Miniature Anvil
5,082
67
24
This time I have made a mini anvil for my future collection of mini-tools. I have tried to be as similar as an anvil of original size using certain details that are usually seen in blacksmiths' anvils.
My inspiration came from the genious Marco Terenzi
If you like the video please Subscribe to my Youtube Channel.
I would also apologize for my English as a non-native English speaker some terms are very difficult for me. Forward, Instructable!! I will be happy to answer any question.
Step 1: Materials and Tools
Materials
  • Beech Wood
  • Copper block
  • Little chain
  • Old Windscreen wiper
  • Little Eye Screw (2 Unit)
  • Sandpaper
  • Wood Glue
  • Wood inserts (Threaded)
  • Metal Nails
Tools
  • Saw Metal
  • Metal Files
  • Ruler
  • Drill Press
  • Similar Dremel
  • Japanese Saw
  • Hammer
  • Polishing disk
  • Pliers
Step 2: Anvil's Drawing
I began marking the silhouette on the copper block. I looked for different anvil drawings and finally I decided to use this (document attached).
Firstly, I only marked the sides and then for the curved areas I used a very useful rule for these type of jobs.
Step 3: Cutting the Silhouette
In this step I just cut the main anvil silhouette. For the curved areas I used a bit drill to speed up the work and give it a better finish. For the rest of the cuts, I used the metal saw and extreme patience...
Step 4: Cutting Rounded Edge
With the attached drawing, I mark the thickness of the anvil and cut the excess material. Little by little it takes on the shape of an "anvil"!!
To get closer to the final size I use files in order to achieve grater accuracy.
In these steps I still do not intend that the surfaces are perfect, I simply delimit the proportions of the piece.
Step 5: Anvil's Horn
I use different files to define the anvil horn and as if it were a pencil, I sharpen it to achieve a symmetrical surface and as realistic as possible. It is a laborious work and as you are removing material it becomes more delicate, since removing an excess of material would ruin the appearance of the anvil.
Step 6: Polishing
In this step I was still not very clear about the aspect I wanted to give the anvil: whether a new look or on the contrary, a degraded appearance...
I decided for the moment to give it a new look: I started sanding the anvil with the following grids: 200, 300, 500 and 1000 and finally I polished it with polishing paste so as to get a shiny look. I really did not want to have that shine, but one of the peculiaryties of the copper is that it oxidizes very fast and it was a matter of days that it took that old touch. And that's how it was...
Step 7: Anvil's Stand
For the stand I used beech wood: I could use a single piece of wood but as I wanted to give it the greatest possible realism I used small pieces stuck imitating a robust, hard and heavy stand.
Step 8: Stand Details
In most of the old anvil stands, blacksmiths put around a reinforcement to prevent wood loosening. I came up with the idea of taking advantage of the small metal splints that the windscreen wipers of the cars have, since their dimensions were ideal for this purpose!
With the help of pliers, I shaped it until getting around the piece of wood and then I hammered it with gold small metal nails.
I used a walnut effect tint to give it and old color effect.
Step 9: Clamping System to the Anvil Stand
To hold the anvil to the stand I used a wood insert and a screw. Possibly, it would have been enough with epoxi glue but as maybe one day it falls up into the hands of a child... better to assure it well :-)
Step 10: More Details
Not happy with the realism achieved so far, I put a small chain fastened with two little eye screw. A delicate and laborious work due to the size of the parts.
Step 11: Final Conclusions
I could have done more small details such as small supports to store the hammers, but maybe I would have recharged it too much worsening its appearance. I am quite satisfied with the result, although I would have liked to use stainless steel.
I hope you like it and remember that I will be very happy to solve any doubt.
Big and Small Contest
Fourth Prize in the
    • Trash to Treasure
      Trash to Treasure
    • Pie Contest
      Pie Contest
    • Pocket Sized Contest
    24 Discussions
    Dangerously Explosive
    3 months ago
    I clicked on this thinking it was a tutorial for making a real anvil for small detail work, not a model! Good job, it looks really convincing!
    BayRatt
    3 months ago
    Love it! That's gorgeous. Well done! :-)
    Kenno79
    4 months ago
    This is neato! I love it! I sure hope your next project is a tiny hammer for this anvil.
    Kudos
    Mikhandmaker.Kenno79
    Reply 4 months ago
    Thank you for the comment! I will soon make a tiny hammer ;-)
    The Juliart
    4 months ago
    You did an amazing job!! This piece is truly a work of art!!! Great Instructable!
    KryptoTSD
    4 months ago
    I'd make that from a piece of steel bar stock... It might look better...
    Mikhandmaker.KryptoTSD
    Reply 4 months ago
    It could have more realism, although maybe more difficult to work.
    SteveDay72
    4 months ago
    The only thing different I would suggest is making the anvil out of aluminum, then turning it black using a small pot of chemical blackening solution that is used on aluminum guns/gun-parts (available online at any gunsmith supply or local gun shop). That way you can carefully use wire wool to buff away the blackened surface (in spots that would be worn) and reveal the silver metal underneath.
    Nice work though. I'd like to see the rest of your collection.
    [Edit]...
    If you want more heft than aluminum you could use zinc. Zinc can also have a dark chemical finish applied using black patina for lead&solder, it is sold in craft stores.
    Mikhandmaker.SteveDay72
    Reply 4 months ago
    It's very interesting what you are suggesting and maybe I will make like that in any of my following mini tools. I leave you the link of other one I shared in case you haven't seen it:
    https://youtu.be/MXzR5p5AMnM
    ElChick
    4 months ago
    Nice job! One small suggestion, change your material from "copper sheet" in the list to "copper bar" or "copper block". Otherwise, very well done!
    Mikhandmaker.ElChick
    Reply 4 months ago
    You're right, thank you for the suggestion and your comment!!
    SenKat
    4 months ago on Step 11
    Fantastic work ! The little chain, and the metal bands are a great touch ! Rest assured that your command of the English language is better than some that were born and raised in the U.S. ! Thank you for sharing this project, it makes me want to create an entire miniature smithy !!!!
    Mikhandmaker.SenKat
    Reply 4 months ago
    It could be cool to create the whole workplace of a blacksmith!! Thank you for your words, I appreciate them!!
    Peter MC1
    A beautiful piece of work. You mentioned stainless steel, if you wanted a 'steel' look you could always electroplate it.
    Mikhandmaker.Peter MC1
    Reply 4 months ago
    I have never used that technique, but I think I will investigate about it, thank you Peter!!
