Motorcycle Chain Cleaning & Lubrication - Ninja 650/Z650
1,972
16
6
Published
Introduction: Motorcycle Chain Cleaning & Lubrication - Ninja 650/Z650
About: Just a guy who doesn't know when to quit, and is constantly in search of a solution to a problem that doesn't exist yet.
So it's time to clean and lubricate the chain, huh?
It might not be the most glamorous job, but it's necessary if you want your chain and sprockets to live a long life. It's a pretty basic job, but if you're new to DIY motorcycle maintenance or want to see if there are any tips and tricks, keep reading. Today I'll be cleaning and lubing the chain on a 2017 Kawasaki Ninja 650 (Z650).
Difficulty: Easy
Tool Requirements: Basic
Time: 30 min
Cost: ≈0$
Step 1: Is Chain Oiling Important?
Next to tire pressure and chain tension adjustment, chances are the chain is one of the most neglected things on your bike. Which is a pity, considering how bad it can be when things go wrong. To make matters worse, it should be done pretty often. Kawasaki recommends lubricating the chain every 400 miles (600 km) on their bikes. I personally just try to do it once a month after washing the motorcycle.
Why do chains have to be oiled?
Motorcycle chains have come a long way, believe it or not. These days most bike chains have O-rings between the pins and the plates which keep the lubrication in. The main purpose of chain lubrication is actually to clean the chain from debris and keep the o-rings supple. If chain lubrication is neglected, grit can get past the o-ring, or the o-rings can shrivel up until they break off. For a more detailed read on the topic, checkout Wikipedia's entry on Roller Chains.
However, I won't lie to you either. Plenty of riders neglect their chain the same way most cagers neglect tire pressure. But you're better than that. Maintaining your chain will go a long way with regards to safety and avoiding trouble down the road. Plus, the day you try to sell your bike, it's the first thing a buyer is going to look at. If your chain doesn't look well taken care of, what are the chances the rest of your bike is? For more info, check here.
Step 2: What You'll Need
Thankfully, this maintenance job is a cheap one. A bottle of lube will go a long way, and most of the tools you'll already have or will only have to buy once. As far as what I used, it's as follows:
  • Garden hose - For rinsing the bike and chain, or feeding the pressure washer.
  • Motorbike Rear Spool Stand - Like any motorcycle how-to, you knew there was going to be a rear stand involved. If you don't have one already, now would be the time.
  • Bike Washing Soap - We'll be washing the bike alongside the chain to do two things at once, so you'll need some soap. This is what I used. It's main advantage is that it washes and waxes the bike simultaneously. Though not as good as handwaxing, it comes close as far as water beading goes.
  • Thick Sturdy Cardboard - If you have a large cardboard box available, great. If you have some waterproofing spray around too, even better. You'll see why later.
  • Box Cutter or Heavy-Duty Shears - I used this to cut the cardboard.
  • Motorcycle Chain Cleaning Brush - This little thingy is actually pretty good for cleaning motorcycle chains. And it lasts pretty long too (a few years used with care).
  • Chain Lube- I use DuPont Teflon Chain-Saver Dry Self-Cleaning Lubricant. It consistently proves itself to be one of the best chain lubricants out there. Plus, it's self-cleaning which avoids me having to buy another separate product. To boot, it does pretty well regarding preventing chain rust (take it from a South-Floridian).
  • Pet Training Pads - One of the biggest hassles of having to lubricate the chain frequently is clean up. I've found these to be a godsend regarding reusable ground cover.
Step 3: Clean Your Bike
The first step would be to clean your bike. Yup. Don't kid yourself. Your bike needed a cleaning anyway, so why would you just clean the chain? Plus, regular automotive soap is all you should need to remove superficial road grime and grit from the chain. This is how I do routine washing. I've got another guide where I show how to do a full motorcycle detailing.
Anyway, the interval at which the chain should be serviced more or less matches how frequently most people wash their bike. That's why I'd recommend doing both together. Furthermore, you should lubricate your chain anytime it gets soaking wet. Applying a decisive stream of water will do great to remove any dirt, grit or mud on the chain.
That said, lets rinse off the bike. I used a portable electric pressure washer.Take notice of the wide water pattern which does not focus water on any one point. While bikes are "water-resistant/waterproof", I'd really avoid using any sort of concentrated high pressure turbo nozzle on them since it can lead to issues. Especially on the chain. The fanned out water nozzle used here shouldn't harm it. In case you're wondering, I'm using an 6-in-1 quick connect nozzle and an adjustable pressure regulator to make the water stream softer.
The next step is to cover your bike in soap suds! My weapon of choice is a foam cannon full of Wash & Wax Soap. By the way, if you don't have a pressure washer and would still like to use a foam cannon with your garden hose, you can use this - Foamaster II Foaming Cleaning Sprayer. Make sure to get some regular auto cleaning soap on the chain. It won't hurt. Let the bike soak in the soap. Once all the crud is softened give it a once-over with a microfiber mitt or sponge. Regarding the chain in particular, we'll take care of that in the next step.
