Music Synced LED Lamp (using Arduino and Sound Sensor)
2,642
33
About: Student | Electronics | Love Programming | Foodie | There is always more to learn | Positive Vibes Always |
The Music Synced LED Lamp blinks the LEDs according to the beats of the music.
Supplies:
Step 1: Components Required
1. Arduino Board
2. Different colour LEDs
3. Sound Sensor
4. Breadboard
5. Resistors (100 ohm, 220 ohm)
6. Connecting wires
7. Butter paper
Step 2: Make the Following Connections
  1. Connect LEDs onto breadboard.
  2. The Negative of LEDs should be grounded using the 100 ohm or 220 ohm resistors
    (Negatife of LED -> Resistor -> GND)
  3. The Positive of LED should be connected to the digital pins of the Arduino board.
  4. Connect Ground of breadboard to GND on Arduino board.
Sound Sensor connections:
  1. GND pin of Sound Sensor to GND pin on Arduino board.
  2. VCC pin of Sound Sensor to VCC pin on Arduino board.
  3. OUT pin of Sound Sensor to digital pin 2 on Arduino board.
Step 3: Upload the Code Onto Arduino Board
Step 4: Video Demonstration
Play the Music and enjoy the Music Synced LED Lamp.
    • Arduino Contest 2019
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    3 Discussions
    rishabh8721TomD249
    Answer 1 year ago
    Hi Tom, I had made a circuit which takes input via AUX port and lit led strip sync with the music. I had used MSGEQ7 seven-band audio spectrum analyzer chip which you can order from aliexpress. Also, you can check
    full circuit and directions to make it. You can use an AUX splitter to give audio input to both i.e. your speakers and led circuit.
    xprobes
    1 year ago
    well keep in mind e resistence ..... of the devices... must keep track to be in proper circuit
