Matchbox Ring Organizer
3,155
109
11
Here's a simple ring organizer you can make with things that you most probably have lying around.
You will need...
~A large Match box
~A Piece of thermocol / foam
~Some Fabric
~Rubber bands
~Pins
~Glue
~Craft knife
Supplies:
Step 1: Preparation
To make this ring organizer...
~Cut a piece of thermocol / foam that would fit exactly into the matchbox.
~Cut the fabric to approximately twice the dimensions of the matchbox.
~Mark ring slot on the thermocol as shown in the image.
Step 2: Making the Slits
Using the craft knife, make slits on the thermocol along the lines made, with depth half that of the thermocol piece.
Step 3: Placing the Fabric
~Place the fabric on top of the thermocol piece and pin one ends of the fabric to the back of the thermocol.
~With the back of the knife push the fabric into the slits made starting from the pinned end of the thermocol.
Step 4: Securing the Fabric
~Now, remove the pins from the bottom, apply glue to sides and bottom of the thermocol and secure the fabric onto the thermocol with the rubber band.
Step 5: Finishing
~Apply some glue to the base of the matchbox and place the thermocol into it.
~Let the glue dry and the box is ready for use!
Do leave your comments, questions or suggestions! :)
http://alternatecreations.blogspot.ae/2014/03/matchbox-ring-organizer.html
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    11 Discussions
    Althea MaeH
    3 years ago on Introduction
    could u push stud earrings into foam between the ring slots (like for use as a travel jewelry box)?? I might try it!! (Seeing a I have way to many rings and nowhere to put them.......)
    Wynd
    3 years ago
    Awesome! Was looking for a way to display my mass of rings (I'm a costume ring fanatic) XD
