Multi-Purpose Pouch
547
15
This is a more advanced product, for those wanting to move on from basic projects aimed at beginners.
The pouch can be used for multiple purposes. It can be a pencil case, makeup bag or a jewellery pouch.
Personally I use mine as a pencil case. It is a fun back to school item that all of my friends have admired. s
Supplies:
Step 1: Materials
For Template:
- A3 Paper
- A4 Paper
- Scissors
- Pencil
For Pencil Case:
- Fabric
- Fabric Scissors
- Zipper
- Elastic
- Sewing Machine (with zipper foot and buttonhole attachment)
- Button
- Quick Unpick
- Needle
- Thread
Step 2: Template
- Piece A - Back, 25 cm x 32 cm, x 2
- Piece B - Pocket, 25 cm x 15 cm, x 2
- Piece C - Pencil case top and bottom, 25 cm x 8 cm, x 4
- Piece D - Tab, 10 cm x 6 cm, x 2
Step 3: Iron
I always like to Iron my fabric before I begin a project. This helps me to make sure my pieces are nice and straight and it just makes it easier to cut them.
Step 4: Cut Out the Fabric
Pin the templates to the first piece of fabric and cut them out.
For the second piece of each template - the outer layer, I used a different coloured fabric. If you choose to do this you will need to cut the second template pieces out of this second piece of fabric.
Step 5: The Pencil Case
Place B pieces right sides together. Repeat with C and D.
Pin them along one long edge, as shown above.
Step 6: Sew
Sew along pinned edge.
Step 7: Fold and Iron
Open out each piece and fold along seam. (right sides showing)
Iron.
Step 8: Sewing the Tab
Pin the two E pieces right sides together
Sew along the top and the two longest edges, as seen in the pictures above.
Step 9: Finishing the Tab
Cut the corners of the top of the tab (as shown in the picture)
Turn the tab inside out and iron it flat.
Step 10: Pinning the Zip
Cut two small squares of fabric
Stitch to each end of the zip. This makes the zip easier to work with, especially for beginners.
Take piece C and D
Pin to the zipper, as shown above
Step 11: Sewing the Zip
Using the zipper foot as a guide stitch along the edge of the zip on both sides.
Step 12: Fold and Iron
Once the zip is stitched in place, fold the outside edge over 1cm. Iron the fold.
Step 13: Sewing on the Pencil Case Pocket
Pin the pencil case pocket (pieces C & D) onto piece A as shown above
Working with the edge at the centre of piece A, join the pencil case pocket to piece A using straight stitch (as seen in picture above).
Step 14: Sewing the Elastic
Cut two pieces of elastic.
Pin them onto piece B.
Stitch elastic to piece B at desired intervals - the gap will depend on the end use.
I divided mine in half and then half again to give 4 sections.
Step 15: Putting It All Together
Place the piece B onto piece A (outer), opposite to the pencil case. (as seen in diagram)
Take piece A (lining) and place it on top, making sure that the right sides are together.
Pin around the edges and sew around the whole piece leaving a gap to allow your work to be turned through.
Step 16: Turn It Inside Out
Cut the off corners, to allow for a neater product once turned through.
Using a quick unpick, make a gap at the half way mark of the pocket seam (piece B). Insert the tab between the two layers of piece A, as shown above. Stitch in place.
Turn right side out through the gap.
Neaten corners by gently pushing into place using your fingers.
Step 17: Finishing Your Work
Stitch a top stitch around your work, 3mm from the edge
Step 18: Making the Button Hole
Using the buttonhole attachment on your machine, create a buttonhole in the tab. Carefully cut open with a seam ripper.
Step 19: Sewing the Button
Using a needle and thread stitch the button into place.
Step 20: Finished Pouch
Now your multi-purpose pouch is ready to use. Store your jewellery, make-up or pens and pencils.
Sew Cool Contest
Runner Up in the
Sew Cool Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
