Mega Powerbank for Campers
4,737
93
8
About: radom diy projects
an easy and cheap DIY big powerbank for campers
Step 1: Part List
i use:
* 12v 18Ah Lead Acid Battery
* 10A solar charge controller
* 30w 18v solar panel
* 12-24 to 5v 2,5Ah dc to dc converter
Step 2: Build It
  • put the controller and the 5v converter with hot glue at the top of the battery and connect the wires
    • add a 4 pin connector to plug and unplug the solar panel easily
    • add the usb ports on 5v converter and a connector for 12v output
    Step 3: Connection Diagram
    • add a fuse on the (+) of battery
    • add a switch for the 5v converter and one for 12v if you want
    • add if you want a led dimmer
    do not connect anything direct on the battery if not needed.
    the solar controler have over-charging /over-discharging protection
    Step 4: End..
    now can have energy for days with no sun..
      • Faux-Real Contest
        Faux-Real Contest
      • Paper Contest
        Paper Contest
      • Sweet Treats Challenge
      8 Discussions
      emrude
      1 year ago
      Very nice build. Thanks for the write-up.
      3rdiii
      1 year ago
      How much juice is needed to power a lamp or refrigerator
      bace19783rdiii
      Reply 1 year ago
      for lamps. choose led lamps. very efficient and lot of light
      bace19783rdiii
      Reply 1 year ago
      minimal amount for peltier element style cooler box 40_50wats 12 volt
