Mini Halloween Piñatas
2,226
7
About: For more about my costumes, crafts and general craziness, check out my blog: http://modmischief.blogspot.com/
Spooky little pinatas are perfect for your next Halloween party!
These pinatas were created for Drinking with Scissors, a monthly craft party in Whitehorse, Yukon. With all the materials (and even the treats to fill them with) provided in kits, the personal-sized pinatas can easily be assembled over drinks with friends or as a craft activity at a fun family event.
Step 1: Materials & Tools
For this instructable the spider kit has been used an an example, but the bat and ghost are assembled in the same way (minus the pipe cleaner legs).
Each kit contains:
  • printed card stock templates
  • extra card stock pieces for the side strips and decorations
  • string or ribbon
  • googly eyes
  • tissue paper or crepe paper
  • pipe cleaners
  • candy, confetti and other treats to put inside the pinatas
Extra tools and materials:
  • scissors
  • glue - clear tacky glue is used in this instructable but white craft glue works as well
  • tape - optional
  • hole punch - optional
Step 2: Cut Out Card Stock
Cut out the card stock body pieces. For the spider this is an oval with tabs that are folded up.
In addition to the two body pieces, you'll need long strips approximately an inch wide that will wrap around the entire outer edge.
Additional decorative pieces can be cut out of the card stock including fangs and eyes.
Step 3: Attach Sides
Fold up the tabs on one body piece and glue or tape them to the side strips.
Note on glue vs. tape: Scotch tape will be easier and faster than using glue to assemble the pinata, but the more tape you use, the harder your pinata will be to break open.
For the spider legs, punch or poke four holes in the side strip on each end of the oval. Thread through the pipe cleaner and secure with glue or tape.
Attach the string or ribbon through the side strip, at the top. You can reinforce where the string is attached by wrapping it around an extra piece of card stock before securing it inside the pinata.
Step 4: Fill and Close
Fill the cavity with confetti, candy and other small treats.
Close up the pinata with the other body piece and glue or tape the tabs to the side strips.
Step 5: Decorate
Decorate your pinata by covering it in tissue paper or crepe paper and adding details like the eyes. This is your opportunity to be really creative and give your pinata some personality. Consider adding fun eyelashes or going for a more authentic look with an 8-eyed spider.
To give the spider a fuzzy appearance, the tissue paper was cut into small squares that were scrunched up and then glued onto the surface. A chopstick or the end of a pencil can be helpful when applying tissue paper this way. Once the spider's body was completely covered in black tissue paper, the eyes and fangs were glued on.
For the ghost and bat pinatas in the photos, crepe paper was cut into fringe and then glued on in overlapping rows.
  • Epilog X Contest
    Epilog X Contest
  • Toys Contest
    Toys Contest
  • Cardboard Challenge
    Cardboard Challenge
dggoldst
2 months ago on Step 5
Lovely! If you try this, take note that we used a similar process to make a donkey piñata. It looked great but we found that the cardstock and glue-tab method resulted in a very rugged piñata that a bunch of 10 year olds couldn't get to split open. It tore a bit but never had a satisfying burst. The kids eventually tore it open by hand. When trying this again, I will experiment with making one seam extremely weak, perhaps by using a few small pieces of newspaper or facial tissue to close that one seam.
