Motor Makeover
37,903
372
24
About: I made a book with some new projects in it! It's called Marvelous Makeable Monsters. Check it out here: https://amzn.to/2xN1uWj The Oakland Toy Lab is a community-based wonder lab for students to build, ti...
Does it feel like your motor is a little wound up? Time for a makeover!
Motors are everywhere, from appliances to toothbrushes to tools. Just about anything that uses electricity and moves. This exploration takes a look inside them to see how they work and experiment with making a more powerful one. And it's going to look great.
  • What: Motor Makeover
  • When: Oh, it's time.
  • Concepts: electromagnetism, physics, circuits
  • Time: ~15 minutes to make
  • Cost: ~$3, all re-usable
  • Materials:
    • DC Motor
    • Batteries and Pack with leads
    • Magnets x 2
    • Small pieces of wood
    • Alligator clip leads (optional)
  • Tools:
    • Hot glue gun / hot glue
Let's motor!
Step 1: Test Your Motor
Let's see how this puppy runs!
Make a flag of tape to put on the motor spindle to make spinning easier to see. Load up your batteries, attach them to the clip leads, and attach the other ends to the rear tabs of the DC motor. Feel the tape with your finger (it makes great shapes, too). What happens when you change which leads the black and red go to?
Step 2: Inside Out
Time to pop it open.
Turn your motor over to look at its bottom. Use a pair of pliers to bend the two metal tabs out, which were holding the plastic bottom. Then grip the plastic with the pliers, and pull to remove. What do you see inside? Let's pull it out and examine.
Step 3: Motor Anatomy
Starting from the metal tabs, the first stop is at the brushes. If you follow from each tab, you'll see that the brushes are made of springy metal and have grooved blocks at the end. This allows it to have constant contact with the motor as it spins.
The brushes are in constant contact with the commutator, which has three panels on most simple DC motors. As the motor spins, the brushes slide over the panels of the commutator, and at certain points in the rotation reverse the polarity of the current. It's an incredible trick, and also involves the way the armature windings are oriented as they connect to the rotor.
The motor functions as an electro-magnet, but which flops polarity halfway through its turn. The permanent magnets on the outside provide a common field. The electro-magnet moves partway attracting north to south. As it gets there, instead of locking in that orientation like most magnets do, suddenly its poles flop and it wants to be in the opposite orientation. With the rotational momentum it has, the motor simply keeps on spinning in the same direction.
A couple of things to examine include:
  • the wiring pattern of the windings
  • what having three commutators means as the spindle rotates
  • what north-south orientation are both of the permanent magnets
Step 4: Make a Base
Raise your motor to the sky!
With some wood extras, it isn't too hard to make a base for our motor to spin on. There are many solutions to this, but I cut two short pieces of dowel, glued them on a stirring stick, and glued the motor base on to that. I left the two motor tabs exposed on the sides for easy connecting.
Step 5: Make a Motor
Here's the fun part!
You can set up your motor however you like. You can put a tape flag or leave it, but the essential part is grabbing your two extra magnets to play with. Use the gator clips to hook up your motor. Putting them close to the rotors in the right orientation will get the motor running elegantly and extremely quickly.
Here are some wonderful things to try and notice:
  • What orientation do the magnets have to be in to make the motor spin? Try flipping them mid-way.
  • What happens when they get closer? Farther away?
  • What happens when just one magnet moves away?
  • Try starting your motor with one hand with only one magnet. Why does it do what you see?
  • What happens to the circuit if you don't put magnets near? (heat)
  • What happens when you add more magnets in a ring?
  • Try substituting your magnets for stronger ones. What happens?
  • Notice the spark and arcing happening where the brushes are touching the commutators.
Hope you enjoy this electronics take apart, which gets at the core of how electricity and motion play nice together. Open things up, get amazed, and as always, keep exploring.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    24 Discussions
    SerhiiB1
    2 years ago
    Made It, but bigger :)
    InsomniCAT
    3 years ago
    OMG! Guys! This is where we share, explore, discover, and invent. . . whatever! This comments section is supposed to be about the 'ible, not for you to nitpick and make noise, so stop getting your panties in such a wad.
    Dave P
    3 years ago
    This is a far reach, just a shot in the dark question. And I am sure someone will think it's a stupid question, but who cares. Can the same trick here be used on a generator.
    samratdebDave P
    Reply 3 years ago
    As far as I know yes, it can be. When the motor spins it produces electricity, you can simply connect the two wires out of the motor to a LED and see it glow as and when the motor spins. Its the same concept of the generator.
    KenP30
    3 years ago
    A constructive side-note:
    Its A Commutator (singular), and you are referring to it's 3 segments (plural).
    also
    It's A Rotor (singular), it is the whole rotating structure and contains multiple armature windings (plural).
    Pedantic?
    Perhaps, but someone needs to arrest America's atrocious massacre of English grammar and spelling.
    kermykieKenP30
    Reply 3 years ago
    A nice simple experiment for the children. Why complicate it with concerns over grammar. However your use of "its, it's, and the following capital A" in lines 2 and 5 are also grammatically incorrect. just incase it is important to you. :-)
    dbanks4KenP30
    Reply 3 years ago
    Really? Just stop. No one cares and the piece still communicates perfectly. Grammar Nazis...sheesh.
    KenP30dbanks4
    Reply 3 years ago
    Ha Ha !!
    You must be one who sodders your wires together?
    Perhaps using Aloomin-um sodder ?
    I guess it's unimportant when your education stops at grade 6
    throwedoffdbanks4
    Reply 3 years ago
    Yes, we do care. Just because you're lazy and don't want to speak eloquently or write grammatically and syntactically correct doesn't mean the majority of other people are the same.
    JamesGray38KenP30
    Reply 3 years ago
    KenP30 I totally agree.
    Next up, someone needs to clue in America the difference between your/you're, then/than and there/their/they're.
    itsmescottyKenP30
    Reply 3 years ago
    Absolutely correct concerning America's grammatical downward slide but what can be done, School? Not a prayer of that happening! As with Rafununu's comment - bi and multi lingual people have it hard enough without having common usage being corrupted and have to deal with idioms. I conversed with technical French and Italian and got along well BUT my conversational usage generally had my counterparts preferring we speak English, sigh.
    SteveA35KenP30
    Reply 3 years ago
    @Ken- Had to laugh at your comment; you're not alone. An hour ago I emailed a candidate with a suggestion that he locate a recording of an on-air interview he did this AM.
    During the 10 (or so) minutes, he must have punctuated his sentences hundreds of times with:
    "Ya know?"
    Ya know? LOL
    rafununuKenP30
    Reply 3 years ago
    I agree at 100%. I'm french and cannot stand misemployed words, whatever could be the language.
    Mjtrinihobby
    3 years ago
    I love the last line in your final step! It's the hobbyist's anthem.
    Mark 42Mjtrinihobby
    Reply 3 years ago
    "Open things up, get amazed, and as always, keep exploring."
    laminceesayMjtrinihobby
    Reply 3 years ago
    Ha ha ha ha, i got your jokes bro. Couldn't help but reply to your reply.
    BernyM1
    3 years ago
    I think you'll find that the brushes are not magnets (Why would they need to be? They have to maintain contact with the brass commutator segments, so being magnetic will not help. It's the springs that do that job.). They are usually made of carbon for its self lubricating properties and electrical conductivity properties.
    redroosterBernyM1
    Reply 3 years ago
    Hmmmm, I wonder how a graphene impregnated polymer would go instead of carbon?
    qdogg
    3 years ago
    I wonder how this would play out with a big@$$ motor like from a golf cart? Where's the %#*+! bandaids??
