Mousetrap Vehicle
29,362
8
This instructable is not for the faint of heart, possess weak stomach, nor a phobia of calculators. Before we start, defining what a mousetrap vehicle should be done. A mousetrap vehicle, as implied, is a vehicle solely powered by the potential energy of a mousetrap(s).
There are three main types of vehicles; long range, high speed, competition. The defining characteristic of the long range vehicle is it's large drive wheel. For the high speed vehicle its, you guessed it, it's high speed. As for the competition vehicle they must comply with guidelines most likely for school or Science Olympiad.
This Instructable will be for the designing and building of a mousetrap vehicle following the rules for Science Olympiad devision C for the 2010 - 2011 academic year.
Supplies:
Step 1: Design
To start your design you must have nothing more than:
*a writing utensil
*paper/notebook(preferred)
*calculator
However, if you want to design a vehicle that you will be proud to put your school's name on you will also need:
*a graphing utility
*ruler/straightedge
*caliper
* micrometer(if you have a thing for sig figs?)
**a good foundation in mathematics
**Those who do not possess these skills, yet. Have no fear there are countless resources at your disposal. For example the internet, public libraries, and your teachers. The internet, your on it now. Public libraries, they are free and full of helpful underpaid knowledgeable city employees know as librarians. The other option is your teachers. Who would be enthralled to have a student or non-student ask for their help and guide you. That is if you don't owe them any work.
Here is the SciOly wiki on mousetrap vehicle, an indispensable resource.
After reading the rules, read them again. The last thing you want to hear is, after all your hard work, "your disqualified."
Step 2: Materials
Does this step need an explanation? The answer is yes.
You will need these items:
*mousetraps(different kinds)
*wood(balsa preferred)
*bearings
*super glue
*epoxy
* lubricant(not dw-40, gt-85, or pw-50. lithium based preferred)
*CDs
*rubber bands
*fishing rod(old,cheep)
*sip ties
*fishing line
* aluminum rod
*washers
Tools needed:
*tools listed in step 1
*X-ACTO knife or utility knife
*hacksaw
*C clamp
*scissors
*measuring tape(7m min)
*spring scale
*protractor
*computer or calculator
Step 3: Data Collection for Spring Constants
Lets start with a fun calculation of the spring constant of different types of mousetraps.
you will need:
*C clamp
*spring scale
*paper
*writing utensil
*protractor
*anything that can do a liner regression (very helpful)
1. Make a table with three columns labeled; #, angle(deg), force(N).
2. Clamp the mousetrap to the edge of a table.
3. Measure the length of the mousetrap lever arm in meters.
4. Measure the force of at least four different angles. I used {0, 90, 130, 180}. Keep the spring scale perpendicular with the arm.
5. Repeat steps 1 - 4 for each mousetrap
6. Clean up your lab equipment
7. Create a new table with columns labeled; #, angle(rad), torque(N*m).
8. Convert the angle column from degrees to radians
     a) multiply by pi radians
     b) divide by 180 degrees
9. Convert the force column to torque
     a) multiply by the lever arm in meters
10. repeat steps 6 - 8 for the data sets of each mousetrap
Step 4: Calculation the Spring Constant With Computer
This method for calculating the spring constant will be using:
*software for data regression (I suggest QtiPlot )
1. Start QtiPlot
2. Enter the column labeled "angle" into the column labeled "x"
3. Enter the column labeled "torque" into the column labeled "y"
4. Click Analysis -> Fit Liner
5. record the a and b values, the "a" value is the spring constant.
6. repeat for the different mousetraps
Step 5: Calculating Equilibrium
Knowing the values of a and b of the different mousetraps makes this step very easy.
1. negate b
2. divide by a
3. record the value
3. repeat for each mousetrap
*we will represent this value with the Greek letter theta � measured in radians
Step 6: Calculating Potential Energy
It is yet again time to pull out the calculator.
1.  The potential energy stored in the spring of mousetrap is equal to a * ( ((pi + �)^2) - (�^2) )
2. repeat for each mousetrap
3. Now lean back and enjoy an ice-cold beverage (not really, you are far from finished)
Step 7: Calculating Arm Length
calculating proper arm length is very important:
you will need:
*paper
*writing utensil
*calculator
the length of the arm is equal to ((the length of the track * (radius of the axle + radius of the string)) / (2 * radius of the axle))
Step 8: Velocity
We could continue and derive the formula for the efficiency of the vehicle, but that information is off limits until competition season is over. Feel free to derive it, here is a hint "Energy Conservation."
