Monitor Your Room From Anywhere in the World
49,115
564
46
Hi all, I am here to explain steps to make your home secure and monitored in real time even when you are NOT at your home. This interactive device will notify when something is wrong at your house. This device can communicate room status anytime to your smart phone through cloud (Thingspeak).
Lets get started
Supplies:
Step 1: Materials Required
1. Arduino UNO
2. Arduino Ethernet shield
3. Ultrasonic distance sensor (You can use a PIR sensor, if you want to. I don't have one so used distance sensor)
4. DHT11, temperature and relative humidity sensor
5. Gas sensor (MQ-2)
6. OLED display (optional)
7. Servo motor (This is optional, I used this to mount the distance sensor and screen the room while rotating)
8. Jumper wires
Step 2: Circuit
Here are the details of the connection
Note : A- analog; D- digital
Ultra Sonic Sensor - Arduino 9 (Range upto 4m)
(Note you can use PIR sensor which has a range upto 10m)
Vcc - 5V supply (Parallel connection via Breadboard)
GND - GND
Trigger - D8
Echo - D9
MQ2 - Arduino
GND - GND
AO - D4
DHT11 - Arduino (Temperature sensor)
GND - GND
Signal - D2
OLED Display - Arduino
Vcc - 3.3V supply
GND - GND
SDA - A4
SCL - A5
Servo motor - Arduino (optional)
GND - GND
Signal - D3
Step 3: Thingspeak Channel
Thingspeak is an open source cloud platform. You can send the sensor details to the cloud and get notifications to your smartphone or monitor your room via Thingspeak website.
Step 1:
Create an account in "www.thingspeak.com" website
Step 2:
Click "New channel" on your main home page
Provide the details of your channel like
1. Name
2. Description:
3. Fields: In our case, four fields are "temperature, Relative humidity, Gas Concentration, Intruder distance"
4. You can also give latitude and longitude of your room location
Step 3:
You can set this channel Public or Private as per your wish in " Channel settings" tab
Step 4:
Note down the "Write API" key number which is unique number to a channel created. Use this channel API number in your arduino sketch shown below
"const char * myWriteAPIKey = "xxxxxxxxxxxxxxx";
Step-5:
Here are the two steps you need to follow to view your room status on your smartphone
1. Download and install "ThingView" app from google play store. here's the link (https://play.google.com/store/apps/details…)
2. Type channel ID as "xxxxx"
attached are the pics you see in the app if everything works properly
You can also get notifications via twitter from "thingspeak" channel by setting the limits of the fields in "Apps" tabs. explore this section for more details....
Done..Compile and upload the sketch to your arduino and you are all set to stream your room data online....
Step 4: Sketch and Libraries
For this sketch to work, use the libraries attached.
Extract the files from rar file and copy them to arduino documents libraries folder.
Step 5: Conclusion
Let me know if you have any queries while following this instructable
Thanks
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    46 Discussions
    vandenbrande
    3 years ago
    Nice stuff... but i thought it was security camera stuff. I use my Security cameras and a hidden computer with teamviewer to watch my home from wherever i am, even in china. Everytime when i feel a little paranoia about my home, i take a look on my phone LOL.
    BobD21vandenbrande
    Reply 3 years ago
    Don't be paranoid about your home, we are all looking after it for you.
    EricS100BobD21
    Reply 3 years ago
    Not me. I have an overseas group of minions to watch his house for me.
    BobD21EricS100
    Reply 5 months ago
    Awesome ,are they available for hire,?
    vandenbrandeBobD21
    Reply 3 years ago
    Ah well... there is only 200 million hidden on the attic...lol
    Bhanu Kishanvandenbrande
    Reply 3 years ago
    yeah that was good. but i did this as a starting point for the next version. I didnt find a camera compatible to arduino and associated libraries so I tried something with Ultrasonic sound sensor. anyways thanks a lot for the idea.
    muhdaniq
    2 years ago
    i have succeed in compiling and uploading the coding..but the serial monitor shows nothing and thingspeak shows no result..please help me
    Bhanu Kishanmuhdaniq
    Reply 2 years ago
    Then there should be no problem with the syntax. Then do the following
    1. Check all your connections if they are as per the instructable.
    2. Check whether your sensors are working.
    3. Finally all seems alright, start trouble shooting with one of the sensors say DHT11/ gas sensor / ultrasonic sensor and try to figure out the problem.
    4. If you are sure all your sensors are working properly, then start looking at your serial connections like D0 and D1 issues.
    muhdaniq
    2 years ago
    why there are errors when compiling the coding in arduino software?
    Reply 2 years ago
    What are the errors? Can you post them? I can help you out if I figure them.
    LeeJ35
    3 years ago
    I also would like the schematics and circuit diag please
    NitinN2
    3 years ago
    Bro do you have the schematic and the connection to the arduino and the sensors...
    Bhanu KishanNitinN2
    Reply 3 years ago
    Okay, I will upload the schematic but will be available after 11th as I am out of station
    muhdaniq
    3 years ago
    can you show the schematic diagram for this project?
    Reply 3 years ago
    Any trouble in understanding the circuit section?
    NitinN2Bhanu Kishan
    Reply 3 years ago
    Yes I am unable to see the pin and the connections.
    Guna Sekaran
    3 years ago
    I need the circuit connection
