My Bloody Valentine, Valentines
11,539
201
6
Color inkjet prints on transparency sheets.
Step 1: Supplies
Color Inkjet Printer
Transparency Sheets
Scissors or Exacto Knife
Scotch Tape or Super Glue
Step 2: Get the File
(Skip ahead to the next step if you want to use files that already made)
Things exist on the internet for free sometimes. The heart used in this tutorial is one of these:
Heart Diagram
This file is part of the Wikimedia Commons. Sort of like saying "it's cool if you've got plans for this file."
I took it into Photoshop erased the names of valves and made everything red. What a plan.
Step 3: Print the Hearts
There is a JPEG attached that will print two hearts and a border on one transparency sheet. This is useful if you have two valentines.
See below for "hearts.jpg"
Step 4: Print the Words
I've included a file with some words. You may want to personalize this experience for that special someone. Do whatever you want.
Remember that you're going to press these two transparency sheets together, this means that your text will have to be mirrored/flipped horizontal/backward/inverted, you get it.
Print this file on a second transparency sheet.
See below for "text.jpg" to use the same file as this instructable.
Press these two transparency sheets together.
Step 5: Cut
Be careful.
Follow the border on the original heart print. Leave some red if you'd like.
You can tape the edge to preserve the words and the original shape of the heart print.
Step 6: Distribute
The ink may dry a little bit, but it will likely never dry completely. If you tape or glue the corners it may help preserve your prints.
Since you made two, you can try it both ways.
Distribute to each of your valentines.
  • Pie Contest
    Pie Contest
  • Weaving Challenge
    Weaving Challenge
  • Organization Contest
6 Discussions
hraman
6 years ago on Introduction
the idea's great..
but how do i paste the two printed sheets..?
did u use super glue or pvc glue..
clintsleeperhraman
Reply 6 years ago on Introduction
Hi! I never used glue, but found the ink was sticky and would hold my two sheets together. A little dab of clear glue in the corner could make them a bit stronger, not a bad idea at all...
