Mini Powerbank 8000 MAh
1,939
34
5
About: DIY, 3Dprinting,Concrete, Electronics, Maker http://www.kims3diy.com
Hi guys! I made a big powerbank a couple of weeks ago, its perfect to have in my schoolbag as backup, but little to big to have in the pocket, so i decided to make another smaller one.
This one is can also be customized with different lids if you get tired of the design, with a capacity up to 8000 mAh. There is an assambley-video step-by-step on the youtubechannel.
Tools:
Gluegun - https://goo.gl/tqisEb
Solderiron - https://goo.gl/SE2Kiz
Solder helpinghand - https://goo.gl/nwfH0x
Cutting Plier - https://goo.gl/nwfH0x
3D-printers - https://goo.gl/FTIDCH
https://goo.gl/VTXWFa
Bill of materials:
USB-PCBCARD - (2$) https://goo.gl/L0R7sK
Batteryholder - (2,5$) https://goo.gl/jS8Eds
Batteries 4000 mAh - (13$) https://goo.gl/L0R7sK
If you like it PLEASE VOTE on me in the travel contest :)
Videoinstructions:
Step 1: 3D-print the STL´s
You will need a bottom, a lid and a powerbutton, you can find everything here or at thingiverse:
https://www.thingiverse.com/thing:2374637
I printed it at 20% honeycomb-infill PLA.
I used Support for the minibottom part, the other ones no support.
Step 2: Solder the Battery Holder
Make sure you got a Parallell circuit with your batteryholder. Like in the picture, else you will burn the PCB due to high voltage!
Step 3: Solder
The USB-PCB card to the batteryholder, Bta+ (Red) and Bta- (Black).
Step 4: Assamble
First insert the 3D-printed button, then the PCB and battery holder.
Step 5: Glue
Make sure everything works and glue everything where it belongs.
Step 6: Lid
Put the on the buttom and tight the 4 x M3 screws 10 mm.
Step 7: Finnished!
You have complete you Powerbank build, hope you had fun during this tutorial!
Please subscribe to my youtube to support my projects
    • Paper Contest
      Paper Contest
    • Pie Contest
      Pie Contest
    • Epilog X Contest
      Epilog X Contest
    5 Discussions
    igggy17
    11 months ago
    Perfect and easy to do.
    Kims3DIYTechno craft
    Reply 1 year ago
    read step one, bill of materials there is everything you need. just click the button and it will show how many % batteries.
    Jobar007
    1 year ago
    Have you tested the amp hours of the batteries? A lot of the ones on Bang Good and other cheap import sites are usually well below their listed capacity. If memory serves, with current lithium battery technology, 18650 batteries can only have 3500 mAH capacity. Anything over that are greatly exaggerating the truth.
    With the two cheap parallel cells, my guess is that you are going to be closer to 3000 mAH, which is more than enough for a cell phone charger.
    It is really good that you use hot glue to cement everything in place. With the powerbank being tossed into backpacks, onto desks, etc., you need to keep components in place to prevent leads and wires from breaking. Well done.
    Kims3DIYJobar007
    Reply 1 year ago
    you are absolutley right, its proberly not that much, but if it were it should been 4000 each, i have not tested it.
    Thank you for your feedback :)