Note - Do not use a high-pressure washer directly pointed at the chain. At least not at its highest pressure, and not carelessly. If you do, the jet stream should be strong, but not so much that it would hurt your hand if you were to point at it (don't do that). Use a pressure regulator if needed. The only thing worse than not lubing the chain is getting water past the o-rings.
Step 4: Brush the Chain and Then Rinse
To help remove any superficial rust or grime, I'd definitely use a chain cleaning brush. They don't cost very much and last very long (about a year), so it's a worthwhile tool. Especially considering how frequently you're supposed to lube the chain! Plus, it works so well that it is part of the reason why spending money on a chemical chain degreaser is unnecessary.
Here is where the rear stand comes in useful, as it allows you to rotate the wheel to clean the whole chain. Honestly, I can't even imagine cleaning a rim or lubing a chain without one. If you don't have swingarm spools or a stand, now would really be the time to consider one.
Once you've given the chain a few passes with the brush, rinse everything off with water.
What about Chain Degreasers?
Personally, I am not fond of sprayable chain cleaners. At least not for regular use. If your chain gets dirty enough to need a degreaser between lubrication sessions, either you're lubing wrong or waiting too long between lubing sessions. Or your an adventure bike rider. In that case, if your chain gets caked in mud then you're doing things just perfect. I simply don't see the need to spend the money and space on an extra unnecessary bottle. I much rather an all-in-one chain lubricant which provides both cleaning and lubing like the one I'll be using here.
By the way, if you ever do get your chain dirty enough to need extra cleaning, or it has a bit of rust, you can use WD-40 to clean the chain. While WD-40 is a mediocre lubricant at best, it's an excellent cleaner. Rather than buy a different product, just use the can of WD-40 you probably already have. Just don't use it for "oiling" the chain.
Step 5: Make a Rim Protector
Make yourself a semi-permanent rim protector to keep wax or lube from getting on your rim. The worst part about having to lube your chain frequently is how it splatters the rear rim full of gunk (yeah, the driveshaft BMW crowd is free to laugh - We deserve it). Even if you're careful, lube always seems to end up on the rim.
By making a little makeshift protector you can save yourself a lot of trouble, cleaning and hassle down the road. I just used one of the super thick cardboard fruit crates from Costco. Since I wanted it to last (and I live in "not always shiny, but always humid" Florida), I coated it with a waterproofing spray. It will make the cardboard a little bit more sturdy, as well as help it stay sturdy. I used two coats. That should keep the humidity and any water drops from turning it mushy.
Just use a box cutter or some scissors to cut it similar to what is pictured above. It should be able to fit on the bike while it's on a rear stand, and should cover as much of the rim as possible.
Step 6: Oiling
Now it's time to lube the chain! My personal favorite for this is DuPont Teflon Chain-Saver Dry Self-Cleaning Lubricant. It has nearly 5 stars on Amazon and it's consistently regarded as one of the best products among reviewers. It’s easy to apply, non-sticky (so it doesn’t attract dirt and grit), contains Teflon and Molybdenum and it quickly dries to a clear waxy finish. Sounds good enough to me when it comes to chain lube.
Personally, I like using the straw accessory to really be able to aim the lube. Where you want the oil to go is on both sides of the link's pins (where the o-rings are). Applying it anywhere else is mostly just for rust prevention and cleaning. Also, as you lube the chain, move the wheel so the lube drips from the top of the link to the bottom, lubricating it entirely.
Note - I like squirting the lubricant at the chain near the rear of the sprocket. I find it to be the most comfortable location given how conveniently exposed it is. Since I use a very runny liquid spray lubricant, I can be confident that the lube will distribute itself around the rollers and O-rings. Any lube that drips on the sprocket will simply find it's way down to the chain links below it, and all will be perfectly coated. After all, the rollers roll so it isn't like there is an "inside" or "outside" to the chain link. Others may prefer to apply the lube elsewhere. Just do whatever works best for you.
Though this lube is pretty clean (especially compared with other products), it will drip. I guess that's part of the "self-cleaning" feature. That's why I've gotten used to placing pet training pads (don't laugh) under the bike. If you've seen my other DIYs, you might have noticed it in my oil change guide or the control cable lubrication how-to. They're reusable and will save you a lot of time with cleanup.
Pro Tip - Mark your chain
Use a permanent oil paint pen to mark your chain. Nothing is more annoying while lubing a chain than not knowing where you started. Some chains come with a colored link, some don't. If yours doesn't do yourself a favor and mark it yourself. And surprisingly, it won't get rubbed off with use (I've had my chain marked for over a year). It definitely works better than a Sharpie.
