Modify a Mini-B USB Cable to Power an Enclosed GoPro Hero3 (With Skeleton Back Door)
253,622
205
34
I got my GoPro Hero3 for Christmas, it is a fantastic camera.  However, the battery life leaves something to be desired.  Sure, you can buy a bunch of spare batteries and change them out periodically, but if you are taking a time lapse - you really do not want to move the camera.
Enter: The Frame
This is GoPro's answer to this problem.  Now you can shoot while being connected to an external power source.  But, wait, $40 for a piece of flimsy plastic (to be fair, TWO pieces of plastic!) with a few holes in the side?  No Thanks.
I really wanted this capability, but didn't want to spend a lot of money or sacrifice the poly case by drilling a hole in the side.
Enter: Modify a Mini-B USB Cable to Power an Enclosed GoPro Hero3 (With Skeleton Back Door) (This Instructable)
Disclaimer:  Perform this at your own risk, I take no responsibility for your actions and assume you have some competency. With that being said, this instructable is merely a cable modification, I do not modify the camera or case.
Step 1: Parts/Tools
You will need:
Parts-
-A Mini-B USB cable of your desired length.  I found an old 3-footer in my spare cables tub.  I might suggest not using the one included with your GoPro (just in case...).  Note: I have a Hero3 Black Edition which uses a Mini-B. I do not know what the Hero2 (or whatever) uses.  Also, of course, your cable design may be slightly different.
-Glue...?  I used some, it may not be needed though...
Tools-
-Wire Strippers/Cutters.  Not that you will be stripping wires explicitly - but you will need to cut off the black plastic molding around the connector and trim back the cable sheath.
-Long Nose Pliers.  For general dismantlement and metal bendage.
-Small Rotary Cutting Tool.  I use a really cheap one from Harbor Freight.  Yes, it is cheaply made and doesn't have a lot of power, but hey its like $10 on sale.
Step 2: Destruction.
-Cut off the plastic molding around the Mini-B end of your USB cable.  Take care not to cut through the wires within.  I just cut it and trimmed it away until it separated from the metal casing.  Depending on your cable design, you may have to cut off some plastic strain relief as well.
-Disassemble the metal casing.  For my cable, I bent away the strain relief tabs and then separated the main casing.  Sorry, I do not have a better photo of this step!
Step 3: Modification.
-Bend the pins into approximately a right angle as shown.  My plastic tab broke, this is where the glue comes in.
-Glue the plastic tab back onto the connector.  It doesn't have to be a super glue job, as long as it stays attached, it is not exactly a structural part of the connector. Note: try not to get glue on the power pins (outer, black & red).
-Use your rotary cutter to cut down the side walls of the main connector body as well as a horizontal cut on top of the connector. Bend it down into about the same angle as your pins to form the new body of the connector.  Also bend and flare the newly created tabs out (see photo).
Step 4: Test.
-Do a test fit.  Make sure your pins are flat against the inside of the connector and not lifted up some (this could be bad when you connect it!)
-Bend the newly created tabs against the connector and make sure they hold it down.
-Plug it into your GoPro Hero3 and make sure it powers it.  You may have to adjust the position of your pins slightly, or scrape off some glue from the top of them.
-Look for any adjustments you need to make.  The metal tail of my connector body was too long, it needed to be cut off.
Step 5: Adjustments.
-With your rotary cutting tool, trim off the metal tail so that it will fit within the GoPro Case
-Add some more glue to seal the deal.
-I also trimmed off more cable sheath, you may or may not need to.
Step 6: Record.
-Assemble your GoPro into the case with your new cable attached. Take care, there are a few tight clearance spots noted in the photos.  These are mostly where there are ribs/ridges in the case itself.  I believe these could easily be modified to allow a looser fit of the cable, however do this at your own risk, I did not feel the need to.
I have not done any long term testing with mine yet, but it is definitely nice to know that I have the option, if I need it!
Let me know if you have questions! Thanks!
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    34 Discussions
    tarun1604
    1 year ago
    is it work on gopro hero 4 black/siver ?
    lukeD
    4 years ago
    Hi there!
    I can say this won't work with the hero 3+ silver (please say it in your ible for future makers). I made this modification and it does not fit in the casing of the hero 3+ silver.
    SCHLEPIClukeD
    Reply 4 years ago on Introduction
    The Hero 3 and Hero 3+ utilize the same housing. Is the Hero 3+ wider than the Hero 3?
    lukeDSCHLEPIC
    They certainly do not use the same housing! The camera itself is the same size, the housing is not. ( see the picture )
    SCHLEPIClukeD
    Ah ha. The Hero 3 and Hero 3+ are originally packaged with different housings, but the GoPro website only shows the Hero 3+ housing now (which is also compatible with the Hero 3). The Hero 3+ housing seems to be noticeably slimmer than the Hero 3. Thanks for bringing this to our attention!
    yamil008
    5 years ago on Step 6
    Awesome! I think that you can use Sugru to cover the exposed wires and make it look nicer. Anyways, awesome instructable. I doing this one definitely
    zplusyamil008
    Reply 5 years ago on Introduction
    Maybe so but it is definitely a tight fit without modding the case! In fact, I was not worried about strain relief because the case kind of crimps down on those wires.
    Invention1
    I made this mod in about ten minutes. The Skeleton case provides sufficient strain relief so that the USB cable doesn't need any more support. The only tools I needed were an xacto knife, a teeny flatblade screwdriver and a teeny pair of pliars. Instead of sawing off the excess metal case on the connector I just folded 1/16" of metal over with pliars until it would fit inside the case without modification. Kept the watertight case back in case I need pictures of fish - one other similar instructible contemplates drilling holes in your case which is definitely not necessary. I should be able to keep the Gopro inside its case permanently, pulling off pics by wifi and charging by this hacked cable.
    foggy34
    im prety sure it dosent matter, but i might be wrong.
    gazumpglue
    It looks like you've peeled back the sheathing as well. Normally that is connected to the metal enclosure around the pins and presumably grounded. What should I conclude from this? Should it matter for this project?
    chimplost
    Excellent picture of the finished assembly. This is helping me.
    conniest
    zplusconniest
    Most likely it will not matter at all, especially if you are purely using it for charging. Pulling the shield back could introduce some extra noise, yes, but I doubt anything noticeable. Just don't use the cable near any strong, high frequency magnetic fields or high voltages. :)
    Vincent VD
    6 years ago on Introduction
    Great success! thnx for this tutorial! i'm still looking for a way to have both livestream to my computer and charging at the same time. using the 10.5.5.9:8080 way seems to be the only way...
