Miniature Camp Stove
67,304
409
37
About: Professional work in various electrical and mechanical fields, obscure sense of humour and typically willing to help... Currently under contract designing environmental monitoring equipment.
While looking at camp stoves I thought that I needed a tiny one.
This is a wood burning (tea Light Alternative) miniature camp stove.
The stove is made from scrap copper tubing and about 3 hours of my time.
I used 2 5/8 copper tube and basic copper plumbing tube. all connections are brazed using my Smith Mini Torch.
When completed It will boil water and keep going for up to 25 minutes.
All that is missing is a laser etched maple leaf
Step 1: Materials
I used scrap copper tubing that was 2 5/8 inside diameter. Along with small sections of regular 3/4 and 1/2 inch rigid plumbing copper.
You will need a section of flat copper. I used a section of the scrap tube to provide this. Flatten using scrap pieces of wood and a hammer rather than just a hammer since this will deform the metal. You want an even, flat surface.
Cut a section roughly the diameter of your tube for the burner box then another section that is the diameter of the pipe for the top and bottom caps.
Step 2: Make the Burner Box
Using an appropriate tool (Dremel) cut a rough opening about 1/4 of the tubing diameter wide and leave 1/ inch at top and bottom. This is the access door.
Using 3/8 inch tubing, make two hinge pivots ant are 1/4 inch wide. Flatten one side with a file than braze to the side near the opening that was cut.
Cut a small section of 3/4 inch tubing that is about 1/4 inch wider than the the section that is cut out of the body tubing. Curve this to match the curve of the body.
  Placethe 3/4 inch tubing over the opening of the body and mark the perimeter and index one side.
Step 3: Prepare and Fasten the End Caps.
Enclose the body with end caps.
Drill one of the end caps with a 1/2 inch hole for toe top and braze the end caps on.
Use a file to clean up the edges.
Step 4: Make the Door, Grate and Legs.
Using the semi-flattened 3/4 inch tube. Drill 3 hole ans elongate the center hole into a slot. Cut a section of the removed section of the main body to work as a damper. Drill a 1/8 inch hole and braze a bent rod into the hole. This is now your damper.
It will fit behind the door.
Cut a small section of tubing in half and braze it to work as a slide for the damper.
The grate is made from cut sections of 1/8 inch brass welding rod. Cut and braze these together. Care taken to not overheat and small size.
Step 5: Make a Grate, Fit the Door.
Carefully bend small sections of the Brass rod to act as hinges for the door then braze in place.
Bend a small section of rod to act as a door stop and drill a 1/8 inch hole in the body at the latch point. Braze the rod into the hole.
Braze a small section of tubing onto the inside of the door for the damper slide.
Finish and fit the door.
Step 6: Attach the Chimney and Flue
The chimney is brazed to the 1/2 inch opening on the top plate the damper is placed in the chimney about 1.5 inches from the top plate. It is made from a bent piece of 1/8 welding rod and a copper flap.
The chimney is made from 1/2 inch copper plumbing tube that is swaged to 1/2 inch id at the joints. The chimney is not welded th the uprights.
Step 7: Assemble, Burn, and Enjoy
You can boil water with a small amount of wood. A te light should provide adequate fuel for heat
Pocket-Sized Contest
Finalist in the
    • Trash to Treasure
      Trash to Treasure
    • Weaving Challenge
      Weaving Challenge
    • Pie Contest
      Pie Contest
    37 Discussions
    Jc460
    1 year ago
    If you're interested in making another one similar to that for me, contact me at jcuscianna1981@gmail.com that thing is awesome. I need dry heat in my spacekap. I'm on vancouver island too much moisture already. Cheers.
    rml422244
    4 years ago on Introduction
    Hey this looks awesome, just wondering how you got the hinges (freezer line pipe) to stay attached while you were brazing? really curious as i hope to make on of these someday
    Sorry for the late reply.
    I put a little braze on both pieces then held them together with a pair of pliers then heated until the braze melted together.
    I hope that this helps.
    Good luck with your build
    Can you make me one and I will buy it? Email me @ johnm.cbs_llc@yahoo. Thank you
    Aaronius
    7 years ago on Step 7
    Your wood looks a little green!
    Awesome mini-project!!
    ElGooch
    very nice project... not a bad way to spend three hours of your life. ;)
    This is so cool!! I've been drawing stoves like this for awhile now. It reminds me of the stoves shown in "The Swamp" tent on the MASH tv series. I can't wait to make one.
    GrumpyOldGoat
    I meant to ask earlier, but it slipped my mind.
    I need more information to actually answer that question.
    What are you swallowing? Has it been well masticated and thoroughly mixed with a liquid?
    Also, is the liquid water based, oil based or alcohol based?
    Oil based should slide down rather quickly, but comparing the distance, assumed to be equal, to the distance the Sparrow travels, the Sparrow would win hands down.
    Water is heavier and has a thicker consistency, so would naturally be slower.
    Alcohol based, assuming again legal age to consume adult beverages, after the third swallow... who cares?
    I do hope this helps clarify the question.
    ak49er
    As a physicist, I must disagree with your assertion regarding the non-sphericity of avian species. The spherical bird model is widely applied throughout physics, engineering, and numerous other disciplines[1] and has recently been empirically verified[2]:
    As we know that birds generally share a common morphology, we may therefore conclude that a significant portion of birds are, in fact, spherical[3].
    The problem, I think, is that your physicists are only educated to the undergraduate level. Postgraduate education would make such reasoning as this second nature.
    [1]Kirkman, T. W. (1996).
    [2]Szöllősi, G. (2009).
    [3] Troll, Edward D. ( :D )
    GrumpyOldGoatak49er
    Which exactly proves my point.
    ...unless your much higher level of education demands that all birds be considered to be quite similar to the their spherical body styles.
    In which case I must point out that a Peregrine Falcon and an Emperor Penguin have few similarities, yet both are birds... As are Kiwis...
    ak49erGrumpyOldGoat
    Yup, both clearly spherical.
    See
    http://en.wikipedia.org/wiki/Spherical_cow
    for a similar example.
