Moon Phase Beads and Bracelet!
1,374
45
7
About: I'm a black cat instagram-akatsukino_neko
Hellooo ^u^
Hope you enjoy this little instructable :)
Step 1: Materials
a ring
a needle(with a ball tip)
clay(I used air dry )
black paint(acrylic)
a brush
a hollow carved bead
Step 2: Creating the Shape(Full Moon)
Take a bit of clay and flatten it on the surface.Push the bead on the clay and carefully lift it up with the needle.
Step 3: Cleaning the Edges
Push the ring in the middle and take off the excess clay.You can go around with a knife too.Lastly clean off the edges with the needle and soften with the ball tip.
Step 4: Creating the Half Moon Shape
Repeat the first step for the half moon but keep the shape a bit on the left side.Then cut it in half with the knife.Clean the hard edges with the needle.
Step 5: Creating the Crescent Shape
Again repeat the first step but this time crate the crescent shape by pressing the ring on the clay.
Step 6: Adding the Hole
Using the needle create a little hole on top of the shapes and make it larger using the tip of a pen or a toothpick.If you want you can leave it without painting,it looks pretty cool in my opinion :)
Step 7: Painting
Okaay this step can be a little tricky just be careful :)
Hold it with the tip of a pen and paint reaaally lighly on the clay.So that you only paint the surface.
Step 8: Bracelet
Now the beads are done you can make everything you want!
I just attached one bead to a bracelet but you can make a choker necklace too :).
Sorry I couldn't take pictures when I was making the bracelet...
---- DREAMCATCHER-----
I made a bookshelf decor to-------> Bookshelf Decor
I hope you enjoyed!
If you have any questions leave it below
And if you make anything with them I want pictures :*** :)
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    7 Discussions
    ellnbchristi
    2 years ago
    Fabulous project, thank you! You could also make torch fired enamel moons (and/or stars) for this project...very easy to do and loads of fun!! Not to mention gorgeous! Thank you so much again for sharing your great projects with us. Have a very blessed and happy day!!!
    Leiana2213
    2 years ago
    Awesome! I'll have to make a bunch of these as soon as I can! Where did you get the hollowed bead?
    hinagikuLeiana2213
    Reply 2 years ago
    well it was a piece from a necklace that I already owned but you can find a lot of smilar ones at craft stores I'm sure :D
    hinagikumassahi
    Reply 2 years ago
    yeah I've been obsessed with them too :D