Step 9: Building the Arm
To build the arm you will need:
*fishing pole
*hacksaw
*ruler
*utility knife
*clamp
*sandpaper
1. mark on the fishing pole with the utility knife how long the correct arm length is.
2. clamp the fishing pole to a table
3. cut with hacksaw
4. sand down the sharp burr left from the hacksaw with the sandpaper
Step 10: Cleaning Bearings
To clean the bearing you will need:
*bearings
*lubricant
*needle
*bottle with cap
1. with needle remove the dust covers of the bearings (don't throw away)
2. partially fill the bottle with the lubricant
3. place bearing in bottle
4. cap bottle and shake
5. repeat step 1 - 4 for all the bearings changing lubricant as needed
6. wipe off excess lubricant from the bearings
7. put the dust covers back on
Step 11: Building the Wheels
To build the wheels you will need:
*super glue
*CD
*rubber bands
*washer
1. super glue washer on the center of the CD
2. stretch rubber band around the CD
3. repeat steps 1 - 2 for each CD
Step 12: Building the Drive Axle
This step requires:
*aluminium rod
*lathe
*ruler
*hacksaw
*zip tie
*super glue
1. cut a 15cm segment of the aluminum rod
2. place on lathe and thread both ends
3. place the zip tie off center and tighten it
4. coat the zip tie in super glue. make sure to get super glue in the ratchet.
Step 13: Building the Front Axle
This step requires:
* threaded aluminium rod
*ruler
*hacksaw
1. cut a 15cm segment of the threaded aluminum rod
Step 14: Building (mousetrap)
remember calculation the potential energy stored in the mousetraps? Sure you do, you may have thought all that was for not. It was actually very important. You will want to use the mousetrap with the most energy stored.
you will need:
*super glue
*epoxy
*balsa
*utility knife
*ruler
*pliers
1. super glue the mousetraps together
2. remove the springs with the pliers from the arm. So that the arm moves freely
2. cut a strip of balsa wood to link the to lever arms of the mousetraps
3. epoxy the arm and cross brace on the the lever arms of the mousetraps
4. hold until epoxy sets
5. leave alone until the epoxy cures, in about ONE DAY.
Step 15: Building the Chassis
This step will require:
*utility knife
*super glue
*ruler
*writing utensil
*balsa wood
1. draw a rectangle on the balsa wood
    a) with a length greater than the length of the arm plus half the length of a mousetrap
    b) and width of the diameter of the bearing
2. cut out with utility knife
3. repeat steps 1 - 2 7 times, you will have 8 strips of balsa wood.
4. super glue 4 strips together.
5. repeat step 4
6. cut out semicircles at the ends of each set of laminated strips
7.
Step 16: Building the Cup Pusher
building the cup pusher will require:
*ruler
*utility knife
*balsa wood
*super glue
1. cut two strips 1cm by around 5cm
2. super glue them together
3. cut four strips 1cm by 3cm
4. then chamfer the end of each
5. super glue two strips together
6. repeat step 4
7. glue the two strips from steps 3 - 5 onto the first laminated strip
Step 17: Building Chassis Supports
This step requires:
*balsa wood
*utility knife
*ruler
1. measure the width of the main laminated support
2. measure the width of the mousetrap engine.
3. subtract twice the width of the main laminated support from the width of the mousetrap engine
4. cut six strips of balsa wood and laminate them in sets of two
Step 18: Final Assembly
Now that we have all the parts of the mousetrap vehicle the only step left in building is piecing it together.
1. put the bearings and wheels on the axles
2. glue on the axles to the laminated balsa strips ends
3. glue the mousetraps onto the laminated balsa strips with the end of the fishing pole directly above the drive axle.
4. glue on chassis supports, one on the drive end, middle, and front
5. mount the cup pusher to the chassis support on the side with the mousetraps, the front
6. glue the free end of the fishing line onto the drive axle
7. glue on a toothpick so that one end is at most 1cm from the ground
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    3 Discussions
    csbrocket3
    6 years ago on Introduction
    Hello. I love ur instructable. I to am in science olympiad and want to know if you have any way to help me make my car go straight. Plese respond asap!! And thank you
    Jaycub
    8 years ago on Introduction
    I am in that moustrap competition! I'll see you watching in the audience while my friend and I accept our first place medals at nationals.
    sJaycub
    We'll see about that last part, our state competition is in two weeks. I hope you are a worthy adversary. I built another that was much better, but it's too soon to give out that information.
