My First CNC Machine
105,497
1,237
35
About: I am a bit of geek who loved to make things himself or make things better. making it myself gives me great satisfaction especially if i can do it better and cheaper
This CNC was created using parts bought though the Kickstarter project www.aquickcnc.com.
Here is the Ended Kickstarted Project https://www.kickstarter.com/projects/ajquick/cnc-b...
The Design was built using Aluminium profiles and 3rd printed parts.
The great part of the design of this is that the Accuracy required for the project is designed in by using 3D printed parts. This was crucial for me as I don't own any equipment that would allow me to drill and cut accurately. the whole project was completed USING HAND TOOLS ONLY!
Step 1: Parts List
<---Main Parts--->
8 x 3/4" Linear Rod Rail Shaft Support For Cnc ***
4 x 3/4" rails 2x12" 2x24" http://www.aquickcnc.com/store/linear-bearings-an... ***
2 screw rails 1x12" 1x24" http://www.aquickcnc.com/store/
(alternative lead screws http://www.acculeadscrews.co.uk/acme-lead-screws/5...)
CNC Z Axis http://www.aquickcnc.com/store/building-blocks/z-a...
ACME Nut Bracket http://www.aquickcnc.com/store/building-blocks/acm...
Linear Bushing slide http://www.aquickcnc.com/store/building-blocks/lin...
Rounter Mount http://www.aquickcnc.com/store/router-mounts/bosch...
Stepper Motors http://www.aquickcnc.com/store/stepper-motors/bipo...
Motor Coupler (3/8" to 1/4") http://www.aquickcnc.com/store/mechanical-componen...
<---Emergency Stops--->
Microswitches x6 http://www.rapidonline.com/Electronic-Components/...
Crimp Connectors http://www.rapidonline.com/Cables-Connectors/Insu...
Sockets x4 http://www.rapidonline.com/Cables-Connectors/Clif...
Plugs to fit socket x4 (order some spare too) http://www.rapidonline.com/Cables-Connectors/Low-...
Cable http://www.rapidonline.com/Cables-Connectors/Alph...
<---Aluminium Profiles--->
Ordered from http://www.metallin.co.uk/shop/series-6 These parts from Metallin ordered cut to size and drilled. I Ordered all my parts cut to the correct length as I don't have a suitable method for cutting accurately
60x30 = 12" + 0.375" + 0.375" = 12.75" = 323.8mm x 2 (gantry bottom+ top)
60x30 = 24.75" + 0.375" + 0.375" = 628.65mm x 2 (Table length) with hole each end to attach universal connector
60x30 = 12" = 304.8mm x 2 (verticals) (Order End caps also x4)
120x30 = 12" = 304.8mm x 2 (ends) (Order End caps also x4)
T-Slot Nut 6 St M6
Standard Connector Set 6
<---Bearings--->
bearing 3/8 x 7/8
http://simplybearings.co.uk/shop/p42007/KLNJ3/8ZZ+...
Step 2: Design 3D Printed Parts
Using a 3d CAD software i designed the Brackets that would hold the Guide rails in place.
I also needed a part to mount one Stepper motor on the side of the Gantry.
The great thing about this is by having this part printed the accuracy of the design is printed in and does not have to be hand drilled in the workshop
I used http://www.rhino3d.co.uk/ software to design my parts and then sent them off to a 3D printer service to have the printed (https://www.3dprint-uk.co.uk/)
my 3D print STL files can be downloaded here
http://www.madguernseyboy.co.uk/files/Gantry%20Bra...
http://www.madguernseyboy.co.uk/files/x%20axis%20B...
http://www.madguernseyboy.co.uk/files/xbracket2.st...
Step 3: Drill Clarence Holes Fro Lead Screws
Drill holes in the Side Profiles and End profiles.
Because the Accuracy this 3D printed into the design the holes just have to be larger than the screws (3/8")
Step 4: BUILD TIME
Using a Tap set tap out the holes were required so you can use the T fasteners http://www.metallin.co.uk/shop/series-6/fasteners-..
then just take your time and screw all the parts together.
Step 5: Fit Emergency Stops
Using the switches Screw them in place so they will activate when the CNC machine reaches the end of its travel.
Wire the cables so it is NC (Normally Closed) that was if there is a short circit the CNC machine will fail to a safer position.
I had to add additional wiring to my control box for the Emergency stops.
Step 6: Calculate Steps Per MM for Mach3 Settings
Now I used this website (http://www.prusaprinters.org/calculator/) to calculate the correct Steps Per mm
the step angle of my stepper motors is 1.8°
the stepper motors are connected directly to the Lead screws so gear ratio is 1:1
and the CNC controller is set to 1/4 Stepping
my results were as follows
for the Z axis
9.53mm (2.11mm Lead) ACME Lead Screw
Steps per mm 379.47
for the X and Y axis
9.53mm (5.08mm Lead) x 381mm ACME Lead Screw
Steps per mm 157.48
Step 7: FINISH
I finished the design by adding a MDF work surface. This allows the bench surface to be easily replaced and flexible for fixing items to the base.
