My First Mechanical Iris
17,935
72
17
Hello Guys, this was my first attempt  into a mechanical iris, it was a very fun project, inspired on "gogglerman" creations.
The outside ring (red ring) is made of 3 mm MDF, it has a 130 mm outside diameter, and, an 75 mm interior diameter.
The ring was cutted with holesaws.
The back plate (silver round plate) is made of 12 mm MDF, the runners on it, were made with a tablesaw. it also has the 130 mm outside diameter.
The leaves are made from aluminized sheetmetal.
Bicycle spoke nipples were used as pins, they were brazed to the sheetmetal.
And finally, the whole assembly was housed in a cd tube case.
Thanks for watch!
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    17 Discussions
    millikiani
    1 year ago
    Hello my name is milad i need to make an iris cutter and i need help may i ask your help
    Hoggster
    7 years ago on Introduction
    What did you use to drill/cut the leaves? Im limited to some school drills, and im forced to do line cutting with a powerfull machine rather than break one with a weak blade.
    natacular
    Excellent video. Was having trouble getting my head around it, but it all makes sense now. Cheers:)
    dombeef
    Very interesting, I made a foam core iris and my prototype looks very much like this, but with only 6 leaves. I have the iris as an instructable on this account.
    Is the next one going to be the same size?
    kommodoredombeef
    Thanks, well i just have finished my second iris, and just published it, you can see it here, is the same size as the first one, but this time with an open backplate you can see it here.
    https://www.instructables.com/id/My-Second-Mechanical-Iris-Mi-segundo-iris-mecnico/
    Regards!
    kommodorerimar2000
    Thanks.
    About the center hole, i did not calculate the tracking pins location, so at first i had a back plate with 75 mm hole, but the runners lenght was not enough to close complete, so i did the back plate without hole, just to get the iris to close complete.
    Now im working in a second iris, and this one will have the big hole.
    Regards!
