Molding Idols Using Silicone and Plaster of Paris
1,643
10
4
About: I make stuff while i am not writing algorithmic trading scripts .
Maybe you are not good at creating beautiful figures out of clay or chisel your way like Michelangelo. But you can definitely duplicate and modify an existing figurine . Who know - it might be even better than the real one ! Try this out . If you would rather watch a youtube video - here it is - link to youtube video
Supplies:
Step 1: Clean Your Figurine
Dust is a killer - you don't want all your work to go to dust . ( pardon the pun ) . Clean it up . Use soap if need be.
Step 2: Measure Up
Measure the boundaries of the enclosure. It will be necessary to have an exact fit. ( You will see the reason soon )
Step 3: Cut Cut Cut
Cut out the board in the right dimensions that you just measured.
About the board - The one I am using is called the PVC board. It has got a plastic-like coating on one side. It doesn't get damp when in contact with a liquid material.
Step 4: Size Up - Check If It Fits Tight
Just to double check the fit - place it around the figurine
Step 5: Glue the Enclosure
Once you have made sure the board fit in right, glue it up to the base . Use a glue gun.
Step 6: Pour the Silicone
Once the enclosure have been properly glued up , make sure its water tight .
Now pour the silicone rubber ( with the hardener mixed thoroughly) into the enclosure . The silicone should cover the whole of the figurine. Silicone is heavy - any holes or openings can let it go through and render your project useless ! Now you know why it should be water tight ...
Set this for around 3-4 hours . ( It depends on the room temperature and how much hardener you have used ) . See the instructions in your silicone rubber package.
Step 7: Cut Open the Mould
Once the silicone has set ( after around 4 hours ) , cut open the mold from the enclosure.
This might need some care , ( this is the most important stage ). Any damage to the silicone mold - and all the rest of the casting will turn out bad.
Step 8: Pour in Plaster of Paris
And now ... The real duplication step.
Add plaster of paris ( 1:1 water to POP ratio by volume ) in the mold . This will have to wait for around 8-10 hours. Some POP ( Plaster of Paris ) variants harden quicker.
Step 9: Voila - the Cast Is Ready
Once the cast has solidified, slowly pull it out of the mold . Extra care if it is still humid. You might want to keep it to dry for a few hours ( I used the oven - Its faster and gives a crisp brittle bone dry feel )
Step 10: Paint and Add Some Gloss
Now is the fun part . Relax and pour in your imagination. Paint on it .
Once done, add a coating of clear acrylic onto the final piece. I used the acrylic spray. Its much easier that the liquid acrylic paints. Two coatings will give a good finish.
Step 11: And That's It !
You are done once the acrylic sets . ( it usually takes around 15-20 minutes ) .
And this is how the final product looks like !
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    4 Discussions
    Gadisha
    10 months ago
    It came out very nice! Even though I am not a Hindu I have always found Hinduism to be a very interesting religion and growing up I had some of these idols in my room, so I really love this Ganesha!
    Technically speaking I also like this project a lot, the molding was done very well and I love the paintjob, so very nice work!
    cdt1947Gadisha
    Reply 10 months ago
    Happy to know that you liked it. Thanks for posting the comment. Personally for me, I consider art to be a more spiritual experience than religion itself .
    Technically, this base figurine just happens to be having a good finish- so I choose this base. Have been trying with different materials for casting ( instead of plaster of Paris ) . Let's see.
    cdt1947DIY Hacks and How Tos
    Reply 10 months ago
    Thanks.
    What I figured is that it depends on how dilute the plaster of paris mixture is .
