Making an Online Fish Tank Webcam!
49,616
56
39
Step by step guide for modding the case of an IP camera so that it can be attached directly to a Fish Tank.
The reason this is needed is because webcams usually are designed to be put in front of the subject, or need a stand. However with a Fish Tank cam it needs to be hidden away taking up as little room as possible
Step 1: Get Your Parts
1. Get an IP webcam (this means that you dont have to have a PC attached to it to get the images onto the web) The one i chose was an Orite IP cam 200 - you can pick these up for less than £50
2. Get a project box from Maplin/Radio Shack - the one i got cost about £3
Step 2: Take the IP Camera Out of Its Casing
1. Unscrew the two small phillips screws on the underside of the box
2. Pull the box apart
3. Unscrew the final philips screw which attaches the PCB to the case
Thats it, the camera is free!
Step 3: Cut the Project Box
1. Carefully cut a hole in the project box that will take the cable - make sure that it fits nicely and the box closes fully
2. Cut a hole in the front of the box so that the lens can see through it
Note:/ I found that by using a craft knife the font hole was easy enough to make (you do need to be careful though). The wire hole is easily made with a junior hack saw
Step 4: Now Install the Electronics
Fairly self explanitory!
I have used two large lumps of bluetack (you could also use Sugru) to hold the camera in place, this allowed me to adjust its angle inside the case easily
Step 5: Play With the Angle + Then Screw the Top on
This took a while, first of all get the focus correct then keep playing with the angle of the camera until you can see enough of the tank.
Once done attach the box top
Step 6: Firmly Attach It to Your Tank
I used lots of bluetack!
Step 7: View Your Tank on the Web!
Now just port forward your DSL IP address on port 80 to the webcam.
There are lots of other bits to do on this, including the firewall setup, the camera setup, and the webpage (if you want one) etc etc but i havent gone into detail on this project.
Step 8: Update - Wide Angle Lens!
I've found a wideagle lens that fits, i bought this from http://www.maplin.co.uk (Stock code MW64U) for about £13.
This gives a far wider view of the tank.
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    39 Discussions
    King_Juan
    4 months ago
    Nice tetras.
    MasterMediaXD
    10 years ago on Introduction
    I think your web cams are bust! they all are blank I think its like a blacky grey colour! there are 4 people online on your site! and its within 11-9 in the UK I know because I'm from the UK
    billytkidMasterMediaXD
    Hiya, they were sort of - the blue tack was crap so they fell of onto the floor! I've just stuck them back on, so all should be up and running now! Enjoy the fish! ;)
    MasterMediaXDbillytkid
    Yep they're working again its 11:10AM 16th November 2008 exactly and the lights aren't on yet! I can roughly see the fish! tell me from the picture attached are the lights on?
    ha, make one for a fireplace around x-mas time and sell it to ppl with x-mas tunes in the back, u could get rich lol!
    jpldude445
    11 years ago on Step 8
    you should modify this camera by putting plexiglass on the cameras lens and seal around the pprogect box and then stick it inside the tank!
    jmdepch
    11 years ago on Step 4
    I love this kind of hacks like webcams e usb ports
    bobrob5k
    11 years ago on Introduction
    hi all, in ur instructable when u have finished making the webcam u say "There are lots of other bits to do on this, including the firewall setup, the camera setup, and the webpage (if you want one) etc etc but i havent gone into detail on this project." well srry to be a bore and sounding like a real noob but i need that information so if its not too much trouble please could u direct me to somewhere where i can get that information from please cheers
    billytkidbobrob5k
    Reply 11 years ago on Introduction
    Hiya, to be honest in this part of the project there are so many things that can be different depending on the equipment that youve got, but ill try to help!
    1. Setup of the camera - Ive got 2 cameras now but basically you assign the camera an IP address on your LAN. (To check its working put the IP address in you browser and you should be able to see the camera output - nb this will be inside some form of webpage already, which is hosted on the camera).
    2. Once this bit is working you will then need to port forward on your firewall from your external IP to the internal address, i do this on a different port for security reasons. So my outside address for the camera is http://mydslipaddress:8080 this translates to internal IP address port 80 (the camera). Once youve done this get a friend to put your public ip address : 8080 into his browser to see if he can see the camera. This will NOT work from your home network.
    3. Build a nice webpage - For that you need to read a book, or many websites out there. As a simple start use the Lycos Webmonkey (http://www.webmonkey.com/) its a bit old but teaches you the fundamentals.
    4. The iP cam youve got will have a number of options to stream the video, either using the built in web page (boooo, looks crap), or you can take a stream from the page and put it in a nice applet (either Java or Activex), you will see on my site Ive used both so there is browser interoperability). Once you know the options on your cam just embed it into your nice page.
    5. Sit back and see the people who visit!
    I know this isnt enough info to do it, but hopefully enough to get a rough idea.
    Cheers
    Will
    timgautrey
    I have a webcam set up here which I have linked through a dynamic host here
    you will need to log in as fish and password law. Set the refresh rate at 0.1 and enjoy!
    gigman
    12 years ago
    I thought of doing somthing like this with a bird house. But this is really cool! Have you thought of trying attaching one of those cheap $10 wide angle lenses to the camara so you could see more of the tank? Great idea and great instructable!
    billytkidgigman
    Reply 12 years ago
    Hiya, yea I bought a wide angle security door lens and played about with it for a while, but couldnt get the optics right (which is a shame), ill give it another go when ive got some more quiet time! Thanks for the feedback
    codfilletsbillytkid
    Reply 12 years ago
    Nice. Ive thought about doing this but never had the chance. Now that I do, is there a way you can use a standard webcam instead of the ip-webcam? I have a few extra usb webcams and want to use an old IBM laptop I have lying around. Any links or something that would help?
    tomc3ukcodfillets
    You can set Skype to auto answer calls with the webcam on, so all you'd have to do is call the Skype on your laptop from another computer.
    codfillets
    12 years ago
    Is there a way to make this from a non ip-webcam? I have a laptop I would like to hook the usb webcam, any links, suggestions?
