Makramé Flower Hanger
2,418
61
5
This is a beginners guide for creating a simple makramé flower hanger.
Step 1: Collect Your Needed Items
All you need for this project is:
A rope measuring at least 675cm ( 4x150cm 1x75cm)
Scissors
A measuring tape
A jar, pot, vase = flower container
flowers for final decoration
Step 2: Measure Out Your Cords
on a flat surface, measure out 4 cords of 150cm and one cord of 75cm
Step 3: Making the Hook Loop
In order to hang your makramé flower hanger when finished, start to build a loop.
Grab your 4 cords à 150cm as a bundle and fold them in the middle.
Take the 5th cord à 75cm and tie it around the other cords as seen in the picture.
This is the beginning of a covered knot that will create a neat loop hole.
Step 4: Prepare a Covered Knot
Continue to create the covered knot by wrapping the extra cord around the main cords. I chose to wrap the cord 5 times before continuing to tie the covered knot.
Step 5: Tie and Cover the Knot
After wrapping the extra cord around the main cords 5 times, tie the lower end of the wrapping cord through the loop whole created earlier.
Step 6: Finish the Hidden Knot
Cut off the ends of the wrapping cord.
Step 7: First Round of Knots
Lay your cords out flat and build cord couples for first round of knots.
Leave the cord on the outer left and the outer right untouched.
Start with the second and the third cord. Make simple double knots. Continue with the fourth and fifth cord and so on.
Make sure, the knots are created at approximately the same hight.
As a last step of the first round of knots, tie the cord on the outer left and the outer right together.
Step 8: Measure Pot Position
Now find a wall with a hook and hang your makramé project to measure out where the jar needs to be placed.
Make sure the next row of knots is going to sit slightly under the upper rim of the jar.
Step 9: More Rounds of Knots
Now continue tying 3 more rounds of knots.
Make sure to pair the cords asymmetrically per row to gain the needed honeycomb structure that will securely hold your jar.
If your jar is rather small, like the one I used, make sure that in the following three rows the distance of the rows is not very large and does not exceed the total length of the jar.
Step 10: Make a Final Knot
Once you have reached the length of your jar, take all the cords as a bundle and tie a simple knot to seal the makramé holder.
Step 11: Final Decoration
Bravo! Now simply place your jar, arrange your flowers and that's it!
You made it!
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    5 Discussions
    corieltauvus
    2 years ago
    A very nice (and well explained) beginner's project. As an old sailor I made many different articles using decorative knots. However I beg tho point out that the craft is Macrame with an acute accent on the last 'e'. Pronounced mac-ram-eh.
    Apart from it's seafaring origins this was a very popular craft in the 60s and 70s. Nice if it comes back.
    wold630
    2 years ago
    Adorable!
