Mini Circular Saw With Dc Motor
41,513
230
32
Hello, I show how I made a mini circular saw dc motor advantage he had fitted with a drill chuck (used in the proposed mini drill press), I have done everything trying to go modular, ie the engine to use both for drilling and for the saw.
The mini table saw is simple, all a bit interesting is that I placed the lid hinges to work more comfortably, since the idea is that the mini saw mini drill and share the engine.
The motor is attached by nuts that allow varying the height of the saw cut.
The diameter of the saw blade is 8cm and table dimensions are approximately 28x20 cm.
Thanks for your attention, greetings.
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    32 Discussions
    WilliamR231
    7 months ago
    What power supply did you use and how did you wire it?
    pfred2Marchalis
    Reply 1 year ago
    I'm lucky that way. I was born with only 8 fingers, and two thumbs.
    klee27xKiteman
    Reply 5 years ago on Introduction
    I agree this saw is a little lacking in the safety department.
    OP: while this saw lacks a bit in size and power, there's still a fair bit of stored energy there. Consider the drill chuck's mass is adding to the flywheel effect. So please make sure you bolt/clamp the thing down before you use it. And be careful of your hand placement. If you have your fingers on the stock behind the blade, a kickback will draw your fingers into the blade.
    The table saw is a tool to be seriously respected. The lack of a riving knife is forgivable, given the size of this tool. But the lack of a blade guard, miter slot, fence, and adjustable blade height on this saw really limit the ways you can safely use it. You can't use a sled without a miter slot. And you can't use feather sticks nor a push stick when you don't have a fence.
    Consider the cost of one severed tendon repair could easily exceed the sum cost of every tool in Marc Spagnuolo's workshop.
    klee27xklee27x
    Let me share another 2 cents, as a wood "player." (Vs wood worker). The table saw is a really crappy tool for cutting small things. It can be done, if that's all you have. (With the aforementioned sled and/or fence + push sticks). But it's not very efficient. So a small table saw... well. If you have a particular application in mind, and you have figured out how to achieve that goal, safely, then that's great. But this does not look like a tool I would want to "play around" with!
    ric12335Kiteman
    Hello,
    You're right, it can be dangerous to work with, but I'm trying to improve in this area.
    I have thought about doing an internal structure that covers the circular saw, I'm on it.
    Thank you for your wake-up call.
    andrew mcneilric12335
    hi i have wanted to make something like this for sometime to cut circuit board but never figured out how to make a safety guard that would work without getting in the way. if you come up with something please post or make an updated instructable. have added this to my favorites well done.
    misha-ell
    2 years ago
    hi what kind of motor did you used?
    Abdul Gafur
    3 years ago
    Thanks for the pictures, its usefull for me..
    Abdul Gafur
    3 years ago
    Maze38
    3 years ago
    Thanks for the pictures, cause that definitely tells me exactly how to build it.
    ric12335Maze38
    Reply 3 years ago
    hasta un crío entendería las fotos.....no hace falta ser ingeniero.........
    ric12335chrisjlionel
    Reply 3 years ago
    Yes there is vibration problem, I use sergeants to secure a table.
