Meat Patties
3,713
67
21
This is one of the famous snack  that every body likes.It takes a while to make,so I always make a huge amount  and freeze them.
When ever I have guests or  feel like having home made Patties ,I take it out from the freezer  an hour early to defrost. It is already semi fried/semi baked , so that it does not get pasted in the fridge.. Once it is defrosted I fry it over again until golden brown.
If you don't want to fry, you can apply egg yolk on top of the patties and bake them until golden brown.
Baking is much more healthier,but I like it Fried ,as it is much  more tastier.
I am  publishing  with more pictures ,so that every body understands well looking at the pictures alone.
Enjoy with your favourite choice of  Sauce...Super delicious...
Supplies:
Step 1: Ingredients
For the dough
Flour
Butter or Margarine
Salt
Cold Water
Filling
Beef
Potatoes
Onions
Curry leaves
Spring onions
Lime or lemon (option)
Salt
Turmeric Powder
Paprika powder
Ginger
Garlic
Step 2: Making the Dough
1. Shift flour and add 2 or 3 table spoon melted butter or margarine and 1/2 tea spoon salt .
2.  With you fingertips mix the melted butter, flour and salt until the mixture resembles fine sand. Then add cold water  little by    little to make the dough.Do not add too much butter,as it will become very soft.In case you add too much butter or water   don't panic,just  add more flour.
3.With floured hands  mix  and knead well  until it becomes  soft.
4. Make small balls so that it is easy to roll out one by one.Now  set a  side.
Step 3: Making the Filling
1. Cut the beef  in to medium size pieces add salt and turmeric powder.
2.  Pressure cook the beef for few minutes.
3.  Boil the potatoes and cut them in to small cubes.
4. Drain the water off and  chop the beef  also in to small pieces.
5.  Finally chop  the spring onions
Step 4: Cooking the Filling
1. Temper the onions in oil,add garlic paste.
2. Add the ginger paste,cook until golden brown
3. Add the chopped beef ,curry leaves and salt to taste.
4. Add turmeric powder and paprika powder.If you want it hot and spicy  instead of paprika powder add chilli powder and a little curry powder.
5.  Add  the spring onion.
6. Mix well and let it cook on slow fire.
7 Finally add the potatoes and mix well.
8. Let it simmer on slow fire..Add a little more water if needed.The consistency should be thick.Once it is cooked set it a side to cool.
Step 5: Combine Dough and Filling
1.  Lightly dust a clean surface.
2. With clean fingers  roll out the dough one by one until it is 1/8 inch thick.
3.  Lay the rolled flat dough on top of the Patties cutter.
4.   Spoon 2  tablespoons of the filling onto one side of the dough.
5+6 Fold the other half over to make a half-moon, press to seal.
7.  Remove the excess dough which is out side the cutter.
8. Press well so that it gets sealed properly,if not it will open out when frying.
9+10 When you open the cutter ,the Patties can be on to any side you turn to.
11+12 If you do not have a Patties cutter here is another  way to cut the dough with a bottle.
      Press the glass rim on to the rolled dough a bit harder ,  so that it  cuts a shape of a round.Remove the extra dough.
13.  Spoon in the filling  and press the edges together.if your dough is on the dry side you may need to run wet fingers around the edge of the circles to help get a good seal
14. Lightly press a floured fork around the edge of the patties to make ridges.
15. Ready to be fried.
Step 6: Frying
1.  Fry in hot oil.
2.  Transfer it to a sieve so that the excess  oil drips, and then to a tea towel.
3.  You can make a lot at one time and  semi fry  part of it ,cool, and Freeze  them.
4 . A delicious plate of  snack
  called PATTIES
Step 7:
Enjoy with your favourite sauce!
Thanks for reading.
Sharing it with love!!
Note:
I have posted this in the Hurriecane contest too.
I am a day care mom who is working full time,and do not have enough time for my sewing and crafting work which I love it very much.If ever I win the laser cutter I will give up my full time job or reduce it to a couple of hours(because I do a lot of craft work  with the kids and they will be dissapointed to see me no more)and start my own business at  home as I have enough and more sewing orders which I can not do it on time.Every instructable I do with the help of the laser cutter,I will definetly post it on this great site.
Snack Food Contest
Second Prize in the
Snack Food Contest
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    21 Discussions
    zeenahmalhar
    6 years ago on Step 7
    Mmmm ! Very tempting getting hungry looking at it.Hope to make it soon.
    786Ayeshaebend12
    Reply 6 years ago on Introduction
    Yes of course!The filling has to be thick,so that the dough holds it.Do not use meat alone, add some veggies if you don't like potatoes (carrot,leeks also taste good)
    sheroza
    These definitely look delicious! Thanks for sharing!
