Mirrored Disco Ball Halloween Costume
156,604
130
54
Want to be the Discobelle of the Ball? This mirrored creation will be a crowd favorite!
Create a mobile party that will keep people dancing around you all night!
(Photo courtesy of Joshua Targownik)
Supplies:
Step 1: Materials
Materials for disco ball:
mirrored material (3 2x2 sheets)
2 24" plastic domes
velcro (heavy duty)
2 2" wide silver belts
silver tape
Tools:
Utility knife (with plenty of extra blades)
Scissors
Hot glue gun
Dremel cutting tool
mirror cutting tool
Gloves
Outfit:
Sequined top
Sequined hotpants
Sparkly tights
Silver gloves
Silver shoes
Accessories:
Silver wig
Battery operated lights
ipod shuffle with speakers
Step 2: Cut Domes and Velcro Together
I decided my best option for the disco ball form would be using acrylic domes, available at many plastic supply stores. Although expensive, ($180!) and not perfectly round when seen from the side angle, they are very strong even when cut and still have flexibility. Also, I needed a solid way to attach the domes together, and get in and out of my costume, so the dome "lip" came in handy.
Using a dremel tool, (with help from my friend Dave) I cut out each dome's top and bottom to fit around my body. This step was made easier by taking rough measurements of my bust and bottom using wire shaped around my form and then sketching it on the domes.
I used industrial strength velcro (available at Home Depot) to attach the sides of the domes together. It makes an amazingly strong bond! After lining both edges I also made a velcro "hinge" on the interior of one side to make it easier to put on and take off.
I celebrated getting this far by dancing around doing the robot.
Step 3: Attach Straps and Pad/cover Edges
After velcro-ing the domes together, I needed a way to wear the costume that would support the weight of the mirrors (and it got heavy, fast!)
I cut two silver belts (orienting the buckles on my shoulders, easily accessible) and hot glued them to the interior of the domes. Later, I reinforced the straps with gaff tape to help hold up against the weight of the mirrors.
I covered the sharp cut edges of the domes with foam tape to pad them. Then I covered all edges with silver tape, to disguise where the mirrors ended.
Step 4: Cut and Glue Mirrors
These mirrors come in various sizes (I used 1/2" mirrors) on a fabric backing that is about 2'x2'. I picked mine up at the Kit Kraft hobby store for about $60 each.
To cut strips from the grid of mirrors, I used GLOVES and a sharp utility knife, running the blade between a row to cut the fabric backing. The blade dulls quickly, change often. Keep in mind, mirror edges are SHARP!
Laying the first row of mirrors was the most difficult. I started on the "equator" of each dome. My first try was not level, but luckily the hot glue pulled off cleanly when I decided to try again. This time I also used a laser level to make sure it was a good starting point. Then I started gluing strips of the mirrors up from the equator, offsetting each row in a brick pattern. I cut mirror tiles in half (scoring them with a cutter) to fill in the rows all the way to each edge.
Hot gluing the rows one by one was a time consuming process... but I got both domes covered in a couple nights. I finished off each edge with a row of mirrors as well.
Finished, the ball weighed in about 20+ lbs! A workout wearing that around all night for sure.
Step 5: Choosing the Outfit
I wanted to sparkle and shine head to toe... so I set out to find a great outfit. Something fun and cute that I could wear even if I took the ball off for a bit.
Tinsel wig $15
Sequined top $25
Sequined hot pants $30
Tights $10
Gloves: $12
Shoes $5
The shoes were a goodwill purchase. I had some mirrors left over, so I went ahead and mirrored them too!
Step 6: Getting Into (and Out Of) the Costume
You might think the ball was cumbersome, weighing in at 20 pounds... well it was, but I designed it with practical needs in mind... (like going to the bathroom!) and wanted to be able to get in and out by myself. Crack it open, put one arm through, push velcro together and buckle up!
Step 7: Accessories
Music!!!
I bought mini speakers for my ipod shuffle, which I loaded with disco favorite hits. The speakers weren't very loud, but loud enough for a mobile party. I used velcro strap to attach it to one of my belts.
Bracelets!!!
I had some belt strap, mirrors, and velcro left over, so I made a couple bracelets.
Lights!!
I attached small LED lights to the bracelets. They twisted on, with blinking and solid options. I found these at Michaels Arts in the wedding section. I also carried around a small but very bright LED flashlight to "spotlight" the discoball.
Step 8: Party!!
Now hit the dance floor and spin baby, spin!!
I was a fantastic sensation, clearly a crowd favorite... Everyone likes shiny sparkly things! Yes it was a LOT of work, but I enjoyed every minute of being the Discobelle of the Ball!
Finalist in the
DIY Halloween Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    54 Discussions
    Tiannah20
    2 months ago
    How are you supposed to sit down?
    This is a great project, but I might suggest including info on where to get your supplies. Mirror sheets and large acrylic domes aren't exactly household items.
    I did mention that I got the mirrors at Kit Kraft hobby store... it's in Studio City, CA. The domes I purchased at Solter Plastics in West LA... I've also seen them in other plastic supply stores, places that sell security camera equipment, and available online as well.
    JimL185atozfriendly
    Reply 7 months ago
    I've looked online but can't find the domes. Would you mind sharing where you saw them? Thanks!
    atozfriendlynicemag
    That's a question I went around and around as I tried to find a cheaper way to build this. I think paper mache with a wire frame wouldn't hold the weight of mirrors and it's shape... I couldn't find styrofoam balls that big, Industrial sized salad bowls weren't round enough... I looked into custom vacu-forming and settled on the ready made acrylic domes. They performed amazingly though! Not one crack.
    JimL185atozfriendly
    Reply 7 months ago
    Where did you find the acrylic domes? I can't find them anywhere. Thank you!
    kscienceatozfriendly
    atoz- What a coup you have pulled off! Excellent look back to "Light Show" days. The 'pimp' comment is a cheapening of this utterly rad I'ble. I say, ignore the trash and enoy the genius.
    JimL185JenniferF42
    Reply 7 months ago
    She states in the article, you need to order from KitKraft.
    https://kitkraft.com/products?utf8=✓&q=mirror
    JimL185
    7 months ago
    Absolutely love this and want to make it. However, I can't find the acrylic domes anywhere. Help?
    AllyGz
    3 years ago
    Love love this costume. I want to try to create it this year!
    Instead of the acrylic dome I'm thinking of heavy duty paper mache - do you think if I layer it like 5x it will be strong enough to hold the mirror tiles? Were those heavy?
    Also - which mini speakers did you buy? Where do you hold them in your costume?
    Thanks so much for the creativity, you looked amazing!
    GLoho
    4 years ago on Introduction
    I can't believe the dome is soooo expensive I'm trying to make one for 2014 halloween and just the cost of the materials are steep. Any way you'd rent this costume and cost if I emailed you my zip code ? I'd pay for shipping.
    KDS4444
    5 years ago on Step 8
    Well, that is amazing. I am in awe.
    static
    I wonder if using narrow masking tape, and painting the ball silver or aluminum, would give a reasonable facsimile of a disco ball? Would have to be much lighter, and maybe less expensive. Then again it may not have the WOW factor of actual mirror tiles.
    KDS4444static
    Reply 5 years ago on Introduction
    "Reasonable facsimile of a disco ball"?? No way... You would end up looking like a large steel ball bearing!
    jennneal1313
    7 years ago on Introduction
    Wonderful costume with great details! Have you seen any of those mirrors online? I'd like to work on something similar but not finding the mirror material locally. Thanks for a great job!
