Modular Vertical Garden.
2,464
47
11
The design is my own idea. It is the final and the simplest version, after many thinking and try.
This 5 pieces cost together, from new material, about 13 USD. 1 piece 2,6 USD.
It is very simple to make, go fast, strong, variable, high volume for soil.
Supplies:
Step 1: 10 Peaces in Corner.
To balcony, for herb, flowers and any plants.
A crate volume 15 cm x 15 cm x 100 cm. About with elongation 30 liter soil.
The crates can be lift with 2 men, and can be variable, full with plants too.
As you see, in my garden function as an 8 m long, 1,6 m high dividing wall surround the pool.
The rest irrigation water goes to the lower level.
Better to make 4-5 holes on the back sides, 5 cm from the bottom of the foil.
Step 2: This Is My Own Garden.
This year util this time are in the crates just Strawberry. In 50 crates are 250 Strawberry. I plan later i change in many crates to hanging flowers.
In the crates is an automatic drip system.
Step 3: Just This Material Need for a Crate Frame.
2 pcs 15 cm x 35 cm wood planks
2 pcs 100 cm slats (3 cm x 5 cm)
8 pcs screw nails (55 mm)
Thats all. Less can not be.
Better Handle the wood.
Step 4: Mounting
All cut must be Exact right angle !
You need to drill the location of the screws.
One crate frame can be done in a minute ! (Only screwing)
Step 5: Foiling
You can use any strong enough watertight foil.
As you see, it is easy to cover with the foil. With stapler or crew too.
You can use beautiful oilcloth too, but this not to strong for Stapler clip ! Must use Large head screw.
Thank you for watching.
Gardening Contest 2017
Third Prize in the
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    11 Discussions
    namlehseb
    2 years ago
    It appears that the aluminum is "gutter or roof flashing" and is available in long rolls at any home center. It can be left natural silver color or painted very easily. It comes in a variety of lengths and widths. Relatively sturdy stuff.
    LongJohnHolmesnamlehseb
    Reply 2 years ago
    I dont know what material do you mean. If it is strong enought, then can you use.
    mrsmerwin
    2 years ago
    I have never seen this foil. Where would I look for it? The only foil I have ever seen is the stuff in the roll in my kitchen. This seems to be some sort of construction material.
    LongJohnHolmesmrsmerwin
    Reply 2 years ago
    Yes this is an industrial material. You can find same strong foils in an workshop where made Truck tilt or tents.
    Or you should find any strong material in your territory.
    You can use strong but not waterproof material too, then you cotton inside with waterproof normal foil. The can go inside the soil.
    mrsmerwinLongJohnHolmes
    Reply 2 years ago
    I think auto correct may have changed a few of your words but I think I understand what you were saying. I will look for the aluminum first.
    sun.
    2 years ago
    That's a very interesting way of planting strawberries. Thank you for sharing. How do you handle the watering system and how does the dewatering system works? I can't really figure it out by the pictures.
    LongJohnHolmessun.
    Reply 2 years ago
    Here is the system. All parts from Aliexpress. the water pump about 12 USD. At beginning must perfect set up the dropping, then goes automatic with an timer switch.
    https://youtu.be/Xu0DqCwKKi4
