Metal Flowers
8,596
220
5
A simple project that does not require a forge as most metal flower projects do
Supplies:
Step 1: Designing
To begin your flower first you have to choose your petal shape as this will dictate the type of flower you will have in the end. I chose a lily but the process is the same for many flowers you might want to try to make
Step 2: Stencil
To help keep your petals uniform it helps to have a stencil. The flower I made needed two sets of petal groups but yours may need more or less depending on your design but when using more then one each layer must be differs to give the flower a "real" look. Draw out your petals on a piece of cardboard or thick paper and cut it our to save for later.
Step 3: Choose Your Metal
When picking a metal for this project you need one that is soft enough to bend by hand or on an anvil if you have one. The best choices are copper (very expensive) or thin gauge steel. I had galvanized steel on hand but if you choose the same beware of fumes as burning galvanized steel fumes can and will kill you.
Step 4: Trace Your Petals and Begin Cutting
Take your stencils and trace your petals onto your metal and then cut it out in any fashion you find easiest (I chose tin snips as I had them easily available) beware the sharp edges that will most likely need to be sanded down
Step 5: Stem and Bending
To build your stem you can use any size round bar you wish and attach both of your petal layers on top of your stem by welding them on. Once the petals are on you can begin to bend them up, this is not exact but try to do what you feel looks natural for a flower
Step 6: Anthers
Anthers on a flower carry the pollen and are a finishing touch for most flowers you will make. I used welding electrodes with the flux coating removed and attached them to the center of the already bent pedals, then I bent the tip over to give it the look I wanted
Step 7: Finishing Touches
I chose to put my flower on a base and later painted it but whatever you choose is up to you.
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    5 Discussions
    joe408911
    4 years ago
    In the case of solder I don't see why you couldn't depending on the metal you choose. It's not really holding much stress so it's worth a shot and good luck :)
    msafford
    4 years ago on Introduction
    If one doesn't have welding gear, would a solder join be sturdy enough?
    joe408911
    4 years ago
    Thanks for looking guys and if you liked it please vote for me in the metalworking contest
