Milliput Ring
22,624
251
15
About: Come spend some time in the shop. I'm a hobbyist woodworker and professional computer geek in Northern California. I guess my projects will vary widely, and I have no clue what I plan to make next...
After making the Milliput inlay bowl I knew I wanted to make something entirely from the putty.
I had some time to kill, while my resin project was curing, so I put off editing video and instead opted to spend some time in the shop making a Damascus style ring blank to turn in the lathe!
Supplies:
Step 1: Making the Damascus Putty Blank
I bought two colors of Milliput, one black one white. The putty comes in two parts. You use equal parts of the putty and hardener and mix them together until you get a uniform color. After I mixed both the black and the while, I rolled them into balls and flattened them out.
This process wasn't easy, as the putty is very sticky and stuck to everything I threw at it. Rubber gloves, silicone mats, parchment paper, wax paper and my razor blade.
  • Mix up the putty.
    • One black, one white
    • The roll then up into balls
  • Flatten each out
    • I put each ball between layers of wax paper
    • I then applied pressure with a flat block of wood to get each into putty discs
  • Making the damascus pattern
    • Stack the two discs together
    • Use a razor to slice the stack in half
    • Stack those two halves together
    • Flatten stack again
    • repeat
I think I did the process 5 times in total. I then rolled the whole thing out like a tube then flattened that into my final ring blank.
The Milliput only needs a couple hours to dry, but I ended up not being able to come back to the project for 48 hours.
Step 2: Drilling the Blank
After 48 hours, I had a very hard block of Milliput. It's not much to look at, but I'm hopeful that the pattern will look good once turned on the lathe.
Making rings on the lathe isn't difficult. First step is to drill out what will become the inside diameter. For my ring size that is roughly a 3/4" hole. Here is a useful chart of size in both inches and mm.
The hole can be drilled at the drill press, or even at the lathe. Considering that this project was a quick experiment for me, I just used my hand drill and a some bench clamps to make the hole. I must say, the putty shavings excited me as to what I could expect to see emerge at the lathe!
Step 3: Ring Turning
A jamb chuck is a simple jig used for wood turning. The term is pretty broad and can be used for a number of fixtures and holding devices.
In this case, I turn a small tenon on a scrap of wood with my parting too. That tenon should match the inside diameter of the ring, and be roughly half the items depth. It should be a tight snug fit. It can be a fussy balance between too tight and too loose. If too tight, then turn or sand the tenon a bit. If too lose, add some masking tape to tighten it up.
Once the blank is snugly on you can turn down the ring. Here I'm turning with a carbide cutting tool, but that is not required. It's just what I used for my Milliput bowl, so I knew it would work.
The trick with rings is getting them thin enough. There is an urge to stop early to avoid a break, but a thick ring is really too uncomfortable to wear. So, keep going, even though it's a bit nerve racking. :) I honestly could have even gone a little thinner, but it's pretty comfortable overall.
I skipped the sanding and polishing step as the Milliput came out really nice right off the tools.I think sanding with some very high grit sanding pad would only make this ring even better looking!
Step 4: Finishing
As for a finish, I went simple an just gave it a couple layers of spray lacquer. It really popped the contrast and helped to cement the damascus steel facade I was going for!
I must as I'm extremely happy with the outcome of what just started as a way to kill some free time!
Thanks for looking!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    15 Discussions
    _soapy_
    2 years ago
    Excellent. Very nice effect too. Might try this - if Milliput will actually cure properly into something usefully hard and tough, it'll come in useful for my day jobs too. Most epoxy seems to be, well, poxy.
    TimothyJ999_soapy_
    Reply 2 years ago
    If you're looking for an epoxy that cures rock-hard, try JB Weld.
    I find JB weld does a good job , but tends to get crumbly after a couple of months. Am I mixing it wrong?
    kludge77_soapy_
    Reply 2 years ago
    Thanks! It is quite hard! It feels similar to plastic, but will "write" on hard surfaces, so I think the finish is important.
    davidcondrey
    2 years ago
    If you work with the milliput underwater (In a bowl of water) or keeping your hands damp, you can avoid the stickiness.
    Natalina
    2 years ago
    Great ring! I'm not familiar with Milliput, I'm glad to know about it.
    xxlauraxx
    2 years ago
    What an awesome looking ring! Neato, thanks for sharing.
    "Sort of getting an open Oreo cookie vibe here." :)
    kludge77xxlauraxx
    Reply 2 years ago
    Thank you. I'm very Oreo focused apparently! :)
    deluges
    2 years ago
    Hah I see you made a ring after all !
    Nice work, is it comfortable ? Does it not irritate the skin ?
    kludge77deluges
    Reply 2 years ago
    Thanks! It is very comfortable, and feels a lot like plastic.