The last step is to connect it to a computer with a parallel port and run :)
Get a copy of the user manual for Mach3 (soon to be Mach4) spend lots of time reading and understanding the documentation. http://www.machsupport.com/help-learning/product-m...
Good luck and have lots of fun.
Step 8: Extra Step - Build Enclosure
Ok so its finished but it cant stay on my living room floor Until i get a bigger home!
So I needed to build a case so i can move it safely and look after all the kit
I built a rough box (using what material i had laying about) so the electronics could sit inside in a relatively dust free environment
The Machine can then sit on the top and the wires pass through to the machine.
Step 9: First Cutting Run
Its is a reasonable First effort BUT there are some learnings....
Learnings
1. There is Backlash/play in the Y axis casing errors. It is currently fitted with just a normal ACME Nut. I have placed an order for an AntiBacklash Nut so i can replace it.
2. The Gantry wobbles when moving in the Y Axis at high speed. This is because it is unbalanced. I have ordered a larger piece of Aluminium Profile so I can place the Centre of gravity in-between the two sleeves on the rails. additionally this will allow me to stiffen up my gantry more but will loose some cutting area.
3. I was initially receiving false Limit switch activations. The cause was traced to noise on the Limit switch signals. the reason for this I am unsure but it could be because I have not used Shielded Cables. To overcome this i have added some DeBouncing Code to the computer software to overcome this.
Step 10: Adding Router Speed Control and Emergency Stop Switch
I have used the UK equivalent to the Colt router which is a fixed speed router. This has given me an new problem... Spindle Speed control.
So what I have done is install the Kemo AC Power Control Module inline with an emergency stop.
I also connected one of the parallel port pins through the emergency stop.
this means in an Emergency when I press the button a stop signal is sent to the CNC controller and cuts the power to the Router.
Notes.
The speed controler cannot tell you how fast the spindle is spinning.
additionally on some fixed speed routers the cooling is dependent on the router running at full speed. thus running the motor slowly for an extended period can cause the motor to overheat and burn out.
CNC Challenge
First Prize in the
CNC Challenge
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    35 Discussions
    askjerry
    4 years ago on Introduction
    You may want to look at LinuxCNC as your software... it's free and very configurable. I've been doing quite a bit with it lately... adding probe routines, special function keys, etc.
    Jerry
    thanks.
    I have just started using LinuxCNC as an alternitive because i cant install windows on my PC. (Not sure why its not working)
    ArifE3
    1 year ago
    Can you send pdf files of cnc machine
    erdag_arif@hotmail.com
    ArifE3
    1 year ago
    Çok iyi iş, Solidworks & pdf Dosyalarını paylaşabilir misin?
    ahadiran
    1 year ago
    Very Good work, can you share de Solidworks Files?
    Email:ahadiran83@gmail.com
    richard westerfield
    3 years ago
    to bad this was built in England the cost would be to much to have the parts shipped over here other wise a nice build
    thank you
    Richard Westerfield
    Thanks for your comment
    Some of the parts were ordered from america.
    see http://www.aquickcnc.com/store/
    I hope this helps
    Brendan
    CorreyS1
    3 years ago
    How fast did it take you to put that cnc machining equipment together? By the looks of it seems like it would be simple to put one together. I'm guessing this will be something to try out and show to my father.http://www.productiveplastics.com.au/perspex-division/
    madguernseyboyCorreyS1
    Reply 3 years ago
    Well if you had purchased all the pieces and It could be easily built within a day.
    I think i built most of mine in a day. I ordered the aluminium profiles cut to size so it was very easy to assemble the main components.
    I has to wait for some switches , a computer to run it etc which slows things down.
    cliffyd
    3 years ago on Introduction
    for that amount of money you could have bought a complete cnc ! This is diy not assemble out of box-structable!
    madguernseyboycliffyd
    Reply 3 years ago on Introduction
    It is true for the money I spent in the long term I could have bought one.
    But I set out in the beginning from knowing nothing about a CNC machine to build my own from scratch. This project took me almost 7 years in planning and saving money and eventually building.
    I have enjoyed making some mistakes along the way and have learnt much.
    If you wish an out of the box instructable i suggest you look at other projects.
    hey
    since i bought all my stuff from http://www.aquickcnc.com/store/
    looking at the comparison it looks good. its also 4 axis which is great.
    brendan
    prabhjotIN
    3 years ago
    Exceptional work!!
    I would really like to see how well the machine works on Aluminum. Could you please post some photos for that!
    Also if you could throw some light on what kind of modifications does one need to make to enable the machine to mill and drill other harder metals?
    madguernseyboyprabhjotIN
    Reply 3 years ago
    hey
    thanks for you comment. i have yet to machine some aluminium. I am considering making it larger as my X axis is currently limited in the amount of machining space.
    but when I do machine some aluminium i shall be sure to post a video.
    as for machining harder metals..... I am not totally sure but you most certainly will have to consider some sort of coolant!. with my current design this would not be possible as all the electronics are underneath.
    You may also may need to build the machine more solidly to allow extra rigidity
