Modern LED Desk Lamp...Powered by 5V USB
207,404
1,257
57
About: Teacher by trade. Student at heart
This was an entirely new project for me. I've always been fascinated with edge-lit acrylic and I figured it would make for a nice desk lamp. The sanded edges of the acrylic pieces send off a diffused glow that works great for a desk or reading lamp. The LED strip inside is cheap and safe since there is no wiring involved.
As with all power tool Instructables, please use proper PPE and follow all safety protocols for each machine.
This Instructable is aimed to provide everything you need to make one for yourself. But if you have any questions, send them my way.
Supplies:
Step 1: Gather Materials and Tools
Tools needed:
  • Mitre Saw
  • 3/4" and 1 3/4" hole saw and forstner drill bit (Drill press or hand drill powered)
  • Belt sander or palm sander
Materials needed:
Most of these materials can be sourced from scrap with the exception of the LED strip
  1. Wood: Any wood from aspen to zebra can be used for this lamp. You need about a board foot for a decent sized lamp, so even if you have to buy something, it isn't that expensive. I chose some shorts of walnut that were planned to 1/2".
  2. Acrylic: I got my acrylic from a local plastics manufacturer. They end up with plenty of offcuts and would likely be willing to part with it. If not, you can pick up acrylic sheet at most hardware stores. I used 1/4" thick acrylic for this lamp. But anywhere from 1/8" to 1" would work.
  3. LED Strip: I used a 5v LED strip with a pre-wired USB end. 50cm will give you plenty of light to work with. I ordered several dozen since I am making these with my students and it really drove the price down. You can expect to pay less than $5 for this. Mine were sourced from Aliexpress. LED Strips On Aliexpress.com
  4. Dowel: 3/4" dowel works best for wrapping the LED strip around. You will be able to find this at any hardware store.
  5. Glue: Gorilla glue is great for glueing dissimilar materials like wood and plastic.
  6. Finish: Wipe-on Polyurethane from Minwax is always my choice of finish.
Step 2: Cut to Size
The wood and the acrylic have to be the exact same size. This is especially true if you don't have a belt sander to true them up later on.
I like the look of a square lamp. So all these pieces, both acrylic and walnut, were cut to 5" x 5".
Step 3: Drill Center Cavity
This is where the LED strip will sit and the light will come from. It isn't super important to be dead accurate with your cuts since it will be hidden on the inside, but it is a good idea to make some centre holes to line everything up.
I used a 1 3/4" hole saw to cut through the wood and acrylic. Acrylic is a tough material to work with and I made sure to take every safety precaution when drilling these pieces. They can catch and spin if not clamped down tight.
The centre dowel sits in a 3/4" hole on the bottom piece.
Step 4: Attach LED Strip
The LED strip is attached to the 3/4" dowel with the adhesive backing. Wrap it around and secure it. It doesn't matter what the orientation of the bulbs are because the glow of the acrylic will diffuse the glow.
There is a little slit cut into the bottom piece of acrylic to allow the cord to exit the lamp. I used a bandsaw to make this cut, but a jigsaw, handsaw, or hacksaw will work.
Step 5: Glue and Clamp
Once all your pieces are cut and the LED strip is in place, it is time to glue.
Gorilla Glue will work best for this because you are joining plastic to wood. Be aware that Gorilla Glue expands greatly and will leak out the sides if you use too much.
I orientated the boards so that the end grain was alternating. Clamp in place and allow to set.
Step 6: Sand the Sides
After the glue has set, scrape off excess glue and sand to finish.
Using the belt sander speeds up the process of finishing the sides, but a palm sander will suffice.
Be cautious of burning and melting the acrylic on the belt sander. Take small passes and allow the plastic to cool.
I used grits from 80-220 on the palm sander to get a great finish on the wood and acrylic.
Step 7: Finish
Minwax wipe-on poly gives a great finish to the wood and acrylic. Super easy to apply. Just wipe on, wipe off, Daniel san.
Let dry and then it's time to enjoy your lamp!
Step 8: Make Different Sizes
This project can be customized to so many different dimensions and styles. It's up to you and your creativity to stack different sizes of wood and plastic and create something unique.
The next stage of this project is to cut the pieces out a laser cutter.
Thanks for reading, hope you enjoyed. Please vote for me in the lighting contest!
Lights Contest 2017
Second Prize in the
Lights Contest 2017
19 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Woodworking Contest
    Woodworking Contest
57 Discussions
BarrySumpter
6 weeks ago
Perfection!
And just Super Cool!
Thanks for the verbose instructable.
Much appreciated.
Any chance of getting the dimensions of the rectangle shape?
In AUS, 5" x 5" (~ 125mm x 125mm) acrylic was priced at $5 each + GST.
In my area, not a single plastics manufacturer wanted to sell me an off cut.
I could have driven another 10 klm but would not have been feasible.
docman100
1 year ago
Why on one picture of the acrylic its perfectly clear and next to it you can barely see though it?
cyrzeedocman100
Reply 1 year ago
The acrylic is originally clear. But once you sand the face and sides, it becomes matte and diffuses the light/
BarrySumptercyrzee
Reply 6 weeks ago
There is a technique to heat the acrylic back to clear using a blow torch. Search YouTube. hth
docman100Joel.Stocks
Answer 7 months ago
according to the instructable, the recommended sizes are: 1/2 inch thick and 5 x 5 inch long and wide. But depending on your budget you can just experiment to your every needs.
AndréF100
1 year ago
How would I go about adding a place on top where you touch to turn on? Anyone has any idea?
Also what you can do is get a cheap touch switch and a cheap arduino and c&p some code into it plug the TS into it add some foil to it and attach it to the top. Look for the recently featured touch lamp for more detal
Cuch9901
1 year ago
Can anyome tell me where they are getting the acrylic? Im in Minnesota and it is crazy expensive. Thanks!!
EricE121Cuch9901
Reply 1 year ago
Hi, I recently learned that all old flat screen monitors have a large bit of acrylic inside of them! I found a 19" flat screen monitor in the garbage, took it apart, and sure enough there was a 19" x 19" x 3/8" thick piece of acrylic inside! They're not all that thick but this was a good one. It sure beats paying an arm and a leg for it!
steegs8319EricE121
Reply 11 months ago
Old thread I know sorry- but any chance you could clarify what Kind of old monitors you're referring to? LCD? CRT?
FokkoPsteegs8319
Reply 11 months ago
He's talking about LCD screens. Old CRT's only have glass in front of 'em. I've found that the plexi that's inside of monitors sometimes have some interesting patterns for diffusal or the like. Might make for a cool project.
DanielleE24EricE121
Reply 1 year ago
Are you talking about the old CRT style flat screens?
robertogallea
11 months ago
I make something a bit more complex.
These are two cubes connected to an electret microphone, acting as VU-meter. I positioned them on top of my home theater front speakers.
kooth
11 months ago
This is beautiful! I want to make one for my wife. Your Instructable is easy to follow, and well thought-out! Thanks for posting!
