Mason Bee Hive
3,906
62
16
About: I am a business owner. I have been making and building things longer than I can remember. I love to work for fun and work to build the next project. I am a beekeeper. The work involved in that is nothing mor...
I have been into beekeeping for a bit of time now and thought that it would be great to add mason bees to the list. So i sat down and came up with this design for mason bees. Later on in the season I can take out what they seal up for next year and start up with leaf cutter bees.
Step 1: Design & Pre Fitting
Put some time into CAD coming up with a design that would work. I built a inner chamber that I could remove if need be. I made that to fit the 6" length and 5/16" inner diameter cardboard tubes for the bees. I then made a mounting bracket to be drilled to a post. The last part was the top flower pot for the decor look and to have some close pollen. The top flower pot has a 1/4" drainage hole on each side to not over fill and drown the plant. The inner chamber has a drainage ditch angle to flow water straight out the front. I used a piece to duct tape to go over that so that the cardboard tubes will not fall into it nor block water if any were to get inside.
Step 2: Seal & Finish
At this point everything has been fitted and looked great. So I then painted and sealed it. Put in the few cardboard tubes I had that I bought at the 2016 Northwest Flower & Garden Show. After those were put in I fill it up the rest of the way with the empty ones. Got a plant in full bloom to put in the top flower pot.
Step 3: Mounted & Good to Go
Found a good location and screwed the mounting bracket to a post. Kept the plant well watered while waiting for the Mason Bees to hatch. As they did, they started to fill the tubes more and more with eggs. The season is over in my location for Mason Bees. So I have now taken the filled tubes out for next year. Now I can use the same hive for Leaf Cutter Bees. Well I hope that you have enjoyed this and thank you for checking my project out.
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    16 Discussions
    WUVIE
    11 days ago
    I love the look of this bee house. Very nice!
    doncrush
    2 years ago
    so leaf cutter bees use the tubes also? Where are they native?
    Dylan Larsendoncrush
    Reply 2 years ago
    yeah they will. I was hoping to get some this year, but still have gotten around to it. I have seen wild ones around where I live, Washington state. They can be order from all sorts of places online.
    doncrushDylan Larsen
    Reply 2 years ago
    Cool, I might have to get some. I couldn't resist this pun humor from your comment...here is "a round tuit" I 3d print:
    http://www.thingiverse.com/thing:910711
    hdoman
    2 years ago
    How long does it take the mason bees to discover your tubes?
    Dylan Larsenhdoman
    Reply 2 years ago
    I bought a few tubes before hand to start it up. By the end of the season Those 2 tubes filled all of the tubes you are seeing the pictures.
    Carpenter Guy
    2 years ago
    I always wanted to make one of these, but I have never actually done it! Maybe I will now!
    I have ordered them on #amazon and got some from the local co-op. some companies will sell the tubes with eggs loaded good to go. I have seen a lot of of people using different lengths and diameters. If those work I don't know. I know the sizes I got are what most places will say are the best. So I'm sure there would be some wiggle room with it.
