Mecanum Wheel Robot - Bluetooth Controlled
50,806
489
47
About: I'm an enthusiast of robotics :)
Since I can remember I always wanted to build a mecanum wheel robot. The mecanum wheel robotic platforms available on the market were a little too expensive for me so I decided to build my robot from scratch.
Like no other robot meacanum wheel robot can move across without any difficulty. This feature makes it unique and allows for easy maneuvering in tight spaces without the need to rotate in place.
Well, it's time to get down to work!
Parts needed in this project:
  1. Arduino Mega 2560 x1
  2. TB6612FNG Dual Motor Driver Carrier x2
  3. HC-06 bluetooth module or similar x1
  4. Breadboard (min size) x1
  5. Li-Po batteries: 7.4V 2200 mAh and 11.1V 2800 mAh x1
  6. SKYRC iMAX B6 Mini battery charger x1
  7. DC motor 12V x4
  8. Mecanum wheel x4
  9. Jumpers and cables
  10. Nuts and bolts
  11. Chassis made of plastic
Step 1: Building Robot Chassis
The first thing to do was to cut a piece of plastic plate (153x260 mm). In the next step I screwed the dc motors placed in a metal tube to the plastic base. Instead of 2 metal tubes you can also use 4 metal holders for dc motors. The last step in robot chassis construction was fitting the wheels.
Step 2: Fitting the Mecanum Wheels
Mecanum wheels should be fitted in the correct way. A correct configuration requires each of four mecanum wheels is set in the way as shown in above picture. The rotation axis of each wheel's top roller should cross the center of the robot chassis (point C).
Step 3: Connection of Electronic Parts
The brain of the system is Arduino Mega 2560. As a motor driver I used two TB6612FNG dual motor driver carriers. This motor controller has sufficient range of acceptable input voltages (4.5V to 13.5V) and continuous output current (1A per channel). Robot is controlled via bluetooth using Android application. In this project I used a popular inexpensive bluetooth module HC-06. The electronic system is equipped with two power sources. One for supplying the DC motors (LiPo battery 11.1V, 1300 mAh) and the other to supply Arduino and bluetooth module (LiPo battery 7.4V, 1800 mAh).
All connections of electronic modules are the following:
  1. Bluetooth (e.g HC-06)-> Arduino Mega 2560
    • TXD - RX1 (19)
    • RXD - TX1 (18)
    • VCC - 5V
    • GND - GND
  2. TB6612FNG Dual Motor Driver -> Arduino Mega 2560
    • RightFrontMotor_PWMA - 2
    • LeftFrontMotor_PWMB - 3
    • RightRearMotor_PWMA - 4
    • LeftRearMotor_PWMB - 5
    • RightFrontMotor_AIN1 - 22
    • RightFrontMotor_AIN2 - 23
    • LeftFrontMotor_BIN1 - 24
    • LeftFrontMotor_BIN2 - 25
    • RightRearMotor_AIN1 - 26
    • RightRearMotor_AIN2 - 27
    • LeftRearMotor_BIN1 - 28
    • LeftRearMotor_BIN2 - 29
    • STBY - Vcc
    • VMOT - motor voltage (4.5 to 13.5 V) - 11.1V from LiPo battery
    • Vcc - logic voltage (2.7 to 5.5) - 5V from Arduino
    • GND - GND
  3. TB6612FNG Dual Motor Driver -> DC Motors
    • MotorDriver1_A01 - RightFrontMotor
    • MotorDriver1_A02 - RightFrontMotor
    • MotorDriver1_B01 - LeftFrontMotor
    • MotorDriver1_B02 - LeftFrontMotor
    • MotorDriver2_A01 - RightRearMotor
    • MotorDriver2_A02 - RightRearMotor
    • MotorDriver2_B01 - LeftRearMotor
    • MotorDriver2_B02 - LeftRearMotor
Step 4: Arduino Mega Code
The full code for this project is available at GitHub: link
The Arduino program checks in the main loop - "void loop()" whether the new command (character) has been sent from Android app via bluetooth. If there is any incoming character from bluetooth serial the program starts execution of "void processInput() " function. Then from this function depending on the character a specific direction control function is called (e.g. for "r" character function "void moveRight(int mspeed)" is called). From a given direction control function each motor is set to the desired speed and direction of rotation by function "void motorControl" so that the robot move in the desired direction.
You can also use my other code example for Arduino Mega 2560 that allows you to control a mecanum wheel robot using voice commands: link. Additionally you will need to download BT Voice Control for Arduino app from Google Play.
