Minecraft Instructables Robot
3,476
16
11
About: "I am a crafty girl. I make things. Lots of things. I'll keep making things until my fingers fall off. Then I will grab my hot glue gun reattach those suckers & Make More Things." Kathy R. Jeff...
I don't know about you but I love the Instructables Robot. So I decided to make one in Minecraft. Its pretty big and it's hollow. I converted the inside to a house. I hope you enjoy this instructable. Don't forget to vote.
Supplies:
Step 1: What You Need
What you need is
10 Red Wool
28 light grey
30 black
662 Yellow
Step 2: Feet
Make 2 platforms on the ground each 2 X 3 with 8 blocks between them in light gray wool. Now (following the pictures) make the circle ish these are the feet.
Step 3: Legs
(For this whole instructable it is a good idea to follow the pictures) Now for the legs go on top of the feet and stack up 4 blocks in yellow wool then 1 in black and 2 more in yellow. They should be hollow. These are the legs.
Step 4:
Now make a platform on top of the legs in yellow wool it should be 8 long and 17 wide. (just follow the picture)
Step 5: The Middle
Then make walls in the platform that go up another 11 blocks and put a roof on it. That Is the middle.
Step 6: The Head
Now do as in the pictures and make a head 5 X 8 in yellow wool. that's the head.
Step 7: Details
Put 2 red eyes on the front 2 blocks in between them. then to blocks under the eyes make a black line that is 4 long for the mouth. Now 2 blocks from the top make 3 squares that are 2 X 2 and use light gray wool. Under the gray squares make black line that is 6 blocks long.
Step 8: Antenna
For the antennas on the side of the head make a 3 X 3 square with red wool then a red block in the middle and one on the middle block. Then repeat that step for the other side. Then add 2 black wool blocks on each side for the finishing touch.
Step 9: Arms
for the arms go down 4 on the sides when you reach that block start going out and go out 8 blocks and do this 4 times 2 make a 2 X 2 thick arm. Then repeat for the other side.
Step 10: All Done
Now you are done. I a extra step and made a house inside of it by just putting ladders in the hollow legs and then in the body I put pictures in it and a bed it's pretty sweet. Well I hope you enjoyed this instructable. And don't forget to vote.
4 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Fandom Contest
    Fandom Contest
  • IoT Challenge
    IoT Challenge
11 Discussions
DiyGal123
3 years ago
I like this instructable i will have to give it a go-Madi?
bmcelik
3 years ago
I'm working on it right now! So far, so good :)
Ok I like that Idea. Thanks For including my name. Hey maybe you can put a link in the video :)
Phoenix Flare
4 years ago
Question... In one of the screenshots, is there a sheep lying on its back? I have never seen that before ....
Yes it is a trick check out this link to do it yourself
https://www.instructables.com/id/How-to-make-Mobs-turn-upside-down-in-Minecraft/
Deedman
4 years ago
I really want to vote for you because this is great! Although I cannot because you have not entered the contest when posting this instruct able.
