9-15 percent of the gross trailer weight? Did you use a 2000lb or 3500lb axle? Thanks! I enjoyed the article, and enjoyed the pictures.
    PliskinAJBenJ38
    Reply 4 months ago
    The center spar is 2.5 by 1/4thk square tube the rest of it is 1/8" thk, the max load goal was ~1 ton and the trailer weighs around 1,100 lbs. Normally I have sub 1k of payload in the trailer but utility wise I have loaded it with rocks before.
    The axle was a 3500 lb axle I just changed it out for a 5200 yesterday as I managed to bend the 3500 due to the 2" of up travel I had in the springs before the axle hit the frame. I now under hung the axle and have ~5" of travel. I didn't think I would have needed that much travel but I have launched the trailer airborne a few times on dirt roads while traveling at speed. I don't feel it in the FJ due to higher end suspension but hopefully, this will fix it.
    Tounge weight is 300-400 lbs when loaded.
    49348579_10101024042767440_235752842231545856_o.jpg49836994_10101024043036900_3904485422251638784_n.jpg
    ntsoom
    7 months ago
    voted .. good luck
    TXpeditionO
    8 months ago on Step 14
    You should take this out and test it in Big Bend! ;)
    Great write up. With as much effort as you put into this, you deserve the win!
    gralan
    8 months ago
    Smart, clean, as well as a great instructable. Thank you. _ga-
    LenkaDesign
    8 months ago
    Great build! Good luck with the contest!
    PogueMahone1775
    OMG, we are talking some mad skillz here! That is a work of art!
    BigAndRed
    8 months ago
    Nice job, I like that hard top tent. Done some thing like that frame on mine. To cover the sides ive got 4x 40W solar panels to hinge from the frame to charge the fridge battery.
    PliskinAJBigAndRed
    Reply 8 months ago
    I like the idea of that, right now we have a 100w flexible solar panel we strap to the roof of the tent if we are in one spot for a while. We just have a goal zero as a power source to keep it simpple.
    Thorondor95
    Tip 8 months ago
    If you drive something with a rollbar, like a Jeep, then you could park beside the trailer and set up a hammock!
    Lorddrake
    Question 8 months ago
    wow, great job.
    In the intro step your drawing shows that the bed of the trailer is covered, but the final pictures show that the trailer is open.
    1) are you planning to eventually cover the bed of the trailer like it is shown in the intro drawing, or is it going to stay open?
    2) have you had any issues with water (or snow) in the bed of the trailer having the open design?
    PliskinAJLorddrake
    Reply 8 months ago
    1. Short answer no. We toyed with the idea of boxing the whole thing in to be a square drop trailer with the tent on top for the kid but we are probably not going to go that route.
    2. The main reason we aren't going the enclosed route is we have not had any problems with keeping our gear dry. We have been using Ridgid tool boxes (from home depot) and they have been keeping everything out of our gear and its easy to load and unload. You can see them in the last set of pictures. They have been doing a great job and many of our other friends have gotten them to camp with too. We also keep our food in the vehicle so its with us when we decouple the trailer and if we bring the fridge its maintained with the vehicle battery.
    25348362_10100792191703830_4534145389527162601_n.jpg29261064_10100852195845050_6639262328298162720_n.jpg
    LorddrakePliskinAJ
    Reply 8 months ago
    That makes sense.
    The popup tent portion is really interesting, who manufactures it?
    It looks like you have a ladder only on the far side of the tent for getting up and down, (im guessing that there isn't a ladder on the driver's side because the awning) does that cause any issues in the middle of the night?
    PliskinAJLorddrake
    Reply 8 months ago
    The tent is a Autohome Maggiolina Grand Tour Medium, we chose it for speed of setup and take down along with it being a true 4 season tent, and the tent will nearly last forever if you take just basic care of it. We haven't had any issues with getting out of bed, its a relatively small tent so everyone is waking up anyway.
    Lorddrake
    8 months ago
    voted .. good luck
    JustinC282
    8 months ago
    That is freakin awesome. Seems very well made and super capable. I dig the fact it matches the tow rig. I did the same thing with a boat once. Great job
    Gio Maverick
    8 months ago
    What a great idea! I like the fact that the tent is on top of the trailer instead of being on the roof of the car.
