Mason Jar Pipe Lamp
30,734
778
40
About: I like to design and build random things.
This is a fun little project to build out of scrap pipe and an old mason jar. Another option is to buy the parts from the hardware store which should run around $50.
This lamp was built from purchased ½” pipe and fittings. The fittings are generally bagged. The pipe comes with labels glued to the pipe which took a while to get off. I had to use a razor blade and then washed the fittings to remove the excess glue and oil from shipping. I used a 24 oz. mason jar with a wide mouth. The depth was needed to accommodate the length of the compact fluorescent bulb. The wide mouth allowed room to attach the pipe flange.
Video of the Build:
Step 1: Tools
  • Drill and bits
  • Wire cutters
  • Screw driver
Step 2: Materials/Cost
Step 3: Build Per This Drawing
Step 4:
Position and drill a hole in one of the Tee fittings large enough to feed the cord through. I used a ¼” drill.
Step 5:
Drill 5 holes in the mason jar lid. The first will be in the center. It should be large enough to allow the threaded light socket rod to pass through. The other four holes should match the flange mounting holes.
Step 6:
Assemble the bottom section of pipe as shown. I waited to fully tighten the pipes/fittings until the end.
Step 7:
Feed the cord through the Tee fitting. Pull enough to reach the estimated end length (bulb). Be careful to not damage the wire insulation when pulling the wire through the pipe.
Step 8:
Feed the cord through the 12” section of pipe. Screw pipe to bottom section. Repeat this process until you get through the flange.
Step 9: ​Paint
The lamp was painted flat black and Rub 'n Buff added to give it a steampunk look.
Step 10: Lid/Socket Installation
  • Be careful at this point or you will be reassembling the fixture – trust me :). See exploded view for installation order.
  • Feed cord through the rod nut, threaded socket rod, mason jar lid, and socket nut. Push all the parts out of the way so you can attach the wires to the socket.
  • Screw socket rod into socket.
  • Tighten rod nut to secure lid to the socket
  • Attach the flange to the lid using the ¼-20 bolts/nuts. Note that two of the holes are open. This allows for a little ventilation inside the jar.
Step 11:
Add adhesive or a grommet to the cord entrance point (tee fitting). Add inline switch to cord
Step 12:
Add bulb. Note that I’m using a low wattage fluorescent bulb to limit the heat buildup inside the jar. Screw on mason jar.
Step 13: Update
I used a compact florescent bulb to keep the heat dissipation down. However, I'm not a big fan of how it looks in this application. There was a comment on Reddit about this project with a nice suggestion to use an Edison Style LED bulb. The above picture shows an example and here is the link to the product.
Mason Jar Challenge
First Prize in the
Mason Jar Challenge
2 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Gardening Contest
    Gardening Contest
40 Discussions
imphalblue
4 years ago on Introduction
A well thought out, interesting and attractive instructable. This is well worth having a go at. Thank you.
mtairymd
Pics with different color bulbs:
" frameborder="0" allowfullscreen>
the_tool_man
4 years ago
I liked this so much I made my own using a glass insulator for a shade. Thanks for the inspiration.
15, 9:34 PM.jpg
ben.arndt.39
Thanks for some reason i didnt have all steps on the page i was viewing...makes sense!
ben.arndt.39
how did you connect the pipe to the mason jar/light socket...looks like some threaded piece to reduce from the pipe to the threaded nut of the light socket?
mtairymdben.arndt.39
Reply 4 years ago on Introduction
Refer to the exploded view and pictures in Step 10. The flange screws into the pipe. The mason jar lid is attached to the flange with 2 screws/nuts. The socket rod goes through a hole in the center of the lid. The rod nut is attached to the pipe side of the socket rod. The light socket has threads. You will use that thread to attach the socket to the lid. Hope this helps.
morrocoyo
4 years ago
nice!!! great job
jk55092
4 years ago on Step 12
That's gorgeous, but it screams for a vintage Edison-style bulb.
mtairymdjk55092
I agree. However, I wouldn't want to enclose that style bulb in a jar. I do like the vintage bulbs with vintage cages around them.
from what I have read about the florescent bulbs are very sensitive to heat failure when they are confined by glass globes or deep glass fixtures. Have you had any bulb failures?
From CFL Facts and Myths
http://www.cflfacts.com
"Can CFLs be used in totally enclosed fixtures?
Yes, but with some qualifications. The life of CFLs will be reduced if they are operated at higher than normal temperatures. Therefore, they can be used in totally enclosed fixtures, including vapor-tight fixtures, as long as you do not use a high power CFL, and the temperature outside the fixture is not too high. I have successfully used 25-watt CFLs (light output equivalent to 100-watt incandescent lamps) in large vapor tight fixtures, but these lamps were installed in a relatively cool area. If the fixture is small, or if the fixture is installed in areas with high temperature, such as Phoenix, the power rating of the CFLs should be limited to 15 watts or less."
No failures yet. Note that I'm using a light equivalent to a 60-watt incandescent lamp in a cool ambient (68F / 20C). In addition, the jar does have some venting (two 1/4" holes in lid) as stated in step 10.
