Mosaic Shell Pendant
3,030
90
4
My cousin's birthday is near so I make her this pendant. This is my first jewerly project so there are some imperfection. It still look nice though.
I'm very sorry because I didn't take much photo in this project.
Step 1: What You Will Need
- A sheet of metal + some solder
- Shells (You need different kind of shell to make the mosaic effect)
- Small glass dome (this is the hardest piece to find, I got mine from an old pendant)
- Silicone and epoxy
- Some basic tools like a copy saw, pilers,...
Step 2: Make the Base
The base is simply a ring soldered on a sheet of metal, after that solder on a loop to put a chain through. The ring should be a little bigger than the glass dome. After that I polished the metal so it look better (you can do this after everything is done)
I won't go into details on this step, you can check out this video for the process: .If you don't know how to solder, you can read Mrballeng instructable: https://www.instructables.com/id/How-to-solder-amat... . You should check out his project too, he is very talented.
Step 3: Make the Shell Mosaic
Here's the fun part. First you need to design the mosaic pattern, then pick out different type of shell and cut into the pieces, after that sand down each of the surface till it's flat. Remember to mark each pieces or you'll mess up the pieces.
After everything is cut and sanded, glue them face down on a sheet of plastic and check the fitting. Feel free to do a few sanding to adjust the size.
Once the glue dried, mix up some epoxy and spread them, fill in the gap if you have them. You don't have to worry about the bumps
Step 4: Flatten the Shell Mosaic
One way to do it is by sanding. If you have a dremel like me, this is how you do it:
First take a sanding guide attachment and glue 2 pieces of wood on the side, making a rail. Then hot glue the shell pieces face down on a piece of wood. After that's done, attach on a cutting wheel, set the height, turn on the dremel and side the shell piece on the rail, cutting the execess and make the shell piece flat. I'm sorry but I can't seem to explain this in a more coherence way.
After that, fit in the shell piece using some silicon
Step 5: Glue on the Glass Dome
Add more silicone on the surface, put on the dome and squeeze out exess. Remember not to put too much pressure or the glass dome will break (as shown in the picture).
For this pendant, you cannot press on the outter ring to hold the glass dome because water can still leak inside. That's why I have to use silicone.
Step 6: You're Done
That's it for this instructable. I am very sorry since I don't have much time to right a detail instructable.
Anyway hope you enjoy it.
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    4 Discussions
    Leiana2213
    3 years ago
    How did you get what appears to be flattened shell bits?
    ShizenLeiana2213
    Reply 3 years ago
    First I use sand paper to flatten the surface. Then in step 4, I cut away the uneven part, which make all pieces has the same thickness
    I don't know if I'm making any sense or not :v
    lgooms
    3 years ago
    It's beautiful. Did you have to separate the mother of pearl from the shells? If so, how did you do that? Or did you buy them that way?
    Shizenlgooms
    Reply 3 years ago
    I don't know tbh, I only used a wire brush attachment on my dremel and gave it a good polish.
