Multi-Layer 8-bit Stencils
59,517
325
41
About: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
Love the old 8-bit video game characters and want to put them on stuff around you like your dresser, wall, or sleepy dog? Then make a stencil for it! It's a great way to try out multi-layer stencils. You can go for a clean look or get a little messier for a distressed look like above.
Have a character in mind? Excellent. Here's how to do it.
Step 1: Find a Character
8-bit characters are great because they're blocky and don't use too many colors. Super Mario and Link only use three colors and Megaman is still reasonable with five.
So just go on a search for images. Google is your friend here. That's how I found this image for the wizard from Final Fantasy.
Step 2: Outlines
Now you will need to look at the image and decide how you will paint it in a series of layers. This image only has 4 colors, but it needs 5 layers. The black will be the base coat and then there will need to be another black layer on top top for the shadows of the robe.
For either method below, start a new file that is a printable size. I used 10" x 8"
I used Illustrator to trace the outlines with Live Trace. That process goes like this:
 - Drop image into Illustrator
 - Select Live Trace/Color 6
 - Expand the trace
 - Duplicate the layer as many times as layers you will need.
 - On each layer, delete everything except for the color you want
 - Convert all of the shapes to a black stroke with a white fill
For Photoshop or GIMP, you can do this:
 - Make new layers for each stencil layer
 - Trace the outlines of the colors for each layer
Step 3: Add Registration Marks
Registration marks are the key to making a multi-layer stencil. These let you easily align the different layers when you're painting.
To do this just add a new layer on top and create two triangles in it. One on either side of the character. The farther away they are, the more accurate they are.
Step 4: Print Each Layer and Cut
OK, time to get ready for the real world.
 - Hide everything but the registration layer and the top color outline and print it out.
 - Hide the top color outline, show the next color outline, and print it out.
 - Repeat until you have all of the layers printed.
Now take out a razor and cut out all of the black lines. Fortunately, they're all straight so it's easy if a bit tedious.
Attached is the PDF for the wizard here.
Step 5: Prep the Board With Paint and Wax
If you want to just do a regular stencil, you can skip this step. The goal here is to prep the wooden surface so that it can be easily "distressed" later.
 - Paint the board with a coat of brown paint
 - Rub the surface with wax. I used a block of beeswax, but I've heard crayons work, too.
 - Paint the board with a coat of off-white paint
Step 6: Registration Tape
Now we'll be adding registration marks, but don't want those marks to stick around. So we'll be using some painter's tape to help out.
 - Place stencil on board
 - Put small pieces of painter's tape under the registration marks
 - Take a black pen and outline the registration marks onto the painter's tape
Presto! You now have two registration marks that will guide your painting and won't leave a mark.
Step 7: Paint, Paint, Paint
For each of your layers, the rest is easy. Just place the stencil on the board so that the registration marks and holes line up and paint. Let that layer dry and do the next.
Want to put your character more places? Do the whole thing again!
Want a grungier look? Add some splats and drips for good measure.
That covers the painting. For distressing there's one last step...
Step 8: Roughen It Up
Take some very rough sandpaper, I used 40 grit, and rough up areas where you want the paint to flake off. The places where the paint is on top of wax will have a weaker connection and come off easier. You can only subtract here so be careful not to go too far. Roughen the piece up, look at the whole thing for a bit, and then do more if you want.
That's it!
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    41 Discussions
    flammaefata
    4 years ago
    Saw this on 9gag and it looks so similar to yours:
    http://9gag.com/gag/avgWQy5?ref=android
    flammaefata
    6 years ago on Introduction
    Thanks so much for your Instructable! It's the first one I've done and I'm very proud with how it came out :D
    I got scraps of wood (the type you use in cupboards that's just chipboard painted over) and sanded them down a bit for the paint to stick. I used cheap-ish acrylic paint. I didn't do the extra distressing/wear steps like you did though. I got pics of Super Mario Bros 3 and went through the time-consuming effort of drawing 1 cm grids with pencil on paper - next time I'll go buy grid paper! I had a lot of islands in most of the pics but mostly just aligned them correctly or left connecting pieces to be able to work with them. Your painter's tape alignment tip was very helpful.
    All in all it took quite a long time - partly due to my perfectionism, but I'm sure next time will be quicker. I'm soooo happy and proud with the result though! As is my boyfriend for who this was a birthday present :)
    Yeah, intense/stupid :D The turtle was the most difficult as the boards I had were just a tad too small, so I had to draw its grids at 0.7 x 0.7 cm!
    aoag516
    7 years ago on Introduction
    I just finished mine, made a version using samus from metroid. it looks pretty badass. Thanks for the instructable.
    De Luca
    8 years ago on Step 7
    reminds me of when a pokemon evolves....
    Timotheus
    8 years ago on Step 5
    Bought some paint th is morning to make one of these (I'm doing yoyo kirby), but I didn't have enough for beeswax after buying paint (only had $20)
    So I'm going to give it a go with crayons and let you know how it turns out.
    kewpiedoll99
    8 years ago on Introduction
    What kind of paint did you use? If acrylic, how does the white adhere *at all* to the wax layer? Also, how did you get the runny drip effects coming off the bottom of your figure?
    It was all acrylic paint. It adhered just fine.
    The runny drip effects I made by slightly watering down some black acrylic paint and loading it up into a plastic syringe (made for baby medicine).
    sblank
    you can cut it into acetate or plastic sheets and use a spray adhesive for even cleaner lines.
    fungus amungussblank
    Acetate would be great if you want to do multiple copies. A spray adhesive would've helped as well, but with a stencil brush it's not necessary. My yellows got a little gloppy because I was in a rush.
    sblankfungus amungus
    oh don't get me wrong, its fantastic, i certainly like the look. just posted this if anybody needed it.
    mg0930mg
    I just made one for the mushroom from Super Mario Bros, in photoshop. It was very easy. I'm going to paint it tomorrow, hopefully.
    Great Job, Fungus.
