Manivelle Water Gun
2,504
22
6
About: HMN41 Creations
Manivelle (Crank) Water Gun is a new design of water guns that is characterized by the attractive view and in the fun that is created during water playing. This water gun is a 3D printable object, so in this instructable you will follow the designing of the different parts of the manivelle water gun.
This water gun depends on the circular motion to operate.
Step 1: Designing
Tinkercad is a very easy application to design a 3D printable object.
You can view it on Tinkercad: https://www.tinkercad.com/things/dspXTLUMqDF#
You can view it also on my minifactory: https://www.myminifactory.com/object/3d-print-wate...
In the upcoming step you will use a 3D Printer to print the different parts of the water gun.
Note: In my water gun I print each part separatly and then I gather them up using a glue gun because of the range of printing of my printer.
Step 2: The Fan
Download the file and print it.
Stick this fun in the screw through the center of the base part.
Step 3: The Base
This part where the water circulate to be shoot out.
Step 4: The Cover
This part that covers the the base part of the water gun.
Step 5: The Head
Step 6: The Junction Part
This part that connect the handle with the hole body of the water gun.
Step 7: The Handle
Step 8: The Screw
Note: you can replace the 3D printable screw by a metallic one to maintain the strength and the durability of the water gun.
Step 9: How It Should Be
View this 3D design to gather up the different parts.
Step 10: Gathering
Gather all the parts together by sticking them using a glue gun.
Step 11: The Final View
Step 12: Have Fun !!
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    6 Discussions
    TomL21
    7 months ago on Step 12
    This looks super cool. Can you share more about how it works? How do you load it? How long until you need to reload?
    Hassan NasserTomL21
    Reply 7 months ago
    Thanks,
    It works by putting the base part of the water gun in water(pool,...) and then start to move the crank in a circular motion that pushes the water out, and it doesn't matter about reloading as you setting the base part (where the fan is) in water.
    Vote for me if you like it ⬆️⬆️