Step 5: Control of the Mecanum Wheel Robot
Every mecanum wheel has free rollers, which make a 45 degree angle with the wheel's axis. This wheel design allows robot to move in any direction as shown in above figure. The blue and green arrows show the direction of the friction forces acting on each mecanum wheel. By moving all four wheels in the same direction we can get forward or backward movement. Controlling the two wheels on one diagonal in the same direction and other two wheels in the opposite direction we get sideways movement as shown in the second figure (move right).
You can download my Android app that allows you to control mecanum wheel robot from Google Play: link
How to use the Android app:
  • tap menu button or 3 vertical dots (depending on the version of your Android)
  • select the tab "Connect a device"
  • tap on the "HC-06" tab and after a while you should see the message "Connected to HC-06"
  • after connecting, you can control your robot
  • if you don't see your bluetooth device HC-06 tap "Scan for devices" button
  • on the first use pair your bluetooth devices by entering the default code "1234"
If you would like to see my other projects related to robotics please visit:
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
47 Discussions
Dryroti
Question 24 days ago on Step 5
Hi, I am doing a project with mecanum wheels and have followed your instructions. But could not find your app in playstore. Would you be able to send the app that you use for this project? Thanks in advance.
chancomp007
Question 1 year ago
Hey, I bought the exact dual motor drivers you used in the images and videos. However, they keep frying. I have tried other dual motor drivers, and they fry too. Could I be using motors that draw too much current, or should I use resistors in the circuitry? Anyway, thanks for the cool project idea!
chancomp007
1 year ago
VinceT16
1 year ago
Hei,
Any chance we could use Uno instead of Mega 2560 as micro controller?
Joostvanvliet
2 years ago
Hi, how did you create the Android App? I would like to add some custom buttons. Thanks in advance!
IbM2
2 years ago
hello, how do I run the code on the arduino? please help
maoji321
2 years ago
how i control by robo by my android blue tooth???
do i need any extra app???
csm920325
3 years ago
Hi, I appreciate these tutorial. I tried to connect my smartphone to bluetooth module but there is an error. They said 'read failed, socket might closed or timeout, read ret: -1'. I think I did all the things correctly. How can I connect bluetooth? My phone is galaxys4, android 5 version. Thx for reading
silver_acsm920325
Reply 3 years ago
Hi, tap bluetooth icon (on your phone):
1 Do you see your bluetooth device HC05/06 on the list? If yes tap again on it's name and pair with your phone (type default PIN for your bluetooth module e.g. 1234)
2 If you still can not connect please check settings of your HC05/06 module - especially the baud rate (It should be set to 9600)
3 Make sure that your bluetooth module HC05/06 is compatible with 5V (some modules require 3.3V)
Check out these instructions If you don't know how to do it:
https://www.instructables.com/id/Arduino-AND-Bluetooth-HC-05-Connecting-easily/
https://www.instructables.com/id/AT-command-mode-of...
https://www.instructables.com/id/Modify-The-HC-05-B...
csm920325silver_a
Reply 2 years ago
Thank you So much!!! I Finally solved problem!! Have a great day!!
abakin
3 years ago
Hello, I lloved this project and built it up.But, with vex motors.
It is not working with this code. I searched and found they need frq by 127 instead of 255. I switched the values but still not working.
Is there any way you can help?
silver_aabakin
Reply 3 years ago
setting mspeed=255 means that the motor speed (and voltage) is maximal. By changing this value you change PWM and motor voltage and its speed (e.g. if you set mspeed=127 you will get about two times less output voltage and motor speed). Please make sure that you use two wire DC motors, this example does not work with servos!
WaveB
3 years ago
hi, what are those wires that come from the center hole of the metal tube ? 4 of them are the alimentation for the motors but what are the other wires ? Thanks for the project,it's very interesting :)
silver_aWaveB
Reply 3 years ago
Hi, these are the connectors from encoders - not used in this project
Ashlesh6432
3 years ago
Thanks again i did all the connections but the bluetooth module isn't getting connected to the robot control app
Ashlesh6432
3 years ago
thanks!!
i wanted to ask whether the 5v and the VCC in the circuit are the same.
also how to connect the multiple gnd and vcc to arduino?
can i use the 2 lines in top part of breadboard to connect gnd and vcc, and can i use the 2 gnd in power section of arduino together?
silver_aAshlesh6432
Reply 3 years ago
Yes all VCC = 5V, you can use breadboard to connect all GND and VCC pins (in two separate lines) and then wire single Arduino pin GND with breadboard GND line and single Arduino pin 5V with breadboard 5V(VCC) line.
All Arduino GND pins are connected together so it does not matter whether you use one or more GND pins available on the Arduino board.
