Metal Melting Furnace From a Scrap - Building Guide
1,604
26
4
I've seen a lot of cool videos about melting metals, so I tried to do it myself. I tried to craft totally free melting furnace from the backyard scrap. During the whole process I didn’t spend even a cent. I don’t think that I’ll use this aluminum and copper melting furnace for too long because in my opinion homemade metal foundry should be more efficient, safe, handy and of course multi-purpose. So, that’s just an experiment if I’m able to do this. In addition, this furnace will help me to test different mixtures on their ability to withstand temperature up to 1100 oC (or 2012 oF). Therefore, in the future I’ll be able to make much better furnace.
Step 1: Making Furnace Frame and Lid From the Old Bucket
First of all, I took old steel bucket which was used as a garbage can. I made a hole for the pipe which should supply the air to the furnace. After that I made ventilation holes near the center of the pot lid which will cover our furnace. It will help gases to circulate.
Step 2: Building Furnace Walls for Additional Protection and Temperature Sustainability
Secondly, I took some bricks, which were left from our house building more than 30 years ago. These bricks should work as external walls of our furnace. According my plan, they will work for the temperature sustainability and of course as additional protection. They won’t be so hot as a crucible and all nearby objects. The bucket is rusted and in fact don’t have a bottom, that’s why we need such walls.
Step 3: A Crucible
After that, I made a crucible using a can from canned meat. I know that some people do such things but this was a mistake….
Step 4: A Blower!
As a blower, I decided to use old vacuum cleaner, which has the function not only to suck an air but also to blow it. I’ve decide that it’s better than hairdryer which many people use for that purpose. It worked fine, but it was too powerful for such a little furnace. I had to degrade its power.
Step 5: Charcoal As a Fuel
As a fuel, I used charcoal. It was made by myself using firewood as a raw material. In addition, when the experiment was in process I added several little pieces of coal. Coal has grater burning temperature than charcoal. I think it helped me to increase the temperature faster but it smelled awful and black smoke appeared.
Step 6: Beginning of Hot Testing
I've burned the charcoal and started to increase th temperature.
Step 7: Test Results
Finally, I melted aluminum but it burned through the hole in the can and casted on the bottom of the bucket. I took it and prepare to use it in the new crucible made of pipe.
Step 8: Second Attempt
After first fault, I've made new crucible and casted round aluminum ingot.
Step 9: Several Tips for Those Who Will Try Melting Aluminium or Other Metals the First Time.
1. In my opinion, it’s not a good idea to use a tin can as a crucible! Cans can be made of different tin thickness and soldered using various ways. And when you use charcoal it is hard to control the temperature and it’s easy to burn something you didn’t expect to destroy. :) If you have an opportunity, try to use something more reliable than a can.
2. Remember to do everything safely. Temperature is grate.
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
    MandalorianMaker
    2 years ago
    Coal doesn't burn black, it burns with a bluish smoke. Your probably not using good coal, it is worth getting some.
    DuralMMandalorianMaker
    Reply 2 years ago
    Thanks for your comment MandalorianMaker. I'm not sure about the quality of the coal. I took it in my woodshed. My grandparents had some greenhouses long time ago and used firewood and coal for heating. As I understand quality and coal grade depends on the region and depth where it was mining. Definitely, this one is not the best for melting purposes. Thanks for the advice. Now even charcoal in fact is enough for me but may be in the future I'll try some other coal if not decide to use propane! :)
    seamster
    2 years ago
    This is something I'd like to get into someday. DIY metal melting still scares the beejeebies out of me, though! Someday I'll tackle it :)
    Thanks for sharing the things you did.
    DuralMseamster
    Reply 2 years ago
    You're welcome and thanks for your comment Seamster. :) If you're interested in this topic, you definitely should try someday. I've made this experiment one week ago. I had no practical experience in melting, except melting lead at home long time ago. In the nearest future I'll try to cast something into a mold using green sand I think. So, good luck if you decide to try yourself in melting and casting.
