Minecraft PE Zombie Trap
40,681
52
15
Hello,
This is my first instructable for Minecrafters. Ever been attacked by so many zombies that you don't know where to go? Ever wanted to torture those brain-eating creatures without getting hurt?
If the answer is "Yes!!!" then this instructable is just for you !
Step 1: Step 1: Finding the Right Place.
For your trap you will need a large flat surface, if you can't find any, you could build your own by breaking some blocks.
Step 2: Building the Hideout (Optional)
1. Build a wall. (2×4)
2. Build another one forming an "L" shaped wall.
3. Build a 3rd one forming a U shaped wall.
4. Close the opening with some doors.
Step 3: Building the Trap
1. Dig 2 blocks down holes in each side of your door.
2. Continue digging aroung the house.
Don't dig less or more than 2 blocks. If less they can get out. If more you can't kill them anymore.
If you fall in the hole, you can place bricks and climb your way up.
(Unless the hole is really really deep they will die when they hit the ground. But make sure that after you dig it you can get out)
Step 4: How to Use It
Now basically you can just hide inside, but if you skipped building the house, it becomes more fun. Zombies will try to reach you but can't. So all you have to do is grab a weapon and start swingin'.
Step 5: Make It Easier to Keep the Zombies Out of Your House.
To make this easier, you can dig the few blocks that you have left in front of your door and replace them with a glass bridge (Use glass because it's easier to break).
But don't forget to dig 2 blocks down before building the glass bridge.
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    15 Discussions
    JeremyL79
    3 years ago
    Better to use trap doors as a bridge
    robot bx-31
    3 years ago on Introduction
    If you built a glass bridge, won't the zombie walk across the bridge?
    um cool but spiders...? they are fat so dig deeper! lol or the hole will be full of water!!! I don't use lava or cactus because they make loots go away! skeletons can climb ladders though if ur using ladders! great! wait, can't spiders still come? omg also animals can lure in by pushing them in the hole... and then they'll probably burn because of the zombies burning and steaks and porkchops will come out! yay! lol
    the "bone things" are skeletons.
    Keep walking around them in a circle to avoid them.
    They should have a hard time hitting you.
    mcdonaldr
    5 years ago on Introduction
    AWESOME! I'm gonna try it, but I'm going to make a casle and fill the moat with lava, Ha Ha Ha!!!
    aeromagician
    5 years ago
    It doesn't work to well for me those bone things just used arrows
    Ninja Alien
    5 years ago
    Yes, I already mentioned that the house is optional.
    divaalert
    5 years ago
    Not live leave sorry they autocorrect me all the time I hate it
    divaalert
    5 years ago
    Sorry holes not house
    divaalert
    5 years ago
    I wouldn't even build the house ill just make the house all around and live a big square left in the middle
    Ninja Alien
    5 years ago
    Yes... I already know those informations, and I posted them in an instructable, but it mysteriously disappeared, so I had write all over again. But that one disappeared too. So I made it as brief as possible and published it right away. Thanks for adding those infos for readers, I appreciate it. :)
    NVDevastator
    5 years ago
    You might want to make the bridge only one block width instead if two so its harder for them to get across. Also you should add a staircase out of the house thing so if you cant close the door in time you acn get out. This happend to me a long time ago when i first built something like this. You could also teplace the brick with glass to see out. Trying not to be a critic but just giving some ideas to help make it better :) nice job