Step 7: Clean Off Any Excess
After applying some lube, there still might be some black gunk on the chain. Or to be more accurate, there will be some black gunk on the chain. If you're feeling motivated, give the wheel a few turns while you wipe the chain clean. The chain will disintegrate normal paper towels, so either be ready to use a bunch of them or use some disposable shop towels instead. They seem to fare much better.
Once you're done wiping, apply a quick and light last coat of lubricant if you want. I did.
Step 8: Clean-Up
The only thing left is to let the lube dry. You want to give the lube about 30 to 60 minutes to dry, rotating the chain at least once or twice so any wet lube gets distributed. Don't remove the ground cover until you're sure it's dry enough to not be dripping anymore. Especially near the front sprocket.
Step 9: All Done!
All done!
That wasn't that hard, was it? If you're really motivated, now would probably be the right moment to take care of the chain tension adjustment and alignment. Thankfully, there's a DIY for that, too. Also, if you're curious about what other things I've done to my bike, check out my 2017 Kawasaki Ninja 650's Mod List. You might find something interesting.
Hopefully this has provided some insight on one of the most common motorcycle maintenance task. And if you have any tips and tricks of your own, feel free to leave them in the comment section below. I'd love to hear them. If you found this interesting, click the 'Follow' button to get notified of similar projects in the future, or check out my profile to see what other projects I've been up to — here are some others you might like:
Step 10: Addendum - What About Lubing a Hot Chain?
Some people like lubing their chain hot. I'd agree that there might be some merit to that, provided it isn't too hot. However, in the real world I think that the cons are greater than the pros. By all means, lube it right after a ride, just don't obsess over whether it's still hot by the time you're applying oil or wax. You're free to disagree, but that's my opinion.
If you lube your chain hot, it's going to be while it's still dirty after a ride. If you're in the middle of a trip, that's perfectly fine. Your chain is probably pretty clean anyway, if you cleaned and lubed it before the start. But if you're lubing a chain as part of the bike's monthly maintenance, then it will be relatively grimey. Brushing it off, applying any detergent and rinsing it off is going to leave the chain much happier. And by then the chain is already cold.
Given that the main purpose of chain cleaning and lubrication is to remove debris that may damage the o-rings, as well as condition the o-rings to keep them pliable, heat isn't very important. The gap for the o-rings combined with the relatively big tolerances are large enough for any expansion due to heat to be minimum. I sincerely doubt that there would be measurable real-world longevity benefits to lubing a hot chain. Though if there is proof of the contrary, someone please message me with a link. I'd be happy to look at it and correct myself.
All in all, if you want to lube your chain hot without cleaning it first, go for it. If you're capable of thoroughly cleaning it before it's cold, awesome. But for the rest of of us riders that find that to be more trouble than it's worth, lubing a cold or lukewarm clean chain is perfectly fine. In any case, either method is infinitely better than the riders not lubing it at all.
Spotless Contest
First Prize in the
Spotless Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    6 Discussions
    Hey great guide for motorcycle enthusiasts like me..nice bike indeed..thanks.
    Thanks! Sometimes it's nice to see how other people do even basic things like this. You never know what you might learn. And if it helps some other new rider even better. God knows the motorcycle industry needs new blood!
    Nice instructable - nice cleaning...but...
    You're doing something wrong: don't lube the chain on the outside of the sprocket.
    Lube the chain from the inside and make sure the O-rings are lubed! Centrifugal force will push the lube to the outside once you begin to ride. Don't bother to lube the sprocket, there is no advantage in it to do so, except to gather more gunk from the road.
    Btw: best results one gets by lubing the chain immediately after a ride, when the chain is still warm.
    Beautiful bike!
    Good luck...
    Ed.
    Hey there Ceddy,
    I'm not sure what you mean by "doing it wrong". I pointed out the same thing you're saying both in the tutorial and the pictures. Pretty much verbatim to what you said so I don't see the contradiction.
    Regarding the chain being warm, while I agree that would be nice I don't see it as too practical. By the time you're done cleaning the chain, it's cold. At least if you really clean it rinsing it with water. And I'm not going to ride it (and dirty it) again just to get it warm. The minor potential benefit (which doesn't transform into any real world difference) doesn't outweigh the hassle.
    Hey there also,
    The fact that I commented, has its origin in the pictures in step 6.
    The interested viewer sees that the nozzle of the straw accessory is pointed to the outside of the chain and to the center of the sprocket.
    I didn't mean any disrespect ( I *do* like your instructables ) but I think it would serve the potential-chain-cleaner better, would you have shown a picture where the straw is pointed to the inside of the chain and clearly targeted at the O-rings....
    And by the inside of the chain I mean that part of the chain between the front and rear sprocket closest to the ground.
    Please don't loose any sleep over it, I am a somewhat overreacting person when it concerns some details...
    Keep up the good work!
    Greets from Flanders..
    Ed.
    Haha no worries, thanks for the input. I just wanted to make sure that the project was unambiguous as possible. Greetings from the USA!
