Multimeter Upgrade on Li-ion Battery With Charging From USB
2,454
39
6
About: just do it yourself
How do i upgrade a multimeter
Step 1: All the Things You Need
  • Li-ion battery. 18650:
http://ali.pub/22bdhq or http://ali.pub/22bdjo . Other sizes: http://ali.pub/22bdmz or http://ali.pub/22bdnk
Step 2: If You Use a Charging Board With Protection, Use This Picture.
Step 3: Without Protection Will Look Like This.
Step 4:
Now you can throw away the 9-volt battery.
    • Build a Tool Contest
    • Weaving Challenge
      Weaving Challenge
    • Remix Contest
      Remix Contest
    6 Discussions
    Samuel Budiyanto
    4 months ago
    You must be careful, boost converter have an ripples voltage and if you not taming the ripple in high frequencies, many measuring will fail or give a false measure.
    I made it, but keep in the mind first; always put 100uH and rectify with 100nF + 100uF before the voltage come to the Multimeter.
    False reading comes when we driving microchips with bad input voltage (ripples in high frequencies).
    Greetings
    INDONESIA
    GayatriA3
    1 year ago
    if we try to use 2 bms in series for some specifications, then how do i make connections?
    rcs-al
    1 year ago
    How much current does the dc-dc converter drain on idle when the multimeter is off?
    18650Factorrcs-al
    Reply 1 year ago
    close to 0 ,my multimeter could not measure it. If you worried about it, you can put the switch in the circuit break
